Question about Samsung Televison & Video
Samsung cs_21z45ml have sound but no picture
    Top Expert:
  • Samsung Master
  • 75,581 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on May 01, 2015
I have crt samsung television model cs-21z68mg. There is sound but no image,help please and thanks.
Check its horizontal output section circut for the fault. Most probably, line output transformer might be faulty. Not, might be, but is.
Aug 30, 2012 | Samsung Televison & Video
Samsung tv ct-21z45ml problem is power supply ,work in 110 volts but dont on 220 volt
Possible there is a fault in the auto detection circuit or a protection in force when it is powered in the 220 volt line. It is important to isolate and check the SMPS - the switch mode power supply as it can be faulty in the auto detection- auto protection feedback section, Check the opto-coupler section.
please check this link for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Aug 24, 2011 | Televison & Video
Please what is the factory reset for samsung tv.Modle Cs-21z58ml.
samsung tv MODEL CS-21Z58ML.no picture and low brightness problem has been re solved by replace the crt .if you found 4voltage for heater 190volt for scren still no picture you have to replace crt.but some times might be the micro chip on the circuit that its not pushing up the RGB's colors but most and common problem is CRT board.if you'll try to replace the transistors or ic.it will not change any thing.so guys letme know if you fixed it at costerntine@gmail.com thanks
Mar 07, 2011 | Samsung LN-T3253H 32 in. LCD Television
Samsung TV, Modal:(cs- 29k10mq ) only got sound but no picture..
I NEED TV SAMSUNG CIRCUIT DIGRAM MODEL CS-29K10MG,IF SOMEONE GOT IT SEND TO ME BY EMAIL ,mobydick.jusoff@gmail.com...thanks
Oct 05, 2010 | Samsung Televison & Video
Spotty tv
DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.
Jul 27, 2010 | Samsung DLP HL-P5663W 56" TV
Adjust the screen/display size for CS-21K10MQ in normal view
This is a hardware fault and is usually related to the flyback transformer and some of the caps that control picture. It needs technical intervention
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Televison & Video
Over temp red light fashes
Check and replace the following on the smps:
Cs-860 & Cm-860 1500uf/10v With 2200uf/16v
Cm-856,Cm-858,Cs-859,Cs-861 With 1000uf/25v
Replaced Cm-854 & Cs-857 With 2200uf/25v
then let me know if it will power on...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Samsung HL-S5679W 56" HDTV
SAMSUNG SGH G600
if you go onto settings then phone settings, then phone profiles and click edit on the profile your on you can change sound settigns:]
Sep 05, 2008 | Samsung SGH-G600 Cellular Phone
Televison & Video Logo
53 people viewed this question
Jerry Greenberg
Jerry Greenberg
