Question about Oakley MP3 & Digital Media Players
Glasses are broken
Hi dropped my thumps and the earpiece has broken of the wire inside is snapped
0 characters
1 Points
How do you load nsongs
Loading songs is very simple. Connect the glasses to your computer using the usb cable. It should show up like an external drive...simple drag and drop your songs from your computer to the glasses.
Jun 06, 2014 | Oakley Thump MP3 Player
Oakley thump pro 05-175
From what I understand you are charging with the USB cable. Did you leave it in at least for 3 hours (the PC also has to be on and not in standy or hibernation mode)? Do the glasses charge with the wall charger?
Dec 21, 2007 | Oakley Thump 2 MP3 Player
Speaker broken
Jul 21, 2012 | Oakley Thump MP3 Player
Thump pro speaker
16mm. 16ohm 5.4mm high and so far impossible to find. You will have to find a donor pair of glasses
Mar 07, 2012 | Oakley Thump 2 MP3 Player
Just got some oakley thump 2. Only one side has music playing from it. The right side doesn't work/no sounds coming out. Anything I can do?
If one speaker is not working, then the chances are its either the Speaker itself or one of the two wires. Speakers and replacement wires with the JST connector are now available. If the glasses power up, make the THUMP sound and power down Its the battery, same if they only last a short time. Most faults are Battery, Sweat Damage, or damaged ribbon cable.
Apr 29, 2011 | Oakley Thump 2 MP3 Player
My oakley thump 128 sunglasses have been malfunctioning on the right side earpieace ever since i got them. now they do not work on that side at all. they are my prize possesion,and im crushed.
I have a pair of these Thump128's. Brand new demo set, but never used. The lens is broken on it, but since you have the lenses and a malfunctioning earpiece, maybe you would be interested
Email me at
Jul 04, 2009 | Oakley Thump MP3 Player
Oakley reset
While pressing and holding the Play / Pause button, press the Previous
Song / Rewind button once
Apr 25, 2009 | Oakley Thump 2 MP3 Player
How to delete songs
1. Just go to computer from the start menu
2. Then plug in your oakly glasses with a usb cable it shouldve come with your glasses
3. You should see the oakly glasses come up on your computer
4. Then just click on your oakly glasses that come up on your computer
5. you should see your music files
6. right click them, you should see the delete option
7. the next step is kinda obvious click the delete option
8. TADA! it should work now
Dec 29, 2008 | Oakley Thump 2 MP3 Player
Can't download music - says device full
Easy fix, just did it. Talked to Oakley customer service. If your using a MAC when you delete the files off the Thump Pro, you must empty the trash. For some reason, with MAC the files are masked into the trash, so unless you empty nothing is going to change. Mine worked perfectly when I did this, after days of frustration. Good luck.
Dec 14, 2008 | Oakley Thump 2 MP3 Player
Will charge wont turn on
Try reseting by holding and pressing the power button of your player for 1min.It should turn on.
Aug 26, 2008 | Oakley Thump MP3 Player
MP3 & Digital Media Players Logo
16 people viewed this question
Top Oakley MP3 & Digital Media Players Experts
aliasger yq
mac colar
Are you an Oakley MP3 and Digital Media Player Expert? Answer questions, earn points and help others
