Question about Sewing Machines
Doing straight stitching, everything is fine for 2 or 3 inches, and then I get a very long stitch.
The long stitch is quarter or half inch long, as if for 4 or 5 stitches the lower thread failed to pick up to make a stitch.- I'm wondering what the cause of this issue is. Thank you. julie
  • Sewing Machines Expert
  • 468 Answers
The timing may be out and the machine may need a service to correct this.
Posted on Apr 30, 2015
What size needles for bulky/12py wool?
It depends on your project. You need the size needle that will give you the stitch width and stitch length called for in the pattern. The pattern calls for a specific gauge, so you'll need to try out different needles, knitting a swatch on each needle size, and counting the number of stitches across and down to match the pattern specification. Does the pattern not give you a needle size? Needles come in either straight or circular in all various sizes as long as you stay within the same brand needle. (Needle brands differ from one to another, so try to stay within only one brand.) So a straight needle size 6 should be the same size as a circular needle size 6 (of the same brand).
However, although it may call for a specific size needle, you will still need to knit some test swatches because knitters usually knit looser or tighter, so one needs to adjust the needle size to accommodate those differences, ie someone who knits tightly may get 8 stitches to an inch, but a loose knitter may get only 6 stitches. But if the pattern says to cast on 48 stitches in for row 1, that means the 8 stitch gauge will yield a project that measures 6 inches wide (48/8=6). But a 6 stitch gauge will yield a project of 8 inches wide (48/6=8). The result would be one project will be 2 inches wider than the other.
But that is only half of the problem as you would still need to measure the number of rows per inch to get the length of the project. If there are more rows to the inch than specified, a garment with say an armhole that may be too small. If there are fewer rows to an inch, the result may be an armhole that is way to big.
Be very careful with your pattern and yarn selection. You will be much more successful if you stick to the number ply and yarn weight specified in the pattern, ie if the pattern calls for 2-ply 2 oz yarn, there may be some particularly difficult issues with substituting a 4-ply 4 oz. yarn. You may end up with a project that will not fit. For instance, you wouldn't want to use a heavier yarn to knit a baby garment. Baby garments usually call for baby yarn which is a specific ply and weight.
How to Measure Your Gauge in Knitting
earthguild com
3 Things You Might Not Know About Knitting Gauge Adjustment
Oct 30, 2016 | Sewing Machines
Make a rolled hem
If you want it done entirely by machine you will need a special attachment. You'd have to check the make and model of your machine to find out if there is an attachment available from the maker. If not, there are some companies that make general attachments, and they'll list what machines these will fit. Check online sewing supply houses for this kind of thing.
You can also make one by hand. Any decent sewing book would tell you how. Usually you sew a straight stitch along the hem, using quite small stitches. Trim hem to a quarter inch from the stitch line. Crease the fabric or press it along the stitch line to the inside. Anchor your hand thread, then take a short stitch right along the stitch line. Next catch one thread of the fabric a quarter inch above the stitch line. It's just a basic running stitch, back and forth. Every few stitches, gently snug up the thread, which will roll the hem over. The finer the fabric, the smaller the stitches you take where they'll show should be.
There are some images that will help, if you enter the following search terms in google, you will see several pictures. Type the words," Illustrations for how to make a rolled hem by hand ? " and you will get a load of ideas.
Oct 09, 2014 | Sewing Machines
How do I set the basting stitch length? when I try, it just beeps at me.
A BASTING STITCH IS ONLY A LONG STRAIGHT STITCH. THE NUMBER THAT IS LOWER IS A LONGER STITCH (FEWER STITCHES PER INCH). YOU WERE LIKELY MOVING YOUR NUMBER HIGHER. AFTER YOU GOT TO A CERTAIN NUMBER IT NO LONGER QUALIFIES AS A BASTING STITCH BUT A STRAIGHT STITCH. USE A LOWER NUMBER AND IT WILL LIKELY TO STOP THE BEEPING.
Sep 30, 2014 | PfaFF Sewing Machines
Singer sewing machine is stitching every half inch how to fix this
I had a singer machine that had a basting stitch that was like that. Make sure that you have chosen regular straight stitch.
Feb 12, 2013 | Singer 2639
Singer 8770 beeps twice then stops stitching
do you have a manual?
try a new needle
adjust the top tension
try rethreading the machine top & bobbin
May 16, 2012 | Singer Curvy 8770 Electronic Sewing...
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Hello. I hope u can help me. I cannot get my stitching tight? If I pull the thread it comes right out. Thanks Jodie
You need to backstitch over the beginning and end of your stitching, Jodie. When you start out, manually turn the wheel to put the needle into the fabric. Push the foot pedal to stitch forward a little. Now, reverse over those stitches to nearly where you started stitching. Use the foot pedal to go forward again, stitch to where you want to end. Reverse again, just a 1/4 inch or so. Then take the fabric out and cut your stitching.
This backstitching keeps your thread from pulling straight out. You should always use it with straight stitches and general zigzag stitches. Don't use it with decorative or embroidery stitches, though, as it mars the appearance of them. But if you're doing any type of topstitching that uses straight stitches, backstitch in the area that will be in the seam allowance, ever so slightly, or your top stitching will pull out, too.
Hope that helps!
May 19, 2011 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
