Question about Saws
My jigsaw wheel is stuck in forward position , preventing the blade being inserted. How do I return it to its original position?
5 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: lost instruction sheet
Try this link: http://www.accesstoretail.com/uploads/partinfo/686870.pdf
It should have exactly the information you're looking for.
If I've managed to answer your question or solve your problem, please take just a moment to rate this posting...thanks!
Posted on Mar 28, 2009
SOURCE: Changing the blade in a bosch pst 65 pae corded jigsaw
Pull up the knob on the front at the top of the machine and push the yellow bit forward. Theoretically you should turn the knob anticlockwise three turns but it doesn't seem to make any difference on my one. Then take hold of the blade, ease it forward and turn through 90 degrees. You should then be able to pull it out. Replacement is, as they say in all the best manuals, a simple reversal of the procedure. When you are turning the knob clockwise this time it's supposed to click in place but my one doesn't do this and still seems to work.
Best of luck
Gavin
Posted on Apr 10, 2009
canwoodjc
  • 3301 Answers
SOURCE: just got a B&D single
place your model number on this link http://www.blackanddecker.com/Manuals.aspx
Posted on Jun 30, 2011
  • 1116 Answers
SOURCE: I have a craftsman jigsaw(scroll)
Most of the time the cause for this is applying to much pressure on the blade as you are cutting. Remember, the blade does the cutting and you are guiding the jigsaw around the cut. This can strip the blade and wear the top of the mount. Adjust the way you cut and you should not have any problems.
Posted on Aug 26, 2011
I have a bosch jigsaw and the blade keeps slipping out of the roller blade guide after it runs normal for a few seconds. ive reset the blade and changed it.
Hi Rebecca, I hope this helps;
BLADE INSTALLATION
Set the blade orbit selector lever to position III.
Push blade change button downward as far as
it will go and turn the top handle three turns
counterclockwise (viewed from the top of the
tool).
Insert the blade into blade plunger at a 90°
angle to the cutting direction. With a slight
upward pressure, turn the blade teeth forward
(direction of cut) and guide the back of the
blade into the groove in the center of blade
roller guide. Pull gently down on the blade to
seat the blade tabs in the plunger.
With the blade in the proper position, turn top
handle clockwise until a noticeable "Click" sound
is heard, indicating that the blade is locked in
place.
Push blade change button upward to its
original position (flush with the top of the top
handle), and the saw is ready for use.
Removing the blade is essentially the reverse
of the installation procedure, however, take
note that once the blade change button is
loosened, gently push the blade upward to
release the blade tabs from the plunger.
Feb 13, 2017 | Bosch Saws
How to change blade on a Chicago jigsaw
Harbor Freight Chicago Electric Jig Saw - Review - YouTube
? 2:21
www.youtube.com/watch?v=lSh0M4WIJTk
Dec 13, 2013 - Uploaded by AdamDIY
Chicago Electric - Orbital Jigsaw 92772 They change the design over time but some of the key flaws tend to ...
jigsaw from hell - chicago (electric?) brand - DoItYourself.com ...
www.doityourself.com/.../445560-jigsaw-hell-chicago-electric-brand.ht...
Mar 9, 2011 - Most blades either have a hole in the shank or the shank is shaped like a .... A brand new one is only about $25 and no tools for blade changes.
Oct 22, 2015 | Saws
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
Blade keeps falling out when jig saw is started?
ther could be an old peice of a broken blade stuck in the collar were you insert new blade
Oct 07, 2010 | Ridgid 26638 Saw R3121 Orbital Jigsaw
My bosch jigsaw keeps saing sideways!!!
Most Bosch jigsaws have a handle on the top of the main handle that you need to pull up and rotate counterclockwise to allow the screw to accept the blade. Insert the blade and rotate 90 degrees into position then tighten the handle and press back down into place. In the beginning it may seem like you are going to break the handle pulling it up but rest assured it will get easier as it gets used.
May 10, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Jigsaw dc330 blades keep poping out when used
Hi Paul,
When inserting the blade, turn the saw upside down to prevent the blade from moving while tightening.
Before inserting a new blade, check the receiver for obstruction or debris that may prevent the blade from properly registering with the tightening screw.
Make sure the blade is fully seated in the receiver before tightening.
The tightening screws that secure blades on any type of reciprocating saws (Jig, Scroll, Sawzall, etc.) are constantly under stress and do wear out. If the problem continues, it may need to be replaced.
Best regards
Mike
Oct 29, 2009 | Dewalt Saws
I bought a used black & decker jigsaw no. 7548 and dont know how to change the blade
several methods 1) turn collar near top of blade. spring return. same in reverse to insert. 2)Older type may have spindle screw which draws up collets to clamp blade. access to screw may be through body directly over blade shaft. thats all for now.
cheers
Aug 27, 2009 | Saws
Change a blade on a jigsaw
They all either have a screw at the side of the blade holder, or some have a hole in the top of the machine where a screwdriver is inserted and a screw loosened to release the blade, and retightened once the new blade is inserted.
Jul 05, 2009 | Makita Jigsaw Blade
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Saws Logo
322 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
