I want to connect the TV Ears to the ABC Component outlets on the back of the TV, but that doesn't work. How can I get sound to come out of those connections?
TV Ears (brand name) uses ABC component wires for TV sound. I am using a splitter and have one set of wires going to the AT&T cable box for regular TV. The Blue Ray player has no compont outlets. So, I want to connect the TV Ears to the ABC Component outlets on the back of the TV, but that doesn't work. How can I get sound to come out of those connections?
  • Sam McClaren
    Sam McClaren May 04, 2015
    The TV is a Panasonic Viera Mod.# TC-50AS530U. The component outlet connections are for such things as Home theater/speaker audio & video units. Nothing in the manuals or in-set settings instructions mention headphones. I'm stumped.
Only possible with televisions that provide that function, which yours obviously does not.
Posted on May 07, 2015
  • Sam McClaren
    Sam McClaren May 08, 2015
    From Amazon I purchased a "ViewHD" Premium HDMI to HDMI+Audio (SPDIF+RAC L/R) Audio Extractor/Converter/VHD-H2HSAs and a 3ft. HDMI cable and added that to my BlueRay connection. Now, I use the splitter button to switch between HDMI1 & HDMI2. It works just fine. Cost:$30.95.
Sharp crt tv no sound primo series
Just connect an other speaker in place, and make sure that the speaker inside the TV has no fault. If sound comes out from the externally connected speaker is OK; be sure that the speaker of your TV is OK, and the fault with with its audio output section circuit. Check and replace the damaged component/s at the audio output stage circuit. Contact any service technician. Gopakumar Gopalan Google
Mar 10, 2014 | Televison & Video
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
No sound coming from sound bar
what do you mean hooked up and then no sound, hooked up with dvd player in the tv and then no sound?. ok check the cable if no loose connection, replace if possible.if still doesn't work tried to hooked up in other component input in your tv unit just to ensure if the problem is with in the signal input board.
Sep 15, 2012 | Insignia Televison & Video
I have an Emerson lc320em9 3 model tv and I can't
Make sure your X Box is switched to component and not hdmi.
May 02, 2012 | Emerson Televison & Video
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    Hitachi57projection tv when dvd is hooked up, have sound and no picture.
    check the connection if it was in proper video component input in your tv unit, try other video input if still picture doesn't appear on the screen, make sure you have the right settings with in your tv set. then the connector from dvd player is properly connected to the component video out jack.
    Jul 22, 2011 | Televison & Video
    When recording the sound is distorted
    I saw your post, bmbkiones, and I'd like to help you with it! Make sure all connections on the back of the receiver and TV are hand-tight secure. If the problem is still happening, unplug the receiver's power cord from the outlet for at least ten seconds and then plug it back in. If that doesn't fix it, let me know what type of receiver you have. The model number can be found on the front panel in the bottom left corner. Also, what type of connection do you have from the receiver to the TV?
    Hope that helps!
    Jul 01, 2011 | Televison & Video
    When I turn on my set, light turns green, then after 30 seconds turns red won't come on
    Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
    May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
    Televison & Video Logo
    279 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
