Where is the 5 v power supply located. - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on May 01, 2015
Fuse locations vizio e470vle
The fuse will be located on the power supply board. The power supply board is the one that the power cord plugs into. The fuse should be close to where the power cord plugs in at.
Dec 06, 2012 | Vizio E470VLE 47 Class Widescreen LCD HDTV
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    Where are the fuses located on a 37 inch flatscreen magnovox?
    The fuse can be located on the power supply board. To locate the power supply board, trace the TV wire back into the TV. The area where the TV wire is soldered inside the TV is the power supply board. There is fuse on the board. So this means you have to disassemble the TV....
    Regards.
    Walesarumi
    Sep 28, 2011 | Televison & Video
    Black screen no sound
    You have a bad power supply...do a search online at Google, Ebay, or Shopjimmy.com and match up you numbers from your power supply. Requires taking off the back of the set and locating the power supply (located by tracing the AC plug (from the wall socket wire)) and unscrew and unplug the power supply.
    Jun 02, 2011 | Sanyo DP46849 46 in. HDTV
    Where is the power fuse located
    fuse is located at the power supply section.to get to the power supply you need to remove the back cover of your monitor..after you remove the cover you can see the power supply..and the fuse is place on the pcboard and there are two fuses the primary fuse and the secondary fuse....be careful when replacing the blown fuse...do it only once once you replace the fuse and blown again there is a problem on your power supply...replace your power supply with a new one...
    hope this could help you...goodluck!
    your rate is important to this help tnx..
    May 11, 2010 | ViewSonic N2751W 27 in. LCD Television
    Cannot locate the fuse in the liteon power supply
    The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
    Jan 31, 2010 | Lite On LiteOn 150W LPX Power Supply...
    Need power supply for Hp 336044-B21 KVM Switch. (DVE Switching Power Supply, Model DSO-142L) in the last two month I lost three same switches with the same problem - power supplies...
    There are a few things that you can do. First; try to go online to HewlettPackard.com and locate the power supply. Second;go online to ebay and search for the power supply. Last;locate a Batteries R Us store in your city. They have a huge supply of batteries and power adapters. If you do not find a HP adapter the store person can help you find one that is complimentary to your HP adapter.
    May 29, 2009 | HP 336044-B21 8-port KVM Switch
    Power Supply Bestec ATX-250-12E Rev.P6
    Normally if you open the PSU up warranty will be void. ( if it's Under Warranty). if not once you open the unit the fuse's are located right nest to the power input.
    Jan 01, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
    Televison & Video Logo
    24 people viewed this question
    Top Televison & Video Experts
