Question about Grilling
Way is my machine using to much propane
Uses a tank of propane in a week and haft.
  • 494 Answers
Are you smelling gas around the grill or tank? Fill a spray bottle with soapy water, slowly turn on the tank valve, and check for leaks at the tank valve, hose, regulator, as well as each gas valve (remove the knobs first). If no smell or leak is found, check your burners to see if they are burning mostly blue. If they are lazy yellow, they could be dirty or partially clogged and require cleaning; or possibly rusted through and need replaced.. If you do have blue flames, consider turning down the burners for a reduced flame and see if that helps.
Posted on May 02, 2015
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
Gas grill no flow of gas
Jul 14, 2014 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Won't run on electric some times. uses full tank
Hello,Well sounds like you got a real problem. These fridges don't use very much propane when in use,you may have a major leak in the line somewhere or connection? If you do have a leak please do not use repair as soon as possible.And for the electrical part you may have a loose connection where the fridge plugs into the outlet located behind the fridge located outside your camper,hope this helps
Sep 22, 2011 | Dometic RM2652 Refrigerator
We have a Sunjoy table top patio heater without the propane tank that fits inside. The heater number is L-PH007PSS-B. Where can we order a replacement tank from? Thank you. Pat
Pat, the model you have uses a 1 Lb tank, that can purchased at any hardware store or home center. It's the same size tank that Coleman stoves use. They run anywhere for $4,00 -$6.00.Unfortunately, you can't order full tanks, because of Hazmat issues in shipping to you.
Hope this helped you. Please let me know.
Jul 05, 2011 | Heating & Cooling
Have a Rinnai XR26 . For a 2 person house and gas for water heating and cooking hob only, we use x1 45kg bottle of LPG every 3-4 weeks. 4 days of the week we are both away at work all day so it us just...
I'd really like to help you. But, you can not measure propane gas in kilograms. That's measure of weight, not liquid. The weight of the bottle, doesn't determine the liquid amount that the bottle or tank holds when it's 85% full.. Since Propane Gas is a liquid, I would need to know how many liters the bottle/ tank holds, to determine what your consumption is.
Please advise. Cheers...
Jun 26, 2011 | Heating & Cooling
Machine will not ignite...ignitor clicks...new battery...new fuel filter...new propane tank...cleaned machine...help!
is the propane hooked up correctly with the valve turned on, and verify that there is propane inside the tank as I have purchased new tanks that were empty. Hope this helps Tim
May 15, 2011 | Garden
When I light my grill I get a very weak flame in fact it blows out. I have a full tank and I could use your help. Thanks
If this grill uses the small propane tanks, the regulator in the part that attaches to the tank could be bad.
Nov 29, 2009 | Weber Gas Go-Anywhere Grill
Got a travel camper for free they told me everything works has ac, fridge, stove, water heater ect. but never owning one before I dont know how it works. I now theres two propane tanks on the side dont...
have tanks tested and certified if need be install back on camper screw on hoses to tanks open valves spray soap and water on fittings make sure no bubles if bubbles repair leaks spray all fittings were propane fittings in system tighten to check for small leaks if no leaks proceed to lighting pilot lites on heater-hot water tank-stove(is in oven and possibly under burners)and fridge on back of fridge(everything should have instructions on it)turn knobs to pilot push in knob lite hold for a few minute till pilot stays lit then turn to on position-may haft to hold pilot for a while to get propane thru all pipes start with unit farthest from tank.(also if stove top doesnt have pilot you can get all air out by turn on burner till it lites-ac should work on 110vac may haft to remove top cover and clean fins with degreaser and hose-water system i will add a cup of bleach and ciculate thru system let sit then flush out entire water system(to prime waterpump hook up hose to side of camper turn on rack all valves turn off all valves pump should be primed)should have 12v deep cycle i use a semi truck battery same thing alot cheaper and heavy duty i buy at battery store for 30dollars instead of a hundred at walmart and last longer-keep top tarped as uv rays will dry out seams(if leaks i goto place that sells semi-trailer parts and buy vulcam one gallon $50.00 a gallon and paint on all seams on top-vents seams etc anywere it could possibly leak)always keep tarped and tarp will take uv rays and weather not roof tarps are cheap compared to leaks)make sure in fall you winterize keep battery inside house were warm drain all water out of system should be valve at low spot if not blow out system if you get all water out of entire system shouldnt need rv antifreeze stuff has terrible taste and hard to flush out!!!dont set camper on ground set on pallets or something instead of straight on ground!!!!goto library get book on rv's learn as much as you can and you will be prepared and wont ruin a good camping trip because of equipment failure!!!Best of Luck to You!!!!!amtnng@gmail.com
Jun 30, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
How to use propane tank?
leave the propane tank on and install a gas ball valve after the tank. you can see that the gas is on by the position of the valve,
Aug 16, 2008 | King Kooker Grilling
Grilling Logo
192 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
