Question about Whirlpool Refrigerators
Fridge light not working and filter light not working on whirlpool gd5rhaxnq00
4 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Whirlpool Side By Side GD5RHAXNQ00-Electrical Issue
The arcing noise is just that, a loose connection causing electricity to arc from one place to another. this is initiated by opening the door and closing the light switch. The small glow is from a small amount of voltage reaching the bulb. If you are inclined, repair it. remove the cover, look for the burnt wire or connection. If its a removable part, replace it. If not clean it up and/or make a new connection. One thing is for sure, it will not get any better and may get worse and burn up something more critical.
Posted on Jan 13, 2008
SOURCE: Whirlpool GD5RHAXNQ00 Ice maker not making ice
We had a similar problem and there was a broken/stripped gear in the icemaker. A&E replaced it to the tune of $150 or so. I don't recall exactly but I recall my husband thinking he could replace the entire icemaker for the price we paid to repair it. The gear make the ice tray flip out the ice once frozen. Good luck, hope that helps a little.
Posted on Jul 15, 2008
  • 61 Answers
SOURCE: WHIRLPOOL SIDE BY SIDE MODEL GD5RHAXNQ00 ELECTRICAL ISSUE
most comonly the door switch has blown. if you are not using the humid switch in the on position . condensation can build aroud doors and consiquence water gets into the switch. youll nead to unplug the unit and pull out the switch carefully not to damage the breaker strips use and olm meater to check the switch for condinuity.
Posted on Oct 06, 2008
GD5RHAXNQ00 LEAKING?
There are several causis from water leaking from the back of the fridge did you check is not condensation? In case you will need to lower fridge temperature
Feb 24, 2008 | Whirlpool GS6NBEXR Side by Side...
Gd5rhaxnq00
The lights are controlled by door switches and a small circuit board near the compressor=> W10135090 Main Control Board
The control board is quite expensive and if you know someone that can replace circuit board parts it would really pay to have them replace a defective relay, Thanks Sea Breeze
Jan 30, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light will not come on model#gd5rhaxnq00
Unplug your refrigerator and pry out the door switch and check for continuity. In most cases this can be a defective door switch. Can you test the door switch with an OHM Meter?=> 1118894 Door Switch I am here should you have questions or comments, Thanks Sea Breeze
Jan 10, 2013 | Whirlpool Refrigerators
I changed the water filter in my Whirlpool refrigerator, model #EDVHEXVQ01. I then tried to reset the filter light, but it did not work. Should I do something different to reset it or did I do something...
Hi
I guess you changed the filter with the fridge plugged in, you need to switch off and unplug the fridge, switch off the water. Then switch on the fridge and bleed the water line for 5 second intervals every 5 seconds for 1 to 2 minutes.
That should solve the problem
Regards
Gordon
Apr 20, 2011 | Whirlpool Refrigerators
Whirlpool Gold GD5RHAXNQ00 refrigerator not cooling properly.
It takes time for the temp to adjust(up to 24hrs) If the door is open a lot(looking into the box) or the door gasket is bad this will contribute to your problem. Are you sure the thermometer is good that you are checking the machine with. The thermistor could be bad as well(the control that senses the actual temp
Nov 03, 2009 | Refrigerators
Oct 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Jun 21, 2008 | Whirlpool GD5SHAX Side by Side...
Jan 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool side by side fridge freezer
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
