Question about LG Televison & Video
I have a LG model 26LH1DC1 -UB,when I press the power button a green light comes on and blinks several times and then it goes to read
Slinteriors
  • 8617 Answers
SOURCE: Powers off
do you hear any sounds what so ever? Clicks or anything when you press power.
Posted on Jun 06, 2008
  • 38 Answers
SOURCE: powering on my tv
Dear smmmobil,
The problem lies with the SMPS (switch mode power supply ) of your TV. The smps board needs to be replaced.
ramesh22
Posted on Jun 15, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
freetek
  • 5568 Answers
SOURCE: Lamp light blinking, Power Light blinking, TV off
Your description of the problem points to a power supply in the process of failing.
If it was mine, I would leave the set unplugged overnight, remove the back panel of the set, locate the power supply (likely on a separate board related to the incoming AC cable and will have larger components on it), look for an assembly number (often on a printed label), contact the manufacturer's service company and inquire about replacement or repair cost.
When you plug it back in, note whether it behaves normally at first turn-on. If is does, this tends to support the suspicion of a failing power supply since some of the passive components in it have had a chance to recover before weakening again.
Modern supplies are a good bit more efficient than 'linear' supplies of yore but are far more complex and much more dependent on quality of components.
Posted on Jul 28, 2009
SD Tech
  • 14553 Answers
SOURCE: mitsubishi vs-60705 grenn power button goes on
It is an error code for short protection---the most common cause for this is one or both of the pico fuses that protect the convergence IC's are bad--set will detect no voltage and instantly shut off.
I do this here for free so if this has been helpful give me a vote here. if you have questions or need help:
etower.766@netzero.net
Posted on Aug 22, 2009
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
My power source is gone out where can i get it fix and how much
Do the self check this 2001 model (what is model number?)
When green light comes on and goes off on the front of the set press and hold both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what you find.
SD TECH
Mar 05, 2012 | Mitsubishi Televison & Video
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Tv wont turn on green light comes on then goes right out could there be a blown bulb
Do the self check this model has: WHEN GREEN LIGHT COMES ON AND THEN GOES OUT:
On front of set press and hold both the menu and input (device) buttons at the same time and hold both for at least 5 seconds and release both.
Watch the power light, it will blink a two digit error code like: 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find with a comment here and I will tell you what it means.
SD TECH
Feb 02, 2011 | Mitsubishi WS-55613 55" Rear Projection...
Green powere lights comes on and goes off.
Do the self check this set has, when green light comes on and goes off, on front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and repeat it several times.
Let me know what error code you get and I will tell you what it means.
SD TECH
Jan 17, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi vs50705 turn power on green button comes on then it shuts off quickly
TRY the self check here, this model may have it.
When green light comes on and goes off, on front of set press and hold both the menu and input buttons for at least five seconds and release both buttons.
Watch the power light, if it has the self check feature it will blink a two digit error code.
The most common is two blinks, two blinks, a pause and then repeat several times.
Let me know if find a error code.
SD TECH
Jan 16, 2011 | Mitsubishi VS-50607 50" Rear Projection...
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Set comes on then turns it self off
do the self check this model has:
when green light comes on (power) and then goes off:
On the front of the set press and hold both the menu and input (device) buttons at the same time for at least five seconds and then release both.
The power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and then repeat it several more times.
Let me know with a comment here and I will tell you what it means.
SD TECH
Nov 23, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Televison & Video Logo
41 people viewed this question
Computer Repairing
Computer Repairing
