Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Not washing very well, on investigation the lower arm is not rotating freely (it does turn but not spin). Cannot figure out how to remove arm to investigate further
  • 22 Answers
You can find a manual online. Get a copy & see if they tell you how to remove the arm.
Not sure of the distinction between turning & spinning you cite.
Check that some food item has not become lodged and is binding the arm. Empty the washer, remove the rack & invert on a counter to get optimum access to the arm. The problem may become obvious.
Good Luck
Pete
Posted on Sep 29, 2015
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Bottom water sprayer not spining
If the dishwasher won't clean dishes, check the lower wash arm assembly. If the lower wash arm isn't getting water, all of the dishes in the lower rack will come out dirty. Check to be sure the lower wash arm assembly spins freely. Also check to be sure the little holes in the lower wash arm aren't clogged or blocked.
Aug 28, 2014 | LG LDF6810ST Stainless Steel Built-in...
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
Neither the upper or lower wash arms spin.
Circulation pump might be faulty. or spray arms are blocked. remove spray arms and clean them and try it again.
Mar 15, 2014 | KitchenAid 24 in. KUDP01DL Built-in...
My dinner plate stops the arm rotating, why? model fdud4812
Both upper and lower washing arms operate on the water pressure and angle of water flowing thru them.
Pressure provided by water pump.
Just about anything that contacts the rotating arm can stop it.
Best thing to do is re-arrange items in dishwasher so that arms can spin freely.
One can always spin washing arms by hand to ensure proper clearance.
Hope this helps...
Jul 30, 2011 | Hotpoint Dishwashers
The bottom washer arm does not turn or squirt water
Hi Matt.
The lower housing underneath the lower wash arm may still have something blocking the water passages.
If the spray arm is clean and it freely rotates try lightly pressing down on the wash arm and then rotate it. Your checking to see that when water is applied to the spray arm it forces the arm down against the lower housing tower and hopefully does not lock up. If it does lock up while pressing down and rotating obviously you need to find out what the cause is.
You may have to remove the lower wash arm housing and clear the debris from the water passages. Once the passages are clear it should work fine.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Viking DFUD042 Built-in Dishwasher
How do you remove the lower spray arm on a Kenmore Ultra Wash (665.17019.402)? I was told to hold on to the plastic screw and spin the arm counterclockwise to remove, but I've been spinning and...
Hi, In the center of the spray arm is a threaded piece of plastic/bolt.
Use pliers and turn that tab on the bolt. If it doesn't turn easy. Holt the bolt and try to turn the spray arm with you hand.
It will release the spray arm so you can remove it.
Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Dishwashers
Upper arm dose not spin
have you checked to see if the arm spins freely if you push it
Apr 13, 2009 | Beko 24 in. D3421F Free-standing...
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
90 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
