What does $35.00/M mean - Office Equipment & Supplies
What is the meaning of the name Bessie
NEW15+
HOT
VIDEO10
Share Tweet
Baby Names
by Category
Bessie
Browse
Parenting / Baby Names / B / Girl / Bessie
Bessie
The name Bessie is a baby girl name.
Meaning
Greek Meaning:
The name Bessie is a Greek baby name. In Greek the meaning of the name Bessie is: From the Hebrew Elisheba, meaning either oath of God, or God is satisfaction. Famous bearer: Old Testament Elizabeth was mother of John the Baptist and one of the earliest known bearers of this name; Queen Elizabeth II.
American Meaning:
The name Bessie is an American baby name. In American the meaning of the name Bessie is: From the Hebrew Elisheba, meaning either oath of God, or God is satisfaction. Famous bearer: Old Testament Elizabeth was mother of John the Baptist and one of the earliest known bearers of this name; Queen Elizabeth II.
Hebrew Meaning:
The name Bessie is a Hebrew baby name. In Hebrew the meaning of the name Bessie is: From Elisheba, meaning either oath of God, or God is satisfaction.
English Meaning:
The name Bessie is an English baby name. In English the meaning of the name Bessie is: meaning my god is bountiful, or god of plenty, used since the 16th century. Sometimes used as an independent name.
Sep 09, 2016 | Computers & Internet
What does mean mean
mean means mean.
Could be 'that person is mean to me' meaning opposite of nice.
Could signify the average.
Could be 'signify' as in 'what does that mean to you'
Feb 19, 2015 | Computers & Internet
What does the prefix plac mean?
What word has the prefix plac-? Surely you don't mean "place," which has no prefix. If you mean "placoderm," it means "plated" or "plate-like", and "-derm," means "skin." If you mean "placenta," I'm not sure it has a prefix, either. Plac- is probably more of a word root than a prefix.
Feb 13, 2014 | PREFIXES AND SUFFIXES
What is mean
The mean is a measure of central tendency, an average. There are several different types of means, including arithmetic mean, geometric mean, and harmonic mean.
Dec 27, 2012 | Office Equipment & Supplies
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
I need the manaul for this product. I do not know what the the flashing light mean, and I was given this product from another co-worker....but no one knows what the lights mean?
Hello, you can download the manual here: http://www.plantronics.com/us/media/media-resources/literature/user_guides/73156-01_CS55_US_DL.pdf?WT.dl=20 It says that a flashing amber light means charging, a solid amber light means charged, a solid red light means power, a solid green light means talking, and a blinking green light means muted.
May 16, 2011 | Plantronics CS55 Wireless Headset
I have a 4 x 4 2000 S10, the cruise corntrol is not working. the fuses look good. All light appear to be OK. what else should I check?
If there is an Auto Zone around your area, have the truck checked for any DTC codes that may keep your Cruise control from working and make sure that your brake lights do not stay on which can be the cause of the cruise control from working. If all the simple things have been checked, then check the wire harness to the cruise control modulator. The modulator is located in the fire wall beside the brake booster, make sure the wire harness is not damaged in anyway. If all the wires seam good, then it's a good chance that it's going to be the cruise control modulator it self. Mine went bad a few years back and i picked one up from the Salvaged yard for around $35,00. You don't have to get one from a 2000, you can pick one out from a newer truck like yours of one from a newer truck with the same cruise control modulator. Good luck and keep me posted, be glad to answer any more questions you may have.
Oct 26, 2009 | 2000 Chevrolet S-10
I have a 1998 Saturn SW2 that idles high sporadically. Frequently it runs around 1500 rpms when in park even when it is warmed up. I have had the idle motor control (I think that's what it's called)...
Erratic idle is commonly caused by a malfunctioning IPS (Idle Position Sensor), MAF sensor or IAC (Idle Air Controller).
Cleaning any of these only prolongs the inevitable. Change the sensor at fault to eliminate the problem.
Have you had the OBD error codes read?
Some errors do not cause a CEL condition. The bulb may be burned out - or removed by the previous owner.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 20, 2009 | Saturn SW2 Cars & Trucks
No speakers cant get them to work,stereo illuminates has power and have gone on line still no speakers
It sounds like the amp built in the car stereo has gone bad. It's common on the GM product factory radio that the amp in the radio go bad due to the heat and it may need to be replaced. The best thing to to is go to the salvage yard for a factory replacement, since your truck is 17 years old and the salvage yard will cost you around $35,00. That may vary depends on where you live, so call around. Good luck friend, the other thing to is to have the stereo repaired and hope it's not going to cost too much.
Jul 16, 2009 | 1992 GMC Sierra
Ok my mp3 works but the clock portion does not ,why is that?
Simply, you need a new battery....here is the secret....not everyone knows how to change the watch battery and re-install the mp3 device properly. Please do not attempt to change the battery yourself...there are delicate springs inside and if they are damaged, your watch will malfunction. Only a professional should change the battery. if need futher assistance you can call Mercer at 661 917 4615 $35,00 return watch postage included with price.
Aug 06, 2008 | Skull Candy MacGyver MP3 Watch (1 GB) MP3...
306 people viewed this question
jasbo
jasbo
