Question about Apple iPad (16 GB) WiFi Tablet PC
Screen indicated Be Right Back. upgrading. How can I get it to return too be of use?
  • Apple Master
  • 5,631 Answers
How much time has it been with "Be Right Back" message on? Upgrase should take mo nomre then about 15 - 20 minutes
Posted on Apr 30, 2015
On my kindle reading app, how to switch from reading to listening
Step 1: Make sure you have not only the Kindle app installed on your mobile device, but also the Audible app. It's the latter that will handle the heavy lifting, audio-wise. Update: According to Audible, the Kindle app has the necessary audio tech built in, and therefore the app itself is not required.
Step 2: The best way to see this in action is with a book that supports Whispersync for Voice. You can use Amazon's Matchmaker service to see which Kindle books you already own are able to be upgraded with audio, but you can also start with a freebie: Amazon is currently offering the classic "Black Beauty" for Kindle at no charge, with accompanying professional narration also at no charge. (After you "buy" the book, you'll see a button allowing you to "buy" the narration as well.)
Step 3: Load the Kindle app and open "Black Beauty." Tap anywhere on the screen to bring up the options menu, then look in the lower-left corner. You should see a headphone icon. Tap it, then tap the blue download arrow on the subsequent screen. This will start the download of the book's audio companion file.
Step 4: When the download is done, you'll see a familiar-looking set of play controls. Tap the big blue triangle to play/pause, or either of the quick-skip buttons to go forward or back in 30-second increments.
Step 5: To return to the text version, tap the little book icon in the lower-left corner of the screen. Because the book and audio editions stay in sync, you'll always be at the right location as you jump back and forth.
Dec 28, 2016 | Amazon Tablets & eReaders
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
I can't access the kindle store
Are you out of your usual wi-fi area? You may need to go back and check wi-fi settings and set up again.
From Home or any Settings screen, view the wireless indicators at the upper right corner of your Kindle. While reading, tap the top of the screen to view the wireless indicators.
Wireless Indicator Description Your Kindle is connected to 3G. This may also say EDGE or GPRS.
Note: For 3G enabled devices only Your Kindle is connected to a Wi-Fi network and has a strong signal. The Wi-Fi symbol appears when in range of a trusted Wi-Fi network.
Dec 10, 2016 | Amazon Tablets & eReaders
Mr. Danger, please tell me how to unlock the frozen screen for Double Down Casino. How do I do that?
When this kind of sign comes to screen it's really hard to take a decision but finally you don't have options but turn off your device..
Now, this might sove the hangup or might mean more trouble but I really don't see any other opton.
When I have hangup problems with my Apple iPad, I turn it ofF!
Maybe you can leave it on utlil battery gets discharged, device turns off and then you should connect the charget and turn it on
Apr 30, 2015 | Apple iPad (16 GB) WiFi Tablet PC
My zeepads screen isn't lighting up. if you turn it just right in the light it can barely be seen. I have tried the back light and the brightness settings on the tablet and the reset..nothing has worked....
If you can see a faint picture on the screen then it is probably the screen inverter is faulty! If it is still under warranty then send it back!
Dec 25, 2014 | Tablets & eReaders
I have a Polaroid 10.1 inch p10 model tablet why does it reset itself every time I turn it off
Same problem called them and they said its a known issue and there is no fix as of yet. They said hopefully they will have software to fix it within two weeks. I already returned device twice they said it was with all p10's. U would think they would shut it down and reboot it at least before putting it on the shelf's. Smh
Dec 02, 2014 | Tablets & eReaders
Screen rotation lock is now audio muting. i want to return to screen rotation lock
Unfortunately, this is a new feature from a past update. There is no current way to change the lock button back. However, you can access the screen rotation lock by double clicking home, swiping right, and toggle the screen rotation lock. As a future note, in the next update, you will be able to change it back.
Feb 25, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Lcd screen problem
if the lights didn't off, maybe your N800 is grounded. return it for repair.
May 25, 2008 | Nokia N800 Tablet PC
Apple iPad (16 GB) WiFi Tablet PC Logo
32 people viewed this question
Top Apple Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
John mullen
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
