Question about Garden
How to adjust oh intek 50 cc 18.5 mower - Garden
    Champion:
  • 225 Answers
What is it youre trying to adjust???
Posted on May 12, 2015
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I can't find where to attach the vacuum hose for my fuel pump on my B&S Intek 15.5hp
check the dipstick tube for a pulse port. If not, you'll need either a valve cover or dipstick tube with one. Oh and your carb is going to give you fits because it's set up for gravity feed. Yes there is a difference...
Nov 14, 2013 | Garden
Having problems with B&S 18.5 HP Intek. Turns 1-2
This sounds like a compression release issue, which is directly related to the OH valves needing adjustment. Remove the valve cover and adjust the valves per B & S exact instructions and your starting issue will likely be solved. The valves are needed to be adjusted periodically on these machines. The compression release feature works off of the camshaft and is controlled by the action to the intake valve. It works at low speeds and then cancels as the engine starts running.
Many, many users have this problem and are unaware of the compression release mechanism and the fact that the valves periodically require adjusting, They tend to blame their starting problems on a weak or bad battery, which this problem mimics quite well.
May 08, 2011 | Craftsman Garden
I have a 17hp briggs and stratton vertical intek engine that needs the valves adjusted again. What are the adjustments for the valves?
adjustment with 4000 feeler gauge
adjust top valve when the bottom valve is fully compressed and than with the top valve fully compressed adjust the bottom valve the same way.
very easy But remember to losen the center tork screw before adjusting the rocker arm nut
Apr 01, 2010 | Parks Optical Briggs And Stratton Engine...
Need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Jul 10, 2009 | Garden
How do you time a 18 hp intek motor
timing is set by a key in the fly wheel...can adjust very slightly y moving the magnatron further away or closer. other than that no adjustments with out replacing internal parts
Jun 30, 2009 | Garden
Briggs & stratton 18 HP intek ohv won't start
check the safety switches one of them are bad
Jun 25, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
