Question about Toro Garden
I have a Toro time cutter Z4200 and trying to put the deck back on I guess I need a picture
2 Suggested Answers
  • 85 Answers
SOURCE: The motion control levers became tight to move and
You may have some bent or out of adjustment linkages, causing the brakes to stay on.
Or the friction nut (one on each transmission) is too tight. These are located just in front of the axel, they go through a slot, the washer behind the nut should turn freely
Posted on Aug 17, 2009
Timecutter z4200
If you were able to jump start mower then the problem lies with the battery connections or battery itself
Jul 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro Z4200 hdro won't stay in neutral
Your throttle csble is stretched it needs a new one
Dec 15, 2013 | Toro Garden
I have a Toro Timecutter Z4200, The lawn mower turns on fine, but when I go to engage the blades, it makes this terrible grinding screeching noise. I checked to see if the blades were hitting the deck and...
Hi Josh, It sounds like you have a bearing going out on your deck. The best way to check is to remove your deck from your mower, and remove belt. Then spin one blade at a time, they should spin freely and fairly quietly. You will be able to verify the bad bearing quickly by isolating and checking one at a time. The noisy one that grinding will probably need to be replace, although you could try greasing it first. They are fairly simple to replace and not too expensive. It should consist of three or four bolts. FYI, you may want to take a picture of how your belt is routed before removal, this will help you when reinstalling it. Good luck and I hope this helped.
Aug 14, 2013 | Garden
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Aug 10, 2013 | Garden
I need a toro z4200 drive belt diagram as my belt fell off
you should be able to get and idea from the net. log into toro and than go to model entry.
Oct 13, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Aug 15, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Toro TimeCutter z4200 will not start
First check to see if there is a fuel shutoff under the tank. On some models there is a fuel filter screen inside the tank where the fuel line connects to the tank. If niether of these work, R&R the carb.
Apr 08, 2009 | Toro Lawn Mower With Toro Power Tools
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
32 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
