Question about Dryers
Looking for a replacement wheel for an Emerson Electric fan Model 89649-F. Wheel is 5 1/4 diameter and fits a 1/2 shaft.
SOURCE: Can't remove motor from dryer
I access the motor to replace it but can't seperate it from the fan wheel.
Posted on Jan 09, 2008
SOURCE: replacing blower wheel
make sure you turn the nut clockwise to loosen it.
(backward threading)
Posted on Jan 29, 2008
Tech007
  • 63 Answers
SOURCE: kenmore dryer 110.76732500 problem
I would take a hammer and hit it hard break it off I have done this a hundred times at my shop then you can put new blade on with ease
Posted on Jun 09, 2008
  • 65 Answers
SOURCE: Can't remove dryer blower wheel
I would start by taking off the top and checking the belt to see if part of it tore and is hitting the inside of the cabinet. I have not found a real good way to get the blowers out without having to break them sometimes. the part of the blower that you have to hold is access through the front behind the motor. problem is when you turn the motor shaft, the wrench strips out on the blower, then you have to break them, but unless you need a new motor, it should not have to come off.
Posted on Jan 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: remove blower wheel
Put a good fittting wrench on the blower nut and hit it with an impact wrench(left handed threads righty lucy). OR do it the tried and true redneck way get a friend to hold a pipe wrench on the pulley inside the dryer, around the back slide a small hammer handle or piece of wood in between two blower blades at 3 o'clock position and slam downwards to pop that mutha loose. The threads are left handed(backwards). That blower does not wanna go easy.
Posted on Feb 18, 2009
How do I separate the fan wheel from motor shaft on Nutone LS-100 in order to replace the motor?
There are two ways these are connected. One is by a grub screw, that is a screw that when tightened is either flush with the shaft and so hard to see, or is slightly recessed in the shaft which is a bit easier to spot, use an 'alen' or hex key to remove this first. Second way of securing the shaft is to use a 'Morse Taper' where the spindle is made to a taper which causes the taper on the shaft to lock to it. Identify which end of the taper is narrower [you may need to measure the diameter of the shaft to determine this as there may only be a few mm difference in the diameter on either end] then use a hammer and tap sharply from the larger end toward the narrower end..
Oct 20, 2014 | Broan-NuTone N-LS100 Exhaust Fan Exhaust...
I can't get the motor shaft off the fan
From inside dryer hold blower wheel with wrench that fits the squre part of blower wheel turn motor shaft clockwise should loosen the blower wheel............
Jun 21, 2014 | Whirlpool LER5636P Electric Dryer
Hotpoint ctd80p dryer. Noisy from rear. Took off heater cover and discovered what i think is the cooling impeller which has worn out plastic splines which fit on the shaft that comes from motor. Is all i...
Hi and welcome to FixYa, I am Kelly.
The fan should just be a slide on the motor shaft snug fit with a metal clamp. The Blower wheel (fan) when they fail usually crack the center hub and no longer fit will on the motor shaft sungly so it contacts the blower housing as it rotates. That is why you hear all the noise. If the blower wheel / impeller as you referred to it does not fit tightly on the motor chaft then you will have to replace it. It should rotate in a true non-oscillation pattern like a circular saw blade. Any side to side movement during rotation is cause for replacement.
Here are 2 sources for a spare part:
http://www.spares4appliances.co.uk/s4ag1253-whirlpool-tumble-dryer-blower-wheel.html
(^- best price)
http://www.tdspares.co.uk/proddetail.asp?prod=mfn1024&cat=210
Thanks for choosing FixYa,
Kelly
Aug 18, 2011 | Dryers
Im looking for the thread size, off the drive shaft of a power build 10.5 hp
i'm assuming your looking for the nut that holds on the flywheel? if so, measure the diameter of the thread in the crankshaft. you need the diameter and pitch(oor threads per inch) to "know" the thread size. Measure the diameter accurately. then, measure the length of the thread. example, if there is 1/2 inch of thread length and you have 4 threads in that length it is a "8" thread. so if the diameter (overall diameter measured on top of the tips of the thread) is 1/2 inch, then your thread is 1/2-8.
Jan 14, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
I'm looking for a replacement motor for an Emerson Electric wall fan, probably from the 1950s. The model number is F33CYBOM-750, and the MFG# is 86898. Other pertinent info from the mfg plate is that the...
i have emerson electric motor (brand new in box) model no. F33HXEGP-2016, 1/20 HP, 208/230 V, 1.0 AMP, 3000 RPM, MFG # J74B, part no. P-8-8851, thermally protected. contact me at neneay12@gmail.com
Dec 06, 2010 | Dryers
I need a condenser fan blade for a Maytag M6P09D2A portable a/c unit. I can't seem to find that this unit was ever manufactured. It's about 6 or 7 years old. The fan blade is a plastic, centrifugal type...
If you have the old blade, measure the diameter, width of the wheel, diameter of the shaft hole and the number of blades or blades per inch. Go to www.uri.com and see if you can' find a match. If not, e-mail them or look to see if there is a local branch near you.
Jul 17, 2010 | Maytag Portable Air Conditioner M6P09S2A
More RPM Issues for Tools 1) Have old jointer with motor..1725rpm 5 1/2" pulley.. pulley on jointer is 2 1/2" ..what is 4" jointer blade speed ? also looking for right speed for 4" jointer.. 2)...
I had the same problem a while back, But I didn't bother with exact speed, what I cared more about was power and speed, and not bogging down. And I had it running smooth. Of course I have no idea what the pulley diameters were, but it sounds like you should be real close with the 2 1/2 inch at the head and 5 1/2 inch at the motor spinning 1725, should be about 900? So to get 700, bring the 5 1/2 down to 4 1/2, see if it has enough speed/power.
Feb 13, 2010 | Air Tools & Compressors
Fan motor replacement. getting the correct replacement motor. I have a model no.,frame no.,,RPM,mfg no etc. but forgot to physically measure the shaft and diameter of the motor. Emerson fan motor model no....
with the model number the supplier shoud be able to tell you what you need but some sell universal variable speed motors with long shafts so trim to fit might come in to play
Nov 20, 2009 | Heating & Cooling
I'm looking for a replacement switch for an Emerson Electric Roll-about fan model #89649-C. Is it possible to still find one? The fan is very old but still working except for the switch which sometimes...
If you cant find the replacement, why don't you just replace it with any switch that suite for it, as long as the functions is still the same.
You can fix it if you want......
Oct 23, 2009 | Dryers
The blower fan is loose and jumps alaround but I seeno way of securing it the is just a grease fitting there
The blower wheel tightens to the motor shaft(reverse threads) and the housing to the casing. if unable to tighten to motor, could be a broken blower wheel...sold as assembly part#131775600 sugg retail$50.(includes housing and wheel)
Jun 10, 2009 | Frigidaire GLER331A Electric Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
