Question about Garden
What size is the drive belt - Garden
    Top Expert:
  • Garden Master
  • 50,583 Answers
Take the old one into a shop that sells belts and they will match it up
Posted on May 01, 2015
  • Bill Boyd May 01, 2015
    belt sizes are printed on the back of the belt
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
How to correct drive belt deflection on 2510 mule 620
Go next size smaller on drive belt and recheck, or next size up on band width.
Feb 22, 2014 | Cars & Trucks
What size belts for varidrive
If you're talking about a main drive belt (the one that turns [drives] the rear wheel), drive belts are usually measures as width (how wide) and number of "teeth".
An example is here:
http://www.jpcycles.com/product/600-0541
this belt is 1-1/8" wide, by 128 teeth.
Dec 27, 2013 | 2007 Vespa GTV 250 ie
What size Serpentine belt does a prizm need and a oldmobile alero
go to any auto parts stores they can look up info in parts reference in computer and find your drive belt belts size.all you need to know is your engine size and if your engine has airconditioner or non airconditioners which drive belt will be shorter.
May 25, 2011 | Chevrolet Prizm Cars & Trucks
Hi I need a new serpentine belt put on my 1999 alero however I do not know how many grids the belt is supposed to have can you help me please
drive belt has 6 ribs.to buy a new belt take old drive belt with you you so you will get the right size belt.tell the auto parts store the year and model type car.tell them your engine size.and they will find the belt size you need.
Apr 25, 2011 | 1999 Oldsmobile Alero
Ride on mower
Jackie
MTD Part number 754-04001A is the LOWER drive belt
MTD Part number 754-04002 is the UPPER drive belt
MTD Part number 754-0329A is the BLADE drive belt
They do not list them by size, only by part number because they are specially made for lawn mower use and generally not a "common" size
Oct 12, 2009 | Garden
What is the size of the drive belt?
I would suggest removing the old drive belt and taking it with you to me matched up at the parts store. Depending on the size of the mower the drive belts can be different sizes. For Instance, I have a Murray 40" cut. The drive belt for the particular mower is 94". But if you have a larger mower the drive belt can be larger.
Aug 22, 2009 | Garden
I have an older Harmony II HRT 215. The drive
the best thing to do is take the model number and order a belt from honda which will be the right size and thickness
Aug 09, 2009 | Garden
What size A/C belt does a Mazda 3 use?
It is Unusual to have a Belt "Size" As the Belt Size is determined by the Application, Why a Parts store Cant Get this Info By Use of > Year-Make-Modle-Engine Size is VERY Unusual. Try Another Parts Store, or try this Info.
NOTE: You Did Not Say Engine SIZE so this is for the 2.3L Engine
This Info is for the " 2.3L " Engine
Parts Information Part OEM Part Price Drive Belt Serpentine Belt Manual Trans L373159099U $26.99 Notes Auto Trans L37215909A9U $26.99 Notes AC Belt LF5015908 $19.95 Notes Labor Skill
Level
Mfg.
Warranty
Standard Drive Belt Replace AC Belt C 0.0 0.5 Notes Serpentine Belt C 0.4 0.6 Notes
Jul 21, 2009 | 2005 Mazda 3
Waterpump belt
you have a serpentine belt, which is one belt drives all, so the routing of this belt is very specific also it matters whether or not you have a/c. Locate your belt routing chart under the hood before beginning. There is a tensioner pulley mounted on a spring arm, the spring arm should have a square drive hole in it, either 3/8" or 1/2" drive size you will need a ratchet of the proper size to insert into this square hole. Using the ratchet move the tension arm (away from belt) to loosen the belt and remove, route and install the new belt and move tensioner the same way place the belt over it and release. Hope this helps, let me know
May 16, 2009 | 2000 Ford Contour
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
