Question about Staples Tools & Hardware - Others
How do you load staples
When I push in rod they are pushed out
    Top Expert:
  • 3,107 Answers
Contact the manufacturer of your particular stapler for instructions.
Posted on Apr 30, 2015
How to reload staples.
If this is a staple gun then you need to release the tab on the back of the gun. It will release a long spring with a push rod on it. Insert the new staple bundle and replace the push rod. If this is a desk top stapler then pull the top until it opens. Set staples in and close the top again. Make sure to clear out any staples that may be loose or lodged before.
Nov 29, 2015 | Staples Tools & Hardware - Others
Load staples in et50 arrow stapler
It will probably have a release at the bottom rear of the stapler. Just push the release in and down to release the rod/spring assembly (the release catch may be silver in color). Drop in a stick of staples the reinsert the rod/spring and reengage the release.
Dec 12, 2014 | Arrow Tools & Hardware - Others
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
Jun 26, 2011 | Arrow T50P ARROW STAPLE GUN
How do you open/refill this stapler?
Push the top of the lever located on the back of the stapler.It will pop out on a spring. Slide a new strip of staples in and push spring/rod assemble back in until it clicks into place.
May 31, 2011 | Ace Hardware Ace Staple Gun
I have recently been given a Powershot 8000 stapler and having trouble loading staples ,how does it load?
With the staple exit facing toward you (don't squeeze the handle), find the small black square at the bottom (opposite end) from staple exit. Grasp both sides. Pull away from gun (not down). Chamber will open.
Mar 01, 2011 | Powershot Tool Company Cobra 8000 Forward...
I don't understand how to load a T-50 staple gun. There are never any pictures of the thing that you push. I think it may have broken off of my gun. If that is true, then it is no good? ...or is there...
we have one, you push in at the back and pull down take out the rod put the staples in and put rod back in and push up it locks itself, hope it helps
Jan 30, 2011 | Heavy Duty Arrow T50 Staple Gun
Don't know how to load staples in my powershot pro
Usually a black tab toward the back of the staple gun.
Push in, pull up and pull out.
Push rod, spring and assembly should slide out easily.
You can then reload as needed.
Push in, pull up and when the push rod bottoms out push down.
This usually locks the tab back in place. Do this a few times and you will get the feeling pretty quick.
Oct 18, 2009 | Powershot Tool Company Cobra 8000 Forward...
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
How to load Arrow T25 Staple Gun
at the back end of the handle, there is a retainer spring loaded clip. Push it in, then push it downward toward the base of the stapler, the clip should then release the spring, pull the rod with the spring completely out, slide a row of staple in where the rod came out, ONLY ONE ROW, then insert the rod with the spring back in and push it firmly in, and lift it upward to engage the lock. and fire away... Hope this gets your working
Jun 08, 2009 | Arrow T25 Staple Gun
There's a jammed staple but I can't figure out how to open it to fix the problem and refill it
This is how it works on the Arrow staple gun. On the back bottom, opposite end from where the staples come out, there is a little plate. Push it in and it unhooks and pops out. attached to a rod. When you refill with staples, just push them in, then put the rod back in and the spring applies the pressure.
May 31, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Tools & Hardware - Others Logo
21 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
