Question about Philips Televison & Video
What is the 5v power supply on my Philips TV?
3 Suggested Answers
gopakumarg43
  • 75591 Answers
SOURCE: Power supply problem
The power supply board is faulty. Should be replaced. What is the brand name to your TV? Provide more details please. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
Posted on Apr 30, 2013
  • 7 Answers
SOURCE: vizio Tv stuck on splash screen
It may be Broken, Or Its power supply Might only have enough to do the splash screen but not continue
Posted on Aug 26, 2013
I misplaced the power adapter for my mxq pro help
Android TV Box Power Supply Adapter 5V 2A AC/DC For M8S/M8S PRO/MXQ/MXQ PRO
5 VOLTS DC @ 2 AMPS... 95% sure it's a 3.5mm jack!
eBay:
Android TV Box Power Supply Adapter 5V 2A AC DC For M8S M8S PRO MXQ MXQ...
Dec 17, 2017 | Power Computers & Internet
What are the volts outputs of power supply?
Hi Jhun,
As a general rule as soon as you switch on the TV, the power supply must produce stand by (sb) 5V or 3.5V as per the TV's design. Next, when you give power on command, the power supply should produce power on 5V or 3.5V, 12V and 24V or some other voltages as per the TV's design. All this is printed on the power supply pcb in most TV sets. I hope this helps.
Aug 03, 2015 | Televison & Video
Main Board with 5v in short. How do I detect the failure component ?
Contact Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en They might have a fast answer for this.
Mar 22, 2015 | Philips HTR-5000 Theater System
My philips lcd tv does not turn on, it just blinks for 5 times and then nothing... what could be the problem?
good day if the tv won't power up then just only a blinking light from the indicator, you will need to check the power supply first. you can apply the visual checking usually bulging capacitors at the secondary filter capacitor of the power supply they are leak which need replacement. sample of bulged capacitor en.wikipedia.org/wiki/Capacitor_plague . you can find replacement at www.digikey.com. now after you replaced defective capacitors turn on the tv unit then check all the out put voltage if normal the 5v stand by. 5v switched, 12v, and 24v for inverter ballast now if those voltage are stable i'm pretty sure your tv unit will working fine.
Aug 19, 2011 | Televison & Video
Daytek DT-3220 power problem
I have just fixed the power problem on my Daytek 3220. It looks like the Bentek BP-200AD power supply is used in other cheap brand TV's besides this Daytek : Hyundai HLT 3280, Jwin JV-DTV3212.
At first, my TV would just lose the backlight, while the video and sound would still work fine. Power cycling the tv would correct the issue, but would repeat the problem after shorter periods of time.
More recently, I've started losing the video and audio, shortly after backlight.
I have checked all the caps on the outputs and they all tested ok, using capacity and ESR meter (surprisingly enough) and no bulging either.
This power supply outputs 3 voltages : 5V, 12V and 24V, with a stand-by control pin on the 5V connector (0V for TV on and 5v for tv off).
I have got the readings after the power died:
5v out= 5v--ok
12vout=0.72v not ok
24vout=0.0v not ok
One of the transformers was squealing quite annoying while tv worked, but started modulating the squeal a couple of seconds before power died.
The culprit : one small electrolytic capacitor marked C19 on both sides of the board, with a value of 47uF/35v. I have replaced it a 56uF/50v and the TV started working as new (and of course no more squealing either).
Use a good quality cap when replacing C19. A 50v rated one would be a better choice than the original 35v and make sure it is also rated for 105 degrees Celsius, since it is very close to one of the heatsinks.
As always the DISCLAIMER: take all the precautions to avoid electrocution. Disconnect the TV from power, allow a few minutes for the big 400Volt capacitors to discharge completely, before handling and working on the power supply.
Feb 13, 2010 | Televison & Video
The TV will not come on, it acts like there is no power. I have the back off the TV, how can I troubleshoot the power supply? I do not see any test points
Look at the connectors on the dc output side for the 5vdc standby voltage, most good power supply maker will label the voltages on the connector pins. You should hook up the TV while you are working it through the GFCI outlet because of high voltage is present. Look for bad capacitors, burnt parts, poor solder joints. The 5V stnadby is needed for other circuits to work, so start with that first.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Philips Magnavox 42MF521D/37 Television
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Philips 42PF5321D/37 Plasma No Picture Six Red LED Flashes
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Mar 12, 2017 | Philips Televison & Video
Berndulay@yahoo.com
Accroding to your model number:(KV-...) In sony tv units power supply porblems is very low unless a power surge.
You have to check these things.
1. Stand by 5V available or not
2.If stand by 5V available press power and check B+ is getting or not
3.If B+ available check Horzontal oscillation
4.May be H-out transistor or video amplifier is bad.
Oct 14, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
