The display is lit up but showing 000 the control knob is lit but the control buton dose not do anything.
I tried unplugging and then plunging back in but dose nothing it is getting power but will not turn on anyone have any ideas?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Could b door inter lock
Posted on Apr 30, 2015
The control board won't do anything. It is lit up but the incline and speed display are just dashes and the other lit up section is just constantly running lights around it.
Hi There, you didn't mention a make or model? It sounds like the motor control board has died. Has the deck been lubricated lately?
Does the console appear like it's working but no belt movement?
Fitness Remedy in Sun Prairie, Wis., repairs most brands of control boards.
Nov 09, 2015 | Exercise & Fitness
All lights lit up with the number 46 on timer
Hi Juan Abrante,
I understand that you are getting all the lights lit up with the number 46 showing on the display. What this can be is an error code. Error 46 means that it could either mean that the different control boards are miscommunicating or something is wrong with the main control board itself. Try resetting the washer for at least 3 minutes by either unplugging the appliance or cutting the power at the circuit breaker. When you do this, leave the power cut for at least 3 minutes. Bring the power back to the appliance and try starting it back up. If you are still receiving that 46 on the display, I would recommend getting a hold of the manufacturer for more help.
-Best of Luck-
Jan 03, 2014 | Frigidaire ATF6000ES Front Load Washer
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
The words on the display are blurry the hole screen seems a little blurry tried contrast and sharpness dose not help
This can be corrected. You will need to use caution. Pull the back cover off. You will see a flyback transformer. You will note, that a suction cup is connected to the back of the picture tube. Follow the red lead and you will see the flyback transfomer. You will also see, two potentiometers on this transformer. The top knob will correct the focus you are talking about. The bottom knob will increase or decrease the voltage to the picture tube. Just work with the top pots. It will say focus on the knob. Turn back and forth as you watch the lettering of an informational program. This will be helpful. Thanks for asking and show all hands of support!
May 15, 2011 | Toshiba 36A40 36" TV
I have a Vizio VW37LHDTV10A LCD t.v. set that was built in august 2007. The power will come on and I can see the back light turn on. However, the screen stays black and there is no picture or sound. Then...
My friend, I recently fixed a vizio vw37l with the same problem but it was the lcd controller.
hope this helps a bit to diagnose your problem
Aug 27, 2010 | Televison & Video
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
Dec 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
The display shows all the icons of the sytem and wont clear...
$38 part from Sears PartsDirect took about 30 mins to install.  Part # AH92-02673A Ay pcb-front.  There are actually 2 boards to this setup, I went ahead and replaced both but the power button side of the board has some wiring that requires you to remove the disc changer which is only 4 screws and 2 screws for the piece that holds the disc above the reader.
I couldn't find an easy way to get the knob off on the front it required me to force it, nothing borke but your replacing the board anyways..
Jan 09, 2008 | Samsung HT-X50 System
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
