Question about Motorola CLS 1410 (4 Channels) 2-Way Radio
There is a loud ringing noise on all radios. Help
  • Official Brand Answer
  • 3,100 Answers
Gerald-
Visit CLS1410 Two way Radio or Get Support for assistance from Motorola Solutions.
Mark
Motorola Mobility Support
Posted on Apr 30, 2015
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ‎1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES · 2008 Lancer GTS no start please ... 2011 lancer no sound · Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot · Very loud noise on Lancer ES 2008 ...
Dec 03, 2015 | 2008 Mitsubishi Lancer GTS CVT Sedan
Loud noise from subs amp is grounded well
Check the output of the amplifier with the input connections disconnected. Does the sound go away??
If it does, then connect each input one at a time and see what happens. If the sound appears, then do the following:
The ground connection on RCA connectors don't always make a good electrical connection. This is the outside ring. If the RCA connector goes in easily, the the outside ring should be compressed slightly to garantee a snug fit. Do all of the RCA connectors, at the amplifier end and at the radio end.
It could be the way that the amplifier was installed. the ground lead should run directly to the battery NEGATIVE terminal. This will greatly reduce noise produced by other equipment.
Jan 31, 2015 | Car Audio & Video
Ringing of the ears
It is a medical condition called "tinnitus". It can be caused by listening to loud music or noises, but it can just happen without obvious cause. Don't wear headphones loud and don't go to loud concerts, go to an ear specialist and have it checked out to rule out any pathology. Often it comes and goes by itself, but if it has no pathalogical reason then there is no cure other than masking it with other noise like the tv or radio. BTA About tinnitus
Jun 01, 2014 | Health & Beauty
Loud stereo noise comes though the speakers regardless of volume level
RAP, delete all RAP , crapp
cured.
id pull fuse to radio and radio amp
be ready to loose radio codes. (RTM) on that first.
Feb 21, 2014 | 2009 Toyota Corolla
My radio transmitts fine. But when I key another CB, my CB makes a loud noise as it trys to receive. Plz help.
hello what do you mean by a loud noise ,how close are you when you key another radio please try and give more info i will help you the best i can
Jan 09, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
MWhere is the noise elimantor for the radio sometimes when I am driving and hit a bump the sound of the engine comes into the radio speakers I have to shut the radio off it is so loud
Hello! Engine noise is removed via shielded cable...The shields are then grounded to the chassis...They are loose or corroded at the contact point...Rather than hunt for its location...You can ground it to the floor pan...If your vehicle is equipped with the Premium sound system...Pins #3 and #7 on the 8 pin radio connector are the shields...Splice two runs of 10 gauge Green wire to each of these pins and connect both ends to a ring connector...Solder connections...Bolt ring connector to the floor pan...Insure contact point is bare metal...
Guru..............Saailer
Aug 27, 2010 | 2003 Ford Mustang
What would cause a loud roaring in the back seat of my 2001 Monte Carlo as I am driving?
That roaring noise should be a wheel bearing. Jack up the rear wheels and spin the tires by hand. You can hear a grinding noise if the noise inside the car is as load as you state.. The only other noise that will be like that is the differental gears inside the drive axle
Mar 28, 2010 | Chevrolet Impala Cars & Trucks
Frigidaire front load washer LTF2940FE0 wont drain
That loud noise is most likely debris bouncing around inside your water pump. Pull the 2 hoses off and try removing it by hand, or un-bolt it from the floor pan and tip it sideways to shake any small objects out. I found a mans wedding ring in there once.
Mar 18, 2010 | Frigidaire ATF6000ES Front Load Washer
'93 prelude. Starts when it wants to.
i think it could be your Bendix drive. it is the part of the starter that comes out and touches your ring gear. sometimes it becomes worn out and would not catch the teeth of the ring gear right away and it would create this loud grinding noise.
on the other hand, if the Bendix drive is still ok, then there is a probability that your ring gear is the one which has a problem.
good luck,
tnx 4 using fixya, keep me posted,
drcool
Sep 11, 2008 | 1993 Honda Prelude
Motorola CLS 1410 (4 Channels) 2-Way Radio Logo
120 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
