After the operation of the rinse the machine changed to spin and the time is not changing from the last 11 minutes and the machine is just rotating like rinse but not spinning
  • Washing Mach... Master
  • 5,323 Answers
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
after the operation of the rinse the machine chang - after-operation-rinse-machine-changed-fgv1ctnzjgewe3hu2qpqylbk-3-0.jpg
Posted on May 08, 2015
SOURCE: No Spin
F02 means its not draining, see if your hose out is clogged.
Posted on Sep 16, 2008
aborcass
  • 2651 Answers
SOURCE: washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Posted on Feb 23, 2009
  • 10865 Answers
SOURCE: O.K. this is really odd. My machine is 1.5 years
Problem is that the timer needs to be replaced. Call around and get a price and then decide.
Posted on Mar 20, 2009
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
  • 52 Answers
SOURCE: does not drain and spin
It sounds as if you have a defective timer control. Try operating the washer on a different cycle, if it spins on these cycles the mechanical workings are fine it's an electrical switching problem in the timer.
Posted on Sep 17, 2009
Water is blocked inside the machine
The warning buzzer should have sounded after 15 minutes with a warning code of "5E" on the display, if the machine has recognized the fault. Check the drain hose height reaches 90-100 cm as stated in the manual. Set the machine to spin only cycle and minimum water level:-
Press the FUNCTION button four times.
Press the START/HOLD button once.
Spin drying goes on for 11 minutes.
(When the FUNCTION button is pressed during spinning,
the spin time can be changed to from 1 to 7 minutes.)
If this doesn't work try repeating spin and reducing the height of the drain pipe gradually 10cm at a time.
Operation manual available here: http://www.nodevice.com/download/user_manual/samsung+wa80b2s.html
Good Luck.
Jun 08, 2014 | Samsung Washing Machines
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
My whirlpool top loader agitator machine will not spin when the cycle starts
check underneath the washer for a relay called wigwag. It changes the gear in transmition which allows the spin cycle and rinse to spin. Very easy fix if this is the problem, About $15.00 part and 10 minute change
Mar 09, 2010 | Washing Machines
F07 occurs at end of first rinse cycle
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
11 minutes timer flashing, machine locked
unplug washer over night. plug in try drain and spin, if it works after finish try to restart. an 11 minute stall is likely error code f / 11 or dl code starts intermittently then goes out possible ccu board under top at rear
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Indesit wd12s washer dryer
after all you have checked out I think it must be a programmer fault. Sorry I dont know how to check it out for sure
Oct 24, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
