Question about Whirlpool Washing Machines
Spins basket once then won`t start blinks 7 times
Washer won`t fill goes into sense mode and locks out
    Problem Solver:
  • 19 Answers
Check switch under the top of the lid it will not be working feel around under the lid located usually on either side
Posted on Apr 30, 2015
Kenmore 11025102310 washer isnt working. I press the start button, and the sensing button lights up for just a second and there is a couple of minutes of a grinding type of noise but then nothing.
SENSING Page 5
When the START/PAUSE/Unlock Lid is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will use short, slow spins to estimate the load size. These sensing spins may take 2 to 3 minutes before water is added to the load and you may hear the hum of these spins. If the sensing light is on, then washer is working properly. You will hear the motor turn the basket in short pulses to thoroughly wet the load. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: Avoid opening the lid during sensing. The sensing process will start over when the washer is restarted. The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
If there's no water, then Page 13
Washer won't run or fill, washer stops working, or wash light remains on (indicating that the washer was unable to fill appropriately)
Check for proper water supply.
Both hoses must be attached and have water flowing to
inlet valve.
Both hot and cold water faucets must be turned on.
Check that inlet valve screens have not become clogged.
Check for any kinks in inlet hoses, which can restrict water flow.
Or you have an inlet valve that is not working
Apr 29, 2016 | Kenmore Washing Machines
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
How do i get codes for a whirlpool cabrio wtw5500xw0 washer with no display?
Error codes for WTW5550XW whirlpool cabrio
It would appear that no one read your original post, I believe you asked: HOW DO IT GET THE ERROR CODE. I have the same machine and had the same problem. The method is descibed in the service manual available at servicemanuals.net for about $17. It also has a decent wiring diagram and how to generally do anything the local service guy could do well worth the money for a download you can have in your hands in minutes.
Back to your question.1) turn the washer off (the power button) all the indicator lights should be off.
(now think of your old gym locker combination lock, cause it will be a little like this)
2a) rotate the center selector knob CCW (counter clockwise a few clicks), this seems to get the machines attention
2b) immediately rotate 1 click CW clockwise
2c) immediately rotate 1 click CW (again)
2d) immediately rotate 1 click CW (again)
2e) immediately rotate 1 click CCW
2f) immediately rotate 1 click CW (again)
visually it would look like this <---,->,->,->,<-,->
now just the led's below the indicator should be blinking off and on on about 1 second intervals
you may need to try a few times to get the timing just right, you aren't spining through the clicks, just about enough time to say "left-left-left-right one,right-two,right three,left one, right one
with all the led's in a row blinking you are ready to go into code mode.
(sensing soak wash rinse spin done) (mine doesn't have soak BTW)
3) rotate the selector knob a few clicks until only the "done" led is lit
4) press start
5) the led's should blink again
which leds blink tells you alternately the fault# and error# when the "sensing" led is blinking, the other leds are indicating the fault number, when it is not on, the indicate the error# the fault# is the type of problem, and the error# indicates where the problem was detected.
6) a partial listing using the fault #, I will indicate the led as follows: Sensing/Wash/Rinse/Spin/Done
S/W/R/S/D this would be all these leds lit
s/w/r/s/d this would be all these leds off
the F# codes to the right is what you would see if you had the numeric display on the console (not all models)
Here goes:
Over suds condition: S/w/r/s/d F0
High water temp rinse cycle: S/w/r/s/d F0
Off balance load: S/w/r/s/d F0
Main control fault: S/w/r/s/D F1
Motor control fault: S/w/r/s/D F1
Stuck key: S/w/r/S/d F2
Mismatch of main control UI: S/w/r/S/d F2
Pressure sensor fault: S/w/r/S/D F3
Inlet water temp fault: S/w/r/S/D F3
Lid switch fault: S/w/R/s/D F5
Lid lock fault: S/w/R/s/D F5
Lid unlock fault: S/w/R/s/D F5
Lid not opened between cycles: S/w/R/s/D F5
Basket speed sensor fault: S/w/R/S/D F7
Shifter fault: S/w/R/S/D F7
Motor fault: S/w/R/S/D F7
Motor unable to reach target rpm:S/w/R/S/D F7
No fill long fill: S/W/r/s/d F8
Overflow: S/W/r/s/d F8
Hot cold reversed: S/W/r/s/d F8
Long drain: S/W/r/s/D F9
yes several of these had identical blinking light combinations, but it is good start.
Apr 21, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Just bought a front load whirlpool wash machine. when i turn it on it locks door then unlocks door, it does this 2 to 3 times then the washer fills with some water only spins about 3 times then it waits...
This washer will stop and start a number of times during fill as it is sensing how much water it needs. Also you must hook both water line up and have both on. Also you must use HE soap and very little of it.
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't Spin Without Assistance
It sounds to me like either there is an excessively heavy load in the washer and the unit simply isn't strong enough to get it going, or more likely the clutch mechanism/gearbox is malfunctioning. They use a clutch mechanism to allow the motor to run at a constant speed while the basket can start rotating slowly and pick up speed with time. If this clutch mechanism or gearbox isn't performing properly, the basket won't spin. It's not your motor or safety circuit since the basket will turn if given a little push.
Mar 10, 2008 | Washing Machines
Washing Machines Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
