Question about Measuring Tools & Sensors
How to adjust oh on 50 cc intek 18.5 - Measuring Tools & Sensors
How to adjust oh intek 50 cc 18.5 mower
what is it youre trying to adjust???
Apr 30, 2015 | Garden
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Having problems with B&S 18.5 HP Intek. Turns 1-2
This sounds like a compression release issue, which is directly related to the OH valves needing adjustment. Remove the valve cover and adjust the valves per B & S exact instructions and your starting issue will likely be solved. The valves are needed to be adjusted periodically on these machines. The compression release feature works off of the camshaft and is controlled by the action to the intake valve. It works at low speeds and then cancels as the engine starts running.
Many, many users have this problem and are unaware of the compression release mechanism and the fact that the valves periodically require adjusting, They tend to blame their starting problems on a weak or bad battery, which this problem mimics quite well.
May 08, 2011 | Craftsman Garden
New 18" Poulan Pro 42 cc saw, mixed up new gas
Don't use stabil. Use a modern synthetic saw oil (50:1 fuel to oil ratio) available at home centers, hardware stores, and saw dealers. Mix the oil and fuel in it's own container and be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. If it becomes apparent that the carburetor adjustments are wrong, you will need to see your dealer for adjustment. Good luck!
Dec 18, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
7 hp oh valve sears frame
Remove the cover for the valves by the spark plug and adjust both valves at .008 gap
That will end the back firing. They have locking nuts (double nuts) at each valve to adjust
Jun 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I HAVE A 18HP BRIGGS TWIN CYLINDER AND I NEED TO KNOW WERE THE ADJUSTING SCREWS ARE
On my 18 HP, if you are facing the engine and the flywheel is on the left, the adjusting screws are all under the air breather. The best way to get at them is to take the breather mechanism off right down to the carb. They are all on the left side of the carb!
Jul 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
How do you time a 18 hp intek motor
timing is set by a key in the fly wheel...can adjust very slightly y moving the magnatron further away or closer. other than that no adjustments with out replacing internal parts
Jun 30, 2009 | Garden
Carburetor adjustment
have you checked the air filter,if that is clean I think I would replace the carb, diaphram.
May 05, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
148 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
