Question about Refrigerators
How do I clean condenser coils on a Ward HMG 2172-4
    Master:
  • 477 Answers
Unplug the power to the machine. Remove a bottom back cover and use a bristle brush with strokes in the same direction as the fins are. If the clog is stubborn, take the fridge outside and hose the coil clean with a garden hose while not pointing the water at the motor or electrical. Let it dry and put it back together. Keep the fridge upright, a little tilt is ok but not lay it on its side.
Posted on May 01, 2015
  • 156 Answers
Coils on 'fridges are either underneath or on the rear, so you need a good vacuum cleaner with a crevice tool.
Posted on Apr 30, 2015
Montgomery ward side by side HMG 229637B ... defrost timer does not cycle ... have relaced defrost timer .. STILL DOES NOT cycle ...if i manually cycle coils heat ... defrost etc etc BUT refridgerator does...
turn the allen screws one is under the hindge side of freezer door and one is under fridge hindge side of door turn counter clockwise be carefull turn to far the adjustment screw will come out of the wheel adjustment bracket.also try having someone tilt refrigator back by pushing top of refrigator then turning the two white adjustment screws in same area of allen screw this adjust the front of the refrigator you may want to adjust the front adjustment so the refrigator is slightly tilted to the back this will help close the doors.
Jan 22, 2014 | Montgomery Ward Refrigerators
Admiral / HMG 23173 / 10690324HQ. Motor running. Freezer cooling but not freezing. Refrigerator cool - not cold. Not sure age of refrigerator. Internet says 1964 or 1988 - so probably 88 since house...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Admiral Refrigerators
My MW model HMG 1889-4 does not cool the fridge or keep the freezer cold. The motor sounds like it's running (not sure if thats the compressor?) . What suggestions do you have. Thank you
heatman101
Apr 22, 2011 | Refrigerators
Water collecting in bottom of refrigerator side under meat keeper. Wards model no. HMG 2290
Check to see if your ice maker is not leaking water. Otherwise, the problem might be a clogged drain in the freezer. Need to remove the back cover in the freezer to check that the drain is clear. If it is clogged, try removing any blockage that you see and push wire down the drain tube to clear any blockage in the tube.
Oct 04, 2010 | Montgomery Ward Refrigerators
My Ward, HMG - 1400 - 0, refridgerator coils will ice over
Make and model numbers are important to give answers.
Jun 19, 2009 | Montgomery Ward Refrigerators
Middle Wall too hot
There is a pipe with hot gas running through the middle wall to keep the gaskets dry but if itgets to hot probably the condenser coil behind the fridge is dirty ,unplugged it snd brush all the dust and dirt off .That willlower the temperature in the middle wall and it will cold better.
Apr 11, 2009 | Refrigerators
The center divider in our hmg-2170-4 is very hot. the fridge is cool and the freezer is cold, but the center is hot enough to burn you if you are not careful.
Your condenser fan motor (down by compressor) is not running. Either bad motor or something has blocked it. Also possible that condenser coils are filthy.
Nov 27, 2008 | Refrigerators
Montgomery ward refrigerator freezer side by side model hmg 2164
Hi there!
Was the bulb blown that you removed?
If not, it may be the contact switch on the door. These usually are just a press fit, sometimes needing a screwdriver in a slot to release it.
Hope this helps you. If it does, Please take a moment to rate your problem fixed with Fixya! Thanks.
Jun 17, 2008 | Amana ARB2217C Bottom Freezer Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
