Question about Stihl Garden
Runs for 5min. then stops.
Good spark
  • Mark
    Mark May 01, 2015
    Turned out to be the gas cap not venting.
    Master:
  • 456 Answers
Clean the carburetor and if it has a bubble primer check to make sure that hasent got a hole in . it sounds like petrol problem.
Posted on Apr 30, 2015
  • 3,957 Answers
Check your fuel lines for hardening or cracking, and ensure they are connected to the inlet/outlet ports tightly. Ethanol damages many of the plastic parts.
Good carburetor cleaner, and ensure you have fresh gasoline that is properly mixed.
Engine turns over and pops does not start
old post, i over shot.
there are lots of checks.
you will be told lots of things, 6billion people all with thoughts..
pops to where, air cleaner or to tail pipe end????????
to the Air cleaner means bad timing (cam or spark) or far worse....
try the real way.
fuses first.compression over 150psi on all cyl. W.O.T.CEL lamp in cluster glow keyon.connect scan tool, does it show errors, key on?>now crank of 5 seconds, does the scan tool tell you the CKP or CMP are bad? if not , then its not. (get DTC for ignitor?)Ok i check spark to all cylinders with my timing light.but #1 is first and must flash near 0 , if not the cam did slip. 5min work.ok spark good on all cylinders, is it , doing a real spark test, with a real test spark plug, bla bla bha, 100 years same...ok spark is good, car runs nice on test fuel, does it? for 3seconds, vereoommmmm stall, and sounds nice, no pops?ill stop here as fuel failure is 10 more tests. not typing them now..... ask.
Jul 01, 2014 | 1996 Isuzu Hombre
Idling problem
stalls.
you stated the bad , but what is the good.
can it be driven? with full power.
your car has no year? and if working engine,? what engine? option
ever get a 60,000 mile tune up this decade? (just old spark plugs do this)
you start the cold engine/
can you keep it running, with a fast right foot action?
starts after 5min, then runs perfect all day???????
my guess, is one more missed tune up.
Feb 23, 2014 | Toyota Quantum Cars & Trucks
I have a 1982 f100 cranks runs 5min an cuts off wont start until get cold
had this problem once and it was a wire inside the electronic distributor. would bend when it got hot and break contact. when the engine cuts out check if there is spark.
Mar 22, 2011 | 1981 Ford F 100
Runs ruff idling when cold!
Check your choke system first, fix any anomalies then if all OK check your carb systems including your air cleaner.
If those steps doesnot resolve your problem ask me again for other possibilities. Good luck
Apr 13, 2010 | 2005 Yamaha V-Max
Wont run with out chock
the carb needs to be rebuilt this is a very easy job for the DIYer just get the parts from your local repair shop and have at it..good luck
Apr 03, 2010 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Dodge intrepid 1997 not getting spark i changed computer and still wont start
Check the wiring that runs near the coil. There are a few thin wires in the group that become frail..move them around while someone is turning the key. You may be surprised.
Mar 20, 2010 | 1997 Dodge Intrepid
Stihl 55 blower runs 5min. and quits /cool 5 min. and runs aga
running the right fuel mixture for the unit if not it could have to much oil & fouling out the plug or not enough oil & getting to hot & melting the piston ring & piston the only other thing is the carb adustments
Nov 10, 2009 | Garden
Garden Logo
69 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
