Question about Miscellaneous
The wheel at the front of the jigsaw is stuck in forward position how do I get it back to its original position
  • Anonymous May 02, 2015
    Thank you folks for your replies. The problem was caused by the inner casing of the saw cover its self. It was only wen I took the plunge and removed the screws that I was able to push wheel back to its original position. Once again thank you for your help
  • 1,305 Answers
Model and brand would help plus asking in a power tool category rather than miscellaneous might attract someone who knows.
Posted on Jul 06, 2015
  • 3 Answers
SOURCE: 1999 volvo s80 passenger seat stuck in forward position
you will need to check to make sure no coins fell into the track and is jammed it if not you will need to replace the bottom frame of the seat possible with a junk yard one much cheaper than buying new and junkyard frames come complete.
Posted on Jan 08, 2009
SOURCE: Seat adjustment forward and back stuck
I had this problem not to long ago, it's a very easy fix! I agree with that garr651!
There is a a thin metal wire that runs from the left & right side under the seat. Each end of the wire loops around a small hole on each track bracket and is held in place by two small washers that fit inside a grove.
Check to see if the washers are in the groves and holing each end of the wire tightly. If they're not simply slide them back into place and make sure the wire tight.
The easiest way to do this is to look under the driver seat from the back seat. Also a pair of needle nose pliers may become handy (although not necessary).
Posted on Jun 17, 2009
97F350diesel
  • 1326 Answers
SOURCE: kia sedona front passenger seat stuck in forward position
Electric or manual??? If electric one of the motors has gone out. If the kids were playing with it they may have held the button down causing the motor to spin while the seat was all the way foward and it will just burn the motor up after so long. Also the switch could be bad. Unfortunatley being that its power there is no way to manually move the seat back without the motor turning or removing the seat and spinning the motor sprocket by hand...
Posted on Sep 10, 2009
SOURCE: Electric front seat stuck in forward position.
I had the same problem on my 2003 Toyota Camry. The threaded drive screws are what spin underneath the seat and cause the seat to move back and forth (same way a garage door opens or closes). When the seat gets all the way in the forward position, the threading on the drive screws ends, which causes the bolts connected to the seat to jam and get stuck. It should sound like the motor is trying to turn but it won't, it just clicks. Un-jam the bolts and rotate them one rotation from the all the way forward position to ensure your seat is reinstalled straight.
Posted on Oct 28, 2009
  • 59 Answers
SOURCE: the front drivers seat eletric
Thre's three motors or more that move your seat the one that controls foward/back went bad or harness under seat came apart.
Posted on Mar 17, 2010
HAD A FALL WITH MY MOTORCYCLE, HANDLEBARS AND FRONT WHEEL ARENT IN ALIGNMENT.HOW DO I GO ABOUT GETTING IT TRUE AGAIN?
Hi, Anonymous if you have a minor accident, lay your bike down and the front end gets 'TWEAKED" where the front wheel is going in one direction and your handlebars are going in the opposite direction, despair not, there is a quick fix.
1. If your handlebars are turning right turn the front end all the way to the right making contact with the fork stop. Find the 10:00 o'clock position on the front wheel and give it a good swift kick with your foot, put the front wheel in a straight-forward position and eyeball the orientation of the handlebar. Usually, it only takes one or two kicks to get everything back to normal. If you overshoot, no big scare, just turn the front end all the way to the left fork stop and find the 2:00 o'clock position and give it a soft kick.
2. If your handlebars are turning left turn the front end all the way to the left fork stop. Find the 2:00 o'clock position on the front wheel and give it a good swift kick with your foot, put the front wheel in a straight-forward position and eyeball the orientation of the handlebar. Usually, it only takes one or two kicks to get everything back to normal. If you overshoot, no big scare, just turn the front end all the way to the right fork stop and find the 10:00 o'clock position and give it a soft kick.
Continue the process until you are comfortable with the alignment. It's always a good idea to retorque any accessible handlebar riser bolts as well as the upper and lower fork clamps to proper book specs.
Good luck and have a wonderful day.
Oct 25, 2017 | Motorcycles
2005 Subaru Baja - driver seat will not move forward and it will not pitch forward either. It is not electric. Any ideas how to fix? Thank you.
need to look under seat either debris stuck in track at latch release or cable that is used to release it broke or is disconnected
Oct 12, 2016 | 2005 Subaru Baja
Tilt steering stuck in down position.wont tilt forward.
I am sure you have tried this but put it all the way down and let it lock. Then try and pull it back up. The problem will be if it stays stuck. I would wiggle the wheel at the same time. May need a third hand to help.
Feb 23, 2015 | Golden Technologies Golden CompanioN II -...
2006 volkswagon passat key stuck in the ingination cant shift gears
Can you turn the key forward and back to the off position, Is the shift lever in the park position, Is the steering wheel in the locked position????
Jan 03, 2014 | Cars & Trucks
Steering wheel wont lock and stuck in park
In the fuse block under the drivers side rear seat check the ignition 0 fuse. In the under hood fuse block check the B/U fuse and the BTSI fuse. If the b/u fuse is blown than you would not have back up lamps.
Dec 02, 2011 | 2002 Chevrolet TrailBlazer
I have a helix 360. after a pretty minor crash landing the flybar is stuck in the forward position, making the helicopter unflyable. what I mean is that as the rotor turns, the flybar is stuck in the...
Probably need a gentle bend back to its original position. Can you look at a friends or a shop one to see exactly what it should look like before a crash? Crashes usually bend something. Good luck.
Feb 13, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
Electric front seat stuck in forward position. It's a 2002 Camry. I moved the electric adjustment completely forward looking for an item and it would not return back to the original position. Both tilts...
Oct 27, 2009 | 2003 Toyota Camry
Nov 16, 2008 | 1999 Volvo S80
Stuck in 4 wheel drive & pulls to the right??? jeep patriot 3.7 auto year 2002
They told me it is becouse the front tires are new and the back tires bad. I put new tires on the back the same as the front and hope this workes.
Jun 26, 2008 | 2002 Jeep Liberty
Miscellaneous Logo
19 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
