Question about Dell Computers & Internet
I vaccumed my keyboard and now it wont connect to internet. It is a dell keyboard. There is a padlovk symbol with A lit up. No fn key
  • Dell Master
  • 5,631 Answers
You should go to Control Panel
Click Network connections
Right click Local Area connection - Activate is Disabled
Right click Internet Connections - same, Activate is Disables
If everyting activated and still you don't have connection please comment, maybe can think on some otrhe options
Posted on Apr 30, 2015
  • DeeAnn Carter
    DeeAnn Carter Apr 30, 2015
    My two options are internet options or network and sharing. The network and aharing takes me to screen that says iwner to internet (not connected). So i click on connect and it goes to broadband connection. i click connwct put in email and password (att uverse). Then it says failed. Ive done diagnose... and it doesnt find anything. It was work8ng fine until I cleaned my keyboard. I feel like if I new how to turn it off and on with a certain key it would fix it. I cant find anything that doesnt ask for a fn key. I dont have a fn key.
  • DeeAnn Carter
    Plug was out of the wall....fixed it! Sorry!
SOURCE: Fn key wont turn off
OK, I've found a soliution! :) I've been diging the internet and many people are having the same problem, so it is a common problem however the soliution is very simple (in my case). The thing is that laptops does not has a saparated Num Pad, and numbers can be found on keys under F1-F12 row or/and (active with Fn key) on alphabetic keys uiopjkl;m/ and so on. But if there is a NumLk key on your keyboard, you can lock the Num Pad on alphabetic keys. Then you have to hold Fn key pressed to write letters.  Find the NumLk key and try to turn off the Num Pad :)
On my laptop (Acer extensa 5120) NumLk key is on F11 and active when Fn is depressed.
Hope this wil help :)
Posted on Oct 02, 2008
Sutibun
  • 186 Answers
Numlock
GameAPBT
  • 3 Answers
SOURCE: Fn key on keyboard seemed stuck
hit shift and "Num Lk" at the same time. Num Lk is abov the F11 button on some Dell keyboards.
Tony Nguyen From Pasadena, CA
www.connectionzpcrepair.com
Posted on Apr 26, 2009
brownleopard
  • 15 Answers
SOURCE: dell studio touch keys won't work. the eject
Shut down your computer, remove AC power, remove the battery for about a minute. Put the battery back in, hold the power button for 30 seconds. This should reset it.
Posted on Jul 18, 2009
SOURCE: Hi i bought a Acer
The green key used by enabled function key......
Posted on Aug 19, 2010
Key board lock and not working
Look for a Fn key, and note the color. Now look for a symbol that looks like a keyboard. Press the Fn key + the key with the symbol. That should enable the keyboard.
Jun 15, 2015 | Dell Vostro 1015 Laptop
How can i tell if my keyboard is backlit in inspiron 15r?
If you press any key on the keyboard, the back light should come on automatically. If not, hold down (Fn) function key and press "right arrow" with a blue florescent symbol until the back light is lit. Pressing the "right arrow" key while holding down the (Fn) key lits the back light and can also reduce, increase the light.
Hope this helps
May 31, 2014 | Dell Inspiron 15R Laptop
Need to unlock the screen / keyboard for a Dell Latitude E4300. It has a flasing ligh on the two locks symbols on top of the keys F4 and F5. The screen reads Dell Latitude ON / Rearder. There is also a...
Hi
You can try the FN+Number lock which is quite often or the FN+F11
also FN+Screen lock which is quite often FN+F12. Let me know the respond.
Sep 16, 2011 | Computers & Internet
Keyboard on 3yr old Dell desktop PC not working. There is a lighted padlock looking icon on the keyboard that is lit but none of the keys seem to work. any suggestions?
Try pushing the FN key at the same time as you push on the lock key this may unlock the keyboard I think you are in the locked position there is a FN key this is the blue highlighted key to make all the blue keys work you have to press it simultaneously. I hope that this assisted you. Thanks for using FixYa John
Apr 06, 2011 | Dell 0Y3740 Keyboard
How do i dim the screen brightness on a dell inspiron 1525 laptop
Look at your keyboard some of the keys have blue symbols on them, that's the second function. At the bottom left of your keyboard next to the control key there's a button that says Fn on it hold that down and then press one of the other buttons to use the second function. The brightness control is the up and down arrows. Hold Fn and press up or down to change the brightness.
Also if your laptop is set to a lower power setting the display wont be as bright. Click on the little battery symbol at the bottom right hand corner of the screen a little menu will pop up that says select a power plan if its set to power saver your screen wont be as bright.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
Wireless wont enable on my dell inspiron 6400 win7
if you cant connect to any network because your wireless is not turned on, try this press and hold the " fn " key in your keyboard and tap f3.
you will able to see the wireless light is turned on. you can also check the device manager and look under the network adapter if the driver is properly installed or if it has a symbol of " ! " or " x ". if that is so then try to install the driver for wireless adapter using the "driver and utilities" cd.
(note: the fn key is usually next to the windows key)
i hope this helps.
Feb 20, 2010 | Dell Inspiron 6400 Notebook
I would like a manual for the latitude D610 keyboard to know how to use the symbol that are highlighted in bleu
In the lower left hand corner of your Dell Keyboard -- you will see a Blue Key labeled -- "Fn". This key allows you the use of ALL of the other blue labeled keys on your keyboard. You must press the FN key and the other "blue" key at the same time for them to work.
The keys on the right side of the keyboard with the blue numbers on them are controlled by the Numlock key and Fn key. The light at the top of the keyboard near the power button, with the number "9" inside a picture of a lock, will be lit if the Numlock is enabled.
You may need to press the Fn key to type numbers even if the Numlock is turned on. There is a setting in the BIOS called Enable Keypad and if you set it to By Numlock you will not have to hold down this key to type a number.
If you are still having trouble with these keys, please see the general keyboard troubleshooting guide
http://ftp1.us.dell.com/diags/R65848.htm#Key not responding or typing wrong character
Jan 13, 2010 | Dell Latitude D610 Laptop Computer -...
What are the functions of the keys on the dell 1745. F1, F2, keys with the symbols above them?
Fn + F1 Change Display Device. Fn + F2 Wireless Control Fn + F3 Battery information Fn + F4 Decreases brightness on the integrated display only (not on an external monitor). Fn + F5 Increases brightness on the integrated display only (not on an external monitor). Fn + F6 Keyboard backlit(available only if a backlit keyboard is installed) Fn + F7 Mute Fn + F8 Decrease audio Volume. Fn + F9 Increase audio Volume. Fn + F10 CD Previous - Play previous media file. Fn + F11 CD Play/Pause - If there is Audio CD in system, Media player will play music. Fn + F12 CD Next - Play next media file.
Jan 08, 2010 | Dell Studio 17 Notebook
Fn key
The "fn" key is used like a shift key to alternate between multiple symbols of the same key. The symbols on the key that the "fn" enables why being held down are usually surround closely by a box. Hope this helps.
Nov 01, 2009 | Dell 0Y3740 Keyboard
Lock symbol on computer is lit up..can't type letters
try first holding the FN key then hitting the num lk key it should solve the problem, if not take out the battery and the power and leave it off for like two minutes then restart the laptop that should reset it.
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_32392698f23d119d
Jul 08, 2009 | Dell 0Y3740 Keyboard
Computers & Internet Logo
35 people viewed this question
Alun Cox
