Question about Electrical Supplies
Goes off when shower steam is present? - Electrical Supplies
    Sergeant:
  • 415 Answers
Probably should not use the generator in the shower. Moisture from the steam may be causing the problem.
Posted on May 04, 2015
Turn on steam in shower, but no steam comes out
So many things could be wrong. 1 check circuit breaker. 2. Check there is water going to steam unit. Power to control in shower? Steam unit could be burned out. Or control is not working or thermostat not working.
Apr 08, 2015 | Electrical Supplies
Water is pouring out of pipes where steam should be coming from- ? - Please advise
Paige - your question appears in the "Shower hardware" section.
Steam - from a shower head?
Water should be coming from a shower head and steam is in your radiators - not the other way around. Please provide more info on the products or system you're having this trouble
Dec 10, 2014 | Home
Shower problems I have a zy-137 shower and steam cubicle The steam wasn't commingled through the valve and I turned it to have a look one it has come unscrewed and there is a visible hole and I am unable...
Somehow you have to get that pipe coming back through the wall of the shower.
There is a pipe with threads on it that the nozzle threads onto.
Once you can get that pipe back through the shower wall you can thread the steam nozzle back on.
If the steam nozzle has been replaced onto the threaded pipe you can trouble shoot your steamer as to why there is no steam coming out.
ROD
U S Parts Center
May 14, 2014 | Home
SM-9-901 Generator Steam Shower
There are three things that affect this:
1. Incoming water temp.
2. Incoming water volume.
3.Temp of the device.
There are some other minute things like humitidty and altitude too.
Jul 21, 2013 | Steamist SM-9-901 Generator Steam Shower
Where to buy aariel steam shower 120V 3kw heating element
best thing i could advise you to do is go to their web site and order direct...this is your best bet...good luck
Dec 26, 2012 | Dmm WMK-A06 Pearl Steam Shower Unit,...
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
Aug 12, 2012 | Home
Steam shower wont turn on getting a flashing temp on controller in shower
Hi I am with Mr. Steam Tech Support please call 800-767-8326 and ask for tech support. please have your serial number and we will be able at assit you in getting your unit up and running
Thanks
Mike
Mr. Steam
Product Support
Nov 14, 2010 | Mr Steam Ms Super 1e Steam Shower...
Alarms go off with humidity.too sensitive.Any
All smoke detectors, whether they are of the photo-electronic or ionization type, can false alarm due to steam. There are basically two solutions to your problem. Either move the detector further away from these areas (I have found keeping a smoke detector at least 6 feet away from the bathroom door normally works) or if that is not practical, after showering try to evacuate steam by either opening a window or turning on the exhaust fan for several minutes before opening the bathroom door.
Oct 30, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
