My L.G. Model WP.9914PT. Washing machine when I turn the spinner timer then the curcuit braker trips.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Prob earth leakage on motor or pump
Posted on Apr 30, 2015
Yozzer6821
  • 116 Answers
SOURCE: INDESIT Washing Machine
Probably the pump or hose is blocked, remove the cover along the front bottom, of the machine, remove the filter and clean out, ensure the pump impeller is clear of debris and rotates freely.
refit the filter and try again.
Posted on Apr 18, 2008
ginko
  • 19396 Answers
SOURCE: Water is not draining out
Check that the drain hose is not clogged.
Access to the drain pump and check the drain pump intake, that is probably filled with debris.
Ensure that the drain pump is working, the pump should be energized directly by a technician to test it.
If the drain pump is fine , and you already tested water level switch, then it is either a bad control board, or a lose contact on the drain pump wiring harness to control.
Posted on Feb 18, 2009
  • 215 Answers
SOURCE: Hotpoint washing machine barrel not turning all
could be motor not rotating under pressure. When you say brushes have you removed them from motor to check them, also check they slide in and out thier holders ok, as they may be sticking
Posted on Feb 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Ariston delay timer problem AVXL129 washing machine
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
SOURCE: LG Model WP-9241 Washing Machine - Wash tub ok but
i am getting problem in spin unit pl give us manual of it for repair
Posted on Nov 07, 2010
How do i fix the spinners knob of the defy 1000 twinmaid washing machine
Write your answer...i have a twinmaid 1000 defy.The problem is the spinner.When i turn the timer on,it makes the sound but it does not spin.What could be the problem?
Jan 10, 2015 | Washing Machines
Washing machine has blown a fuse and tripped the curcuit breaker
I hate to say this but a blown fuse in that machine wouldnt trip the breaker, so if you turn the breaker on and it stays on until you start the machine the motor is probably shorted and need to be replaced
May 10, 2012 | Hotpoint First Edition WMA22 Front Load...
Maytag Atlantis Model 8551AWW washing machine...fills up with water...then starts the agitation cycle and will agitate for about 1 minute...then shuts off...after about five minutes the agitation cycle...
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Maytag Atlantis MAV8551 Top Load Washer
Our FrancisFrancis espresso machine, started tripping the circuit since we moved from london to singapore. Is it a problem with the machine or the machine is incompatible with the Singapore's electric...
The electricity power is the same as UK 230V and 50 HZ even with same plug shape.
The tripping of the curcuit braker is due to a short in a power line inside the machine.
The most posible part is the heating element and second athe solenoid valve. Last with less posibility is the vibarating pump.
The only way to identify is to open the top of the machine and by a use of leectrical tester you can mesure the above parts live lines if they have an earth contact and replace that part.
Give emphasi to the boiler element.
Good luck
Aug 23, 2010 | FrancisFrancis! X1 - Stainless Steel...
I have a Kenmore model 20802990 washer, it will run for a short while and then stop working, it is almost as if the circuit breaker trips because when I turn the circuit breaker of then back on and switch...
well you right in saying "its triping the braker off" thats what it is doing,,
there is a problem with the washer motor,,its pulling far to many amps so its a fulty motor,,,and it will just keep triping the trip out,,,
its a good job you have trips,,the motor could have gone up in smoke
Jul 15, 2010 | Kenmore 24032\24036 Top Load Washer
Breaker trips when unit is turnedon. Breaker works properly.
replace the timer.
It is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Washing Machines
Washing machine problem
Possibly your timer or a motor
Aug 28, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
