Question about Samsung SyncMaster 226BW
The Samsung SyncMaster 226BW monitor have power and get recognized by the computer, but still no image appear on the screen. How do I fix this?
Using the normal vga connection to the PC. nothing showing on the screen and the power batton's LED is on.
  • 1684 Answers
SOURCE: Flicker, even when no signal cable
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
  • 788 Answers
SOURCE: connected power but hardly see the image all dark
Sorry about your Monitor problems.
I have worked on several of these monitors and yours sounds like the BackLight has gone for a walk. ( NG ).
If you are experienced in the disassembly and the electronic component repair, let me know, and I will walk you thru the repair steps.
The backLight for your unit, can be ordered on EBay or direct from Samsung.
Posted on Jul 08, 2009
tolexade
  • 81 Answers
SOURCE: Samsung syncmaster 551v
you dont have problem with your monitor, check your cpu very well am very sure you have problems with your system board
Posted on Jul 17, 2009
dhecom
  • 233 Answers
SOURCE: samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The solution is open your look for the LCD monitor power supply module (which have PCB connector to the AC power), on that board look for capacitors, now look for broken one which upper part is bloated, like the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
Posted on Jan 22, 2010
budmrtn
  • 11361 Answers
SOURCE: The monitor powers up and the analog icon blinks
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Posted on Mar 29, 2010
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
Samsung syncmaster 226BW fails to wake up.
If pc not sending it to "sleep mode" or "power save" mode, then unit may need help of electronics technician to investigate the "internal switch-mode-power-supply" that may be going into "shutdown" mode after it detects a "fault condition" with itself or onother circuit.
12fixlouie
Sep 20, 2010 | Samsung SyncMaster 226CW 22" Monitor
My SamSung SyncMaster 226BW flashes about 2 times a second for about 30 seconds when first turned on. The background (computer) image is present, but dim. After about 30 seconds it appears normal. It does...
The first place to check will be the caps in the power supply, look for bulging top/bottom seal. See example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 10, 2010 | Computers & Internet
Samsung syncmaster 226BW no backlight
Look for any bulging capacitors, instead of a flat top they will look "pregnant".
If you see any of those then replace them with capacitors of the same UF rating and the voltage needs to be either the same or higher.
If you dont see any bulging capacitors or burnt parts, then its got be the LCD at that point thats not staying on and the cost to replace the LCD is as much if not more then to just get another monitor.
Aug 27, 2009 | Samsung 226BW Monitor
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
Problem with Samsung SyncMaster 226BW
Click the top button on the side of the monitor to open the monitor's settings. In the "Picture" Settings, scroll down to "MagicBright" and open those settings. Chances are you have it set to "Dynamic Contrast". Switch that up to any of the other settings and then it won't try to adjust the gamma based on what is on the screen.
Hope this helps, I struggled with the same problem for quite a while until I found this setting.
Feb 19, 2009 | Samsung 226BW Monitor
Syncmaster 226bw goes black
i think u have a problem with ur display,please contact ur service centre immediately to fix it.
Aug 16, 2008 | Gateway FPD2275W LCD Monitor
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
Jun 23, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Window screen problem
I'm guessing you may need to download the proper software and drivers for this monitor. Have you always had this problem and now want to change it? Try this website: http://static.tigerdirect.com/pdf/samsung-206bw-manual.pdf
Jun 21, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 226BW Logo
52 people viewed this question
Top Samsung Retail Supplies Experts
Patrick Tinashe...
john smith
Are you a Samsung Retail Supply Expert? Answer questions, earn points and help others
