Question about Xerox Phaser 7500DN Laser 7500DN Printer
What is error detected in printer motor in printer motor 042-323
On restart machine prints the configuration sheet then Error detected in printer motor 042-323
4 Suggested Answers
  • 208 Answers
SOURCE: [No Paper] error
take out the paper tray and look inside. You will see a feed tire about 4 inches in, on the upper frame over where the paper stack would be. Right behind that feed tire, there should be a black hook shaped actuator that contacts the paper stack when you put the tray in. It is about 3 inches long.
Either that is knocked off or the sensor popped out of its slots.
The board could be bad, but that is very unlikely.
95 percent of the time that actuator is knocked off or the sensoe is out of place.
If you cant find the actuator, if that is the problem, you can slip a piece of tape , not scotch tape, some type of tape you cant see through, into the channel of that sensor. the only difference you would notice is you would not get an out of paper message but a jam when you ran out of paper.
Posted on Dec 20, 2007
  • 70 Answers
SOURCE: Printer thinks its out of paper
  1. Open the Document Feeder by placing your fingers under the opening where you feed paper, and lifting upwards.
  2. Locate the black Paper Sensor (the black plastic switch that hangs down).
  3. Make sure the Paper Sensor is not pressed in. It should move up and down freely.
  4. If the Paper Sensor is stuck in the up position, try to gently pull the Paper Sensor back down.
  5. Turn the power off by pressing the Power Switch to the [ O ] position.
  6. Turn the power back on by pressing the Power Switch to the [ | ] position.
  7. Try to make a copy using the Document Feeder.
  • If the Paper Sensor is broken off or pushed in, you will need service on your WorkCentre.
  • If the Paper Sensor is not broken off or pushed in, the Paper Sensor not the cause of the problem
Posted on Oct 02, 2008
  • 10 Answers
SOURCE: Xerox system error 09,035,43:46300.
This is from the service manual
Harry
9,035.43 through 9,038 (8500/8550/8560 only):
Ink count sensor flags are
stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41,
where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out
Sensor located at the forward end of each ink channel of the Ink Loader. The
sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This
can lead to false Ink Out messages as well as Ink Stick count faults. Using
8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick
count faults.
Troubleshooting Procedure for Ink Loader
Step Questions and Actions Yes No
Is the ink Genuine Xerox? Are they the
correct sticks for the model?
Go to Step 2. 1. Advise customer.
2. Replace the Ink
with Xerox Ink.
3. Run Clear ISC
Fault
test to clear
the error. The
Clear ISC Fault is
located in the
Internal
Diagnostics
Function menu.
2 Manually verify that the ink stick is able
to advance in the ink loader chute.
Check for broken or wrong type ink
sticks.
Go to Step 3. 1. Remove any
blockage and/or
replace the ink
stick.
2. Replace the Ink
Loader.
3. Run Clear ISC
Fault
test to clear
the error
Posted on Aug 25, 2010
Error 163 on oki c5500 printer
163 Toner Sensor Error, Color: Black An error has been detected in your printer's Toner Sensor.
1 Machine Check Exception A problem has been detected in the printer hardware
2 DSI Exception The printers main logic has attempted to look up an invalid address.
3 ISI Exception The printers main logic has attempted to read the next instruction, which has failed to execute for some reason.
4 Alignment Exception The printers main logic cannot access the memory for some reason.
5 Program Exception The printers main logic has issued an exception code.
6 Floating-point Unavailable Exception A floating-point instruction is executed when the MSR floating point enable bit is set to Disable.
7 Instruction Address Breakpoint Exception The printers main logic has attempted to look up an invalid address.
20 CU ROM Hash Check Error 1 CU ROM hash check error has been found. Check reproducibility if possible.
21 CU ROM Hash Check Error 2 The printers CPU has a checksum error in it's memory.
23 CU ROM Hash Check Error (resident) Seek service if restarting the printer does not correct the problem.
25 CU ROM Hash Check Error (DIMM2) Seek service if restarting the printer does not correct the problem.
30 CU Slot1 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 1
31 CU Slot2 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 2
35 Slot1 RAM Spec Error Check the specification and install in slot 1 RAMs supported by the product
40 CU EEPROM Error The EEPROM mounted on the CU board needs to be replaced
41 CU Flash Error The CU Flash needs to be replaced
43 Flash File System Version Mismatch Seek Service if restarting the printer and initialising the flash memory does not correct the problem
42 Flash File System Error Seek Service if restarting the printer and initialising the flash memory does not correct the problem
43 PS Flash File System Error An Flash Memory error has occured and the printer needs to be serviced if restarting the printer does not correct the problem
51 CU Fan Error The CU cooling fan needs to be replaced if restarting the printer does not correct the problem
70 Postscript Failure An error has been detected in your printer's Postscript Core.
72 Engine Communication Error A communications error has occurred between CU and PU boards.
73 H/W Overrun Detect An error has been detected in your printer's hardware input area.
74 F/W Overrun Detect Occurs when the firmware is unable to set video data in response to video DMA's data request.
75 VIC Limiter An error has been detected in your printer's
80 Parameter I/O Error An error has been detected in your printer's Input/Output area.
81 Parameter Consistency Check Error The EEPROM and flash memory reformatted and initialized.
102 Engine RAM Error An error has been detected in your printer's engine RAM.
103 Engine SRAM Error An error has been detected in your printer's engine SRAM.
104 Engine EEPROM Error An error has been detected in your printer's engine reading/writing the EEPROM at power-up.
105 Engine EEPROM Missing Error An error has been detected in your printer's Engine
106 Engine Control Error An error has been detected in your printer's Engine Controller.
122 Power Supply Fan Motor Error An error has been detected in your printer's Power Supply Fan Motor.
123 Humidity Sensor An error. has been detected in your printer's Humidity Sensor
124 Temperature Sensor An error has been detected in your printer's Temperature Sensor.
127 Fuser Unit Fan Error An error has been detected in your printer's Fuser Unit Fan Error.
131 LED Head Missing, Color: Yellow When yellow LED head connection cannot be detected
132 LED Head Missing, Color: Magenta When magenta LED head connection cannot be detected
133 LED Head Missing, Color: Cyan When cyan LED head connection cannot be detected.
134 LED Head Missing, Color: Black When black LED head connection cannot be detected.
140 Drum Up/Down, Color: Yellow An error has been detected in your printer's Yellow Drum
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum.
142 Drum Up/Down, Color: Cyan An error has been detected in your printer's Cyan Drum.
150 Drum Fuse cut NG, Color: Yellow An error has been detected in your printer's Drum Fuse.
152 Drum Fuse cut NG, Color: Cyan An error has been detected in your printer's Drum Fuse.
153 Drum Fuse cut NG, Color: Black An error has been detected in your printer's Drum Fuse.
155 Fuser Unit Fuse cut NG An error has been detected in your printer's Fuser Unit.
154 Belt Unit Fuse cut NG An error has been detected in your printer's Belt Unit.
160 Toner Sensor Error, Color: Yellow An error has been detected in your printer's Toner Sensor.
161 Toner Sensor Error, Color: Magenta An error has been detected in your printer's Toner Sensor.
162 Toner Sensor Error, Color: Cyan An error has been detected in your printer's Toner Sensor.
170 Upper Thermistor, State: Short An error has been detected in your printer's Upper Thermistor.
171 Upper Thermistor, State: Open Restart the printer. If the problem continues the printer will need to be serviced
172 Upper Heat Temp, State: High An error has been detected in your printer's Upper Heat Temp.
173 Upper Heat Temp, State: Low Turn the printer off to let it cool down, then restart the printer.
181 I/F Error, Loc. Duplex An error has been detected in your printer's Duplexer.
182 I/F Error, Loc. Tray2 An error has been detected in your printer's Tray2.
187 I/F Error, Loc. Control Pnale An error has been detected in your printer's Control Panel.
190 System Memory Overflow An error has been detected in your printer's System Memory Overflow.
191 Page Memory Overflow An error has been detected in your printer's Page Memory Overflow.
200 PU F/W download Check Sum Error Error during PU flash download
201 PU F/W Flash Write Error An error has been detected in your printer's PU F/W Flash Write Error.
202 PU F/W Flash Data Missing An error has been detected in your printer's PU F/W download Check Sum Error.
203 Engine Page Sequences IMAGACK Error An error has been detected in your printer's Engine Page Sequences IMAGACK Error.
204 EnginePageSequences IMGSET Error An error has been detected in your printer's Engine Page Sequences IMGSET Error.
2005 Oki Data Americas, Inc.
Sep 14, 2012 | OKI C5500n Printer
49.ff05 error
A 49 error on an HP printer is caused by the printer receiving a commmand it does not understand. It is the computer equivalent of "huh?" The first step to fixing this is to ensure that you have the most current firmware installed for the printer. Curent version is 02.120.3. To find what is installed, restart printer to clear the 49 error and then printer a configuration page. On the upper left hand side of the config page you will find the firmware revision listed. If it is not 02.120.3 then follow instructions below. You can print a config sheet by using the up or down arrows to change the menus until it displays information. Press checkmark and then on the next menu use the up/down arrow till you find configuration sheet and press checkmark again. You may need to ensure that there are no print jobs pending so that the printer does not have another 49 error while you are trying to do this.
Firmware upgrade instructions:
Click here to access HP site where you will find the lastest firmware revision. If you are using Windows, download the first option which is the EASY INSTALL. Run the file once downloaded and it will automatically start and confirm which printer you want to upgrade.
Mar 13, 2011 | HP LaserJet P3005d Printer
The yellow lamp is flashing and printer dosn't work .My printer is pixma mp510 canon
How many times does it blink... 2, 3, 12....
2 times Carriage error [5100] An error occurred in the carriage encoder signal. - Carriage unit (QM2-3753)
- Timing **** film (QC1-9542)
- Logic board (QM2-3827)
- Carriage motor (QM2-3872)
3 times Line feed error [6000] An error occurred in the LF encoder signal. - Timing sensor unit (QM2-3878)
- Timing **** disk film (QC1-9597)
- Feed roller (QL2-1407)
- Paper feed motor (QM2-3873)
4 times Purge cam
sensor error
[5C00] An error occurred in the purge unit. - Purge unit (QM2-3754)
5 times ASF (cam)
sensor error
[5700] This error takes place when feeding paper from the
ASF after an error occurred in the ASF cam sensor.
- Sheet feed unit (QM2-3762)
- ASF_PE sensor board (QM2-3877)
6 times Internal
temperature
error
[5400] The internal temperature is not proper. - Logic board (QM2-3827)
7 times Ink absorber
full
[5B00,
5B10,
5B01,
5B11]
The ink absorber is full.
Error codes:
Overseas:
5B00: Main ink absorber
5B10: Borderless-print ink absorber
Japan:
5B01: Main ink absorber
- Ink absorber kit (QY5-0178)
1-5
Note: Before replacement of the logic board ***'y, check the ink absorber counter value (by service test print or EEPROM information
print). If the counter value is 7% or more, also replace the ink absorber kit (QY5-0178) when replacing the logic board ***'y, or
register the current ink absorber counter value to the replaced new logic board instead. [See 3-3. Adjustment / Settings, (9)
Service mode, for details.]
2-3. Other Error Messages
5B11: Borderless-print ink absorber
8 times Print head
temperature
rise error
[5200] The print head temperature exceeded the specified
value.
- Print head (QY6-0070)
9 times EEPROM
error
[6800] A problem occurred in writing to the EEPROM. - Logic board (QM2-3827)
10 times VH monitor
error
[B200] The internal temperature exceeded the specified
value.
12 times PG position
error
[5C10] An error occurred in the PG motor during purging
operation.
15 times USB Host
VBUS
overcurrent
[9000] The USB Host VBUS is overloaded. - Logic board (QM2-3827)
19 times Ink tank
position sensor
error
[6502] None of the ink tank position is detected. - Spur base unit (QM2-3750)
20 times Other
hardware error
[6500] The PCI bus error is detected by the ASIC. - Logic board (QM2-3827)
22 times Scanner home
position error
[5010] The scanner unit cannot detect the home position, or
the scanner unit warming-up is not performed
properly at power-on.
On the LCD, "Scanner is not operating correctly." is
displayed.
- Scanner unit (QM2-3775)
Alarm and Power
LEDs lit
ROM error,
RAM error
A flash ROM or RAM checksum error occurred at
hard-power-on.
Jan 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
I HAVE AN ERROR MESSAGE FUSER ERROR WHAT SHOULD I DO?
Power down Machine and restart. If error comes back , you need to order a fusing unit or maintenance kit depending on the pages printed. To get the counts for the last maintenance kit press check mark and scroll to information ,check mark then print configuration page check mark.
Oct 13, 2009 | HP LaserJet 4600dn Color Printer
Error 41 brother all in one :Performed Print Quality Check Sheet $ times. The test sheets became closer and closer to being 100% correct, then error 41 pops up
Machine error 41 is "defective print head".Try to turn off the printer and wait 10 min.Then turn on, if the error continue showing your printer need service.
Oct 13, 2009 | Brother MFC 420CN All-In-One InkJet...
We had a cartridge error. We refilled and replaced the cartridges but still have a cartridge error. We have restarted and unplugged and replugged the printer a couple of times and still have the cartridge...
Your cartridge has something wrong with its electronics. There is no way to "fix" this problem. The reason you could print a calibration sheet is because the printer does not need an electrically functioning cartridge to print this test page. You need to purchase an ink cartridge that has good electronics on it. It doesn't matter if you get a refill or original manufacturer cartridge.
Oct 02, 2009 | HP PSC 1410 All-In-One InkJet Printer
Error on my printer
turning machine off/on doesn't help?
The laser motor has failed most likely
Apr 16, 2009 | Office Equipment & Supplies
Printing
network cable,Thanks
Feb 23, 2008 | HP LaserJet 2430dtn Printer
Error code SC670
Its an over load of information by the file.
here is the actual code: SC670 mistake Engine Response
Jan 25, 2008 | Ricoh Aficio AP3800C Laser Printer
Open Questions:
See all Xerox Phaser 7500DN Laser 7500DN Printer Questions
Xerox Phaser 7500DN Laser  7500DN Printer Logo
466 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
