Question about Refrigerators
Water on floor
Layer of ice in bottom of freezer compartment
  • Refrigerators Master
  • 5,323 Answers
Clogged drain plug....
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
Posted on May 06, 2015
Rotu
  • 175 Answers
SOURCE: Icing up in bottom of the freezer
I don't know the particulars of your brand, but if it is frosting up Most fridges will have a bad heater element, a bad defrost timer (or controller if it is electronic) or most likely a bad defrost limit switch. This is a switch mounted on the inlet line of the evaporator with a clip and senses when the evaporater is defrosted so that it does not get too hot and start melting parts. This switch should have zero ohms of resistance when cold (below 40ish) and be completely open when above 40 or so. The easiest way to test it is take the wall covering the evaporater off and locate the plugs for the swiths. Test continuity through it. If it is sitting in ice, it should have no resistance. If it is open and in ice (infinite resistance) then it's bad.
Posted on Oct 05, 2006
  • 1073 Answers
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
  • 3 Answers
SOURCE: maytag side by side, bottom freezer compartment had daily ice build up
I’ve had my Maytag fridge for 8 years. But only this week did the same problem show up as cathy824 and lew223. When I poked a drink stirrer into the top of the drain hole, it was hard as a rock. Not knowing why condensate from the coils was not draining into the hole and tubing that would empty the water into the pan evaporator on the bottom of the fridge, I took everything apart in the back and messed around with the black rubber elbow at the other end of the drain plug. I shouldn’t have bothered, because what I finally did was to pour boiling, boiling hot water over the drain hole to melt the ice and gunk that was frozen solid in the drain tubing. While I was doing that, I poked the stirrer into the hole, washing the gunk down the drain and into the very dry evaporator pan. Keep pouring hot water into the drain hole until you’re satisfied that water can flow freely into the pan.
That solved the problem of condensate water freezing on the bottom of the freezer and running onto the kitchen floor. Thanks to lew223 for the fix! The fridge should be good for another 8 years now.
Posted on Feb 04, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
  • 4 Answers
SOURCE: Freezer compartment leaking water and icing up inside
I just fixed this problem with my Admiral. I noticed the problem when I found ice in the bottom of the freezer and water leaking out onto the floor. Here is what I did: remove all of the food from the freezer into large coolers. Pull-out the shelves, the icemaker bin, and thaw the basket with a hairdryer until you can pull it out. There are about 12 phillips head screws that hold a plastic baffle covering the freezer coils. Remove all of the screws and loosen but do not remove the icedispenser motor and freezer light (you can pry it up to get to the top screw of the baffle). Pull the top part of the baffle away from the back of the freezer and then slide the baffle up to reveal the defrost drip tray and drain. Use a hair dryer and screw driver to remove the iceblock from the drip try and to thaw any other ice in the bottom of the freezer. Also thaw the top of the drain. Now pull the freezer out from the wall and under the drain area in the back you will find the drain tube attached with a "Oh-Jesus" clamp - at least that is what we call them here in Indiana. Pinch the clamp with pliers and pull the drain tube down. Use a stretched out wire hanger to snake out the tube (I had lots of calcium deposit and a dust ball clogging the tube) and then replace. Test the system with a cup of water to make sure the drain works (should see water end up in the pan under the right front bottom drip tray). Replace baffle, icemaker motor/light, bin, shelves, food, done.
Posted on Oct 11, 2010
Samsung refrigerator RF 4287HA bottom of freezer has layer of ice making drawer difficult to open melted ice and cleaned up water two weeks/ go ice is back
POSSIBLE RESTRICTED DEFROST DRAIN @ FLOOR OF FREEZER BEHIND EVAPORATOR PANEL. USE STEAMER OR WATER TO CLEAR ICE FROM DRAIN HOLE
Jun 01, 2018 | Samsung Refrigerators
I have Kenmore refregrator model 51272200. Water is leaking inside and forming ice at the bottom of the freezer. The refregrator compartment is warmer than usual. Your help on this is greately appreciated....
CK THE ICE MAKER WATER INLET TUBE IT MAY BE ICED AND CAUSING THE WATER TO RUN DOWN THE BACK / ALSO CK THE DRAIN IN BOTTOM OF FREEZER / A VERY COMMON PROBLEM . THIS WILL ICE THE BOTTOM OF FREEZER FLOOR AND RUN OUT ON FLOOR .. .. MM HOPE THIS HELPED ..
Jul 01, 2010 | Kenmore 53092 / 53094 Side by Side...
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice build up on floor of freezer drawer
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Mar 02, 2018 | LG LRFC25750 Refrigerator French Door
Layer of ice in freezer. How do I access drainage tube to clear i
It is in the freezer compartment but you can try accessing  it from the bottom where it goes into the drip pan. Try using a can of compressed air with a straw held tightly with your fingers and blow out the line backwards.
Not a lot of infor ar pictures in you manual . It does say to make sure it is level and shows hot to do so. See below:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=AFD2535DE&siteCd=AMA
Dec 20, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Water leakage under freezer door-ice on bottom of inside of freezer
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 27, 2008 | Maytag MSD2758GEW
Water for some reason is coming out of the bottom we just happen to find it. also It is drippinging and freezing in the bottom of the freezer we clean it out and it comes back, but the water on the floor...
Sounds like you have a side-by-side...
The defrost drain is probably clogged or frozen. When the fridge runs a defrost cycle the melted water cannot reach the evaporator pan underneath the refrigerator. Some water makes its way out onto the floor to wet your socks, and some re-freezes inside the bottom of the freezer compartment creating a layer of ice.
Jul 25, 2008 | Frigidaire Refrigerators
Frigidaire, ice on floor of freexer
check to see if the defrost drain is not frozrn over or stopped up
this is the only way that water can get into the freezer
frost could and melt but dont think that i would check the drain at the bottom of the rear freezer panel if you see ice it is stopped up for sure
if all is clear there go to the ice maker, have had some that are overfilling and runnig over the ice maker into the bottom of the freezer
Jun 23, 2008 | Refrigerators
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
