Where can I get a replacement fan motor, OEM or comparable. The distributor around here won't sell me one, I'm not a contrator.
    Top Expert:
  • Heating & Co... Master
  • 46,416 Answers
Try these guys http://erepairparts.com/
Posted on May 01, 2015
    Master:
  • 450 Answers
Find a motor shop and they should take care of you with a generic motor. Replace the capacitor too if it has one.
  • 3,957 Answers
If you have a contractor friend, have it purchased by them. If not Google search the motor model number and source a vendor online.
Posted on Apr 30, 2015
  • Jay Lyons
    Jay Lyons Apr 30, 2015
    Can't locate the motor model number to source it. If I knew the H.P. and rpm I could just source I could source a vendor online, I do have the physical dimensions.
Need a replacement start/run capacitor for a C56A31B17 AO Smith 3/4 HP 1725 RPM 110 V boat lift motor.
Try your local granger store, they normally stock them. You can get them on eBay as well
Apr 16, 2015 | Pool & Spa
I HAVE A UPSTAIRS UNIT AND A DOWNSTAIRS UNIT AND BOTH HAVE THE FANS TURNING THE WRONG DIRECTION, AND A REPAIR MAN TOLD ME YOU COULDNT REVERSE IT BY SWITCHING THE WIRES AND JUST SCRATCHED HIS HEAD PLEASE...
Swapping wires won't reverse an OEM motor. The only way to reverse the motor is to change the field. Take the motor apart and flip the armature to the other side and she will go in the other direction but if the motor don't go back together right then it will pole out and lock up. Lots of trouble trying that one. Now some generic motors have provisions to reverse direction by swapping around some shorted designated wires that are added specifically for that purpose. If that is OEM it won't have those wires. One thing you could do is get some new blades that turn in the direction you desire and are the same size and pitch..
Jun 25, 2011 | Goodman GPC1342H21A Air Conditioner
Can you please tell me if the plastic fan at the back of the motor can be replaced thank you best regards. john.
You can, but you'll have to purchase from an electric motor distributor. I don't know the exact motor that is in that machine.
Part Number 596141-3 is the entire motor assembly which is only around $65.00. Pretty good investment for a tool that is still retailing around $400 with the added assurance of a warrantied part.
Feb 12, 2010 | Makita 10" Dual Slide Compound Miter Saw...
Installed new distributor in 97 Chevy Vortec V6
Check the wire harness to the Ignition control module (ICM) or replace it. It cost around $40,00 from Auto Zone and it's common for the ICM to fail, or it may just be starting to fail and it's also know that the OEM distributor had a screen vent at the bottom of the distributor for ventilation to prevent condensation from forming in the distributor. Check to make sure your new distributor has a vent and that it's not plugged up with shipping plastic. Condensation may be forming causing the misfire in the distributor. Good luck and keep me posted.
Jul 16, 2009 | 1994 Chevrolet K1500
Motor mount, front right, solid or hydraulic?
Hello wrygrl...The OEM (orginal equipment) passenger side motor mount for the 1988 olds ninety-eight was a hydraulic type. After market "solid" type mounts are available for replacement...either type will work. Shop around and get some price quotes, i believe westar makes a solid type mount that sells for around 22 bucks.
Hope this answers your question. Have a safe and happy memorial day weekend.
May 21, 2009 | 1988 Oldsmobile Ninety Eight
COILS IN FREEZER FROSTED/TEMP WON'T GET BELOW 45 '
can you feel air blowing out of the vents in the freezer comparment.sounds like the evaporator fan is not running. this is common with refrig's that have been stored for a long period of time. the fan motor bearings will seize.the motor is easy to replace your self. remove the screws in the rear panel of freezer compartment you will see the fan at the top of the coils. the fan can be purchased thru sears or any appliane parts distributor. you will need a omplete model number off of the unit it is loated near the ceiling on the right hand wall of the refrig section. good luck peyton
Jan 24, 2009 | Kenmore 53612 / 53614 Side by Side...
Capacitor
Here is a link to a distributor with fan specs : http://www.grainger.com/Grainger/wwg/productIndex.shtml?search_type=keyword&QueryString=3C325B&operator=refineSearchResults&originalValue=Dayton+Fans&searchIndexId=1&typeOf=
I do not know which specific motor is used on that fan ( that fan has been discontinued) however you can check out this link http://www.emotorpro.com/index.asp?PageAction=VIEWCATS&Category=280
and have a representative that sells Dayton products answer your question... Hope this helps you...
Sep 09, 2008 | Dayton Permanent Split Capacitor Motor Fan
Ford ranger a/c fan
These fans are not the most powerful, but auto zone sells them for cheap if you want to replace it.
cost is usually around 30 bucks and installation is easy.
Jul 20, 2008 | 1995 Ford Ranger Supercab
Very noisy
Usually when the motor fan or motor bearings go bad, it will run very loud. You will have to replace the motor. Part #2031214, sells for around $55.
Jan 17, 2008 | Bissell 6594 PowerForce Bagless Upright...
Noise
When the motor fan or motor bearings go bad, the motor will run real loud and will have to be replaced. Part #2031214 and sells for around $55.
Nov 15, 2007 | Bissell 6594 PowerForce Bagless Upright...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
