Need a powersupply ba4at0f01021a
Is there another supply that will work with this tv
Sony tv KDF 50E210 rear screen projector tv since replacing lamp will not turn back on goes green then red flashing 1-2 pause 1-2 pause 1-2 pause etc will not engage fan supply.Have cleaned thoroughly ,no...
Lamp ballast is not work well ,It need to be repaired
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 16, 2013 | Sony Televison & Video
Tv made a pop noise followed by a long hiss and the picture wnt off, sound is okay though.
Related to a capacitor blowing up on your powersupply that supplies the voltage for the backlight inverter. The backlight inverter lights the tv. The power supply will need to be repaired so it can supply the 24v needed for the backlight inverter to work properly.
Thank you and best of luck!~
May 26, 2011 | Televison & Video
Our Polaroid FLM 3232 has worked for four years and now all of the sudden it won't turn on....seems to be no power supply...the red standby light is not illuminated....please help we love this tv!
I hate to say it, but it is prob the main board that went bad. (the board where all the inputs get plugged into) It is possible that it might be the power supply. One thing to check is to make sure you have 25v coming from the powersupply board to the connectors that plug into the main board. If you do have 24-25v than you will have to replace the main board. If not than the powersupply.
Dec 26, 2010 | Polaroid FLM-3232 Television
TV power button comes on to turn tv on & goes right back off but nothing on screen & no sound
Hello
This could be alot of things but I tend to lean towards a power supply issue. The short story is that when your tv starts up, it checks alot of things to make sure they are correct. If one of the voltages is off, then the tv protects itself and turns back off. In my experience when they turn back off its almost always power supply issues. It could be a card pulling down the powersupply, or the neat gizmo that powers the light. But I have not seen alot of that.
Generally if its not a power supply fault that the tv just cant tolerate it will flash a code at ya. Blink blink (Im messed up and here is the number of the fault) Blink blink BLINK!
I wish I had better news, however powersupplys are one of the cheaper and easier things to fix.
Best of luck
Nov 25, 2010 | Mitsubishi CS-32307 32" TV
When turned on ,nothing comes up,no picture
there is a connection between the inverter and the powersupply. on this connector there should be a line that supplies 24 volts. if you are getting that 24 volts on a volt meter the you are most definatly looking at inveters. if you dont powersupply. just a warning if you have 24 volts and the inverter doesnt work you need a new lcd panel, which is not worth buying if you can find one
May 11, 2010 | Vizio GV47LF Television
Powersupply Faulty
Check for short circuit on your Powersupply. If you can isolate it, much better. check the voltage regulator if it supplies power to the system. better still check the regulator itself.
Jul 10, 2009 | Televison & Video
TV wont turn on blinking power light
The powersupply is going bad. If it's within a year old it's probably under warranty, if not look on ebay for "aquos lc32g4u power supply" or "aquos lc32g4u parts" and then replace the powersupply.
Dec 14, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Insignia TV Powersupply
Click here to find parts for your LCD. I can also repair your power supply.
You can write an email to jah2mil@hotmail.com for more info.
Oct 20, 2008 | Televison & Video
Trutech powersupply, I need an IC
Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Aug 05, 2008 | TruTech PLV1615T 15 in. LCD Television
42" Plazma Dead
Check the fuse on the powersupply & non-powersupply area, this was very common problem like the one you have experience..
`micro
Jun 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
