Question about Alba LDVD1538WDCH LCD TV
My alba 19inch tv is giving me problems. when I first switch it on you can see the picture and you can hear the sound. After a few seconds the picture disappears and you can only hear the sound.
    Top Expert:
  • Alba Master
  • 74,118 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on May 01, 2015
Alba Tv Codes
093,011,082,074 are the codes to check. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. You can also make a search by type in the brand name of your device into the search box; can be located at the top right of the display window. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
May 09, 2013 | Televison & Video
Switch on alba tv and sound is there for a few seconds then goes off.
We are not dealing with analog TV signals any longer and so the operation of these display devices are more complicated.
If other channels are good then check the signal strength of the channel you are having trouble with as all these signals are now digital streams and they take time to sync up and the buffers to be loaded.
Aug 10, 2012 | Alba Televison & Video
ALBA tv screen turns itself off, but the volume stays on, what's wrong with it? how do I correct it?
Might be some loose solder terminal/s at its horizontal output section. The set should be checked.
May 11, 2012 | Proton MM2701VT 27" TV
Not sure if anyone has come across this problem before. I have had 3 tv's in my son's room and all 3 different models including old one alba 19 inch lcd and another all just stopped working....
jotvguy just wondering, is there definitely power in these outlets ? Have you tried a lamp or something else to prove you have power at the wall outlet?
Jul 11, 2011 | Televison & Video
32" ALBA 15 MONTHS OLD.
I am afraid it sounds as though either your backlight or power inverter has gone faulty, may be worth contacting alba to see if they will honour the warrenty (unlikely but worth a go) otherwise maybe try your home insurance to see if its covered, failing either of these options, if you feel confident doing so, disassemble the tv and look for any signs of visible damage (capacitors leaking or any components looking burned or scorche, and replace. Try looking for any panel markings which will allow you to search for a price to replace the whole unit.
Unfortunately I cant give you and hard and fast cure, and it is very difficult to tell whether it is the inverter or the backlight has gone (having said that, if you are getting picture at the very beginning, it may suggest that the inverter is getting the power to the backlight ok, which may suggest its the backlight at fault.)
Hope this helps.
May 07, 2011 | Televison & Video
I cant connect my wii to my new alba tv
How can I connect Nintendo wii to alba LCD tv 19inch
Apr 29, 2011 | Televison & Video
Alba lcd32880hdf tv after a few seconds the pitcher gose off
Ive got a albe Lcd32880HDF And the picture goes off 14 months old sound only?
Jan 07, 2011 | Televison & Video
Hi. I have an ALBA LCD32880HDF television which I purchased in August 2009 so just outside warrenty. I have been on holiday for a week and had switched the television off at the wall and returned home...
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
Oct 24, 2010 | Televison & Video
Alba LDVD1538WDCH LCD TV Logo
37 people viewed this question
Top Alba Televison & Video Experts
Rod
Rod
Robert Crombie
Robert Crombie
Level 1 Expert
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
