Question about Bosch Washing Machines
Find replacement doors for washing machine
Bosch wash and dry washing door lever is broken so need new replacement door
    Prodigy:
    An expert who has answered 500 questions.
  • Bosch Expert
  • 536 Answers
Http://www.repairclinic.com/
Posted on May 05, 2015
    Genius:
  • Bosch Master
  • 1,585 Answers
E spares
Posted on Apr 30, 2015
Bosch WAN new washing machine won't tart though washed other loads. Only 5 items under 2kg for sportswash and it flashes start light and lock, beeps and does not start. Why and what can I do about it?
Check that the door is closed properly. It's always better to test without clothes inside. Also, check that there are no broken parts from the inside side of the door. All these parts are usually plastic, so it is very easy to brake something even the machine is brand new.
If all these above are checked, then it seems that you have a problem with the electric door lock and needs a replacement. I advice you not to fix it by yourself. You should call at local Bosch service for a visit, since the machine is still in warranty.
Feb 27, 2017 | Bosch Washing Machines
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
How do I repair/replace a broken door?
Hello there, you will need a new hinge and probably the inside round piece of the door. Can you upload a photo? Please indicate the
E-Nr of the machine. You can find it on the label around the door and/or at the back of machine.
Jul 02, 2015 | Bosch Washing Machines
Washing machine door leaver is broken
Get a new one from you bosch service agent You will need the model number for this. If you can't replace it your self you might have to pay for a service call
Mar 24, 2013 | Bosch Washing Machines
The door seal
All front load washers have the same problem. After washing, prop the door open for a couple hours to dry out the inside.
Aug 18, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Front loader washing machine the door latch is broken, it will not shut to perform cycle. Can you help?
Does it never latch and run, or does it occasionally work? Have you tried pushing on the door? Does the latch make any sort of noise? Have you recently had the boot replaced because of mold? Sorry for all the questions in reply to your question, but if the latch is physically broken then it needs to be replaced. If the question is "how do I replace a broken Bosch latch?", that's a different question.
May 06, 2009 | Bosch Nexxt 300 Series WFMC2201UC
BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Mar 09, 2008 | Washing Machines
Bosch dryer nexxt 500 (wtmc3521uc) broker plastic window
The plastic window can be repalced you dont need to get a new door...
Just remove the door from the washing machine and undue the screws around the rim and unclp the plastic rim and you should be able to fit in a new one with no problem...
hope it helps any questions dont hesitate to ask..
Jan 20, 2008 | Bosch WFMC 3200 Front Load Washer
Help needed indesit washing machine
well it would help to know brand/model#
Oct 03, 2007 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
