Question about Garden
On my riden lawnmore does it take oil in the rearend
2 Suggested Answers
  • 40 Answers
SOURCE: oil coming out of my champion lawnmore r484
you likely will need a new air filter and a carb cleaning. when mowers are turned on their side. oil will seep past the piston and if your intake valve was open it can pass thru into the carb and also spoil your air filter. I am assumeing you have a paper air filter. start by taking off your air filter. then you should also pull the spark plug, place a rag covering the hole. then pull the cord a couple times. chances are that you will blow the oil out of the cylinder. I would recommend a oil change.
Posted on Apr 08, 2009
What kind of oil is needed in the rearend
If it did not have oil it would make the noise going straight. Check your brakes and the wheel bearings for play. Oil should be a GL5 70-90 wt gear oil.
Jun 22, 2014 | 1998 Ford Expedition
I was riden threw the bush it cut out like had no fuel and the gear box oil is milky
Not Good,,,,you've blown a topend gasket,,,Drain the whole system,,oil,water,,Replace the topend gasket set,,,that will fix it,,don't ride,or run anymore till you get it repaired.
Feb 15, 2011 | 2004 Honda CRF 250 R
LAST SPIN SOUNDS LIKE LAWNMORE, IS THA NORMAL
It may be due to heavy usage or water leak at the bottom of the unit if you find any water leak kindly replace the two inner bearing along with the water seal top solve your problem
May 08, 2010 | Whirlpool Washing Machines
H2 2005 oil leak on drivers side shock area.
im not that familiar with hummers but it sounds like youve found the end of the transmission vent hose or possibly the front differential vent hose and they will have seepage of oil sometimes. however if its a constant oil drippage, then there could be a buildup of pressure inside tranny or rearend. if u follow the hose down to its beginning youll know if its the trans. or differential(rearend). it might be normal to see this fluid,or it could be too much fluid inside trany/rear.
Sep 14, 2009 | 2005 Hummer H2
Starts rought,drives and sounds like a lawnmorer?
The most likely cause is water allowing secondary (spark) voltage to go to ground. Look at all plug wires. Inspect carefully the inside and outside of the distributer cap...
Sep 09, 2009 | 1985 Mercedes-Benz 190
Oil coming out of my champion lawnmore r484
Apr 08, 2009 | Garden
Tranny oil white
I would drain it ASAP!Most likely it got in through the vent line.Not sure where the tranny drain plug is.
Dec 28, 2008 | 2005 Suzuki TF 125 Mud Bug
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
