Question about Husqvarna Garden
What are the steps to removing gas tank from Husqvarna 48 riding lawn mower?
I'm getting poor gas flow from tank. It seems there's a blockage. I've blown air into gas line toward tank and cleared it but it continues to block line. Also, I notice leaking beneath mower near tank. I'd like to do complete maintenance on fuel system, including clean & inspect tank.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Before you do that check the breather hole in the gas tank cap - that's the most common problem. Leaking is probably a faulty pipe, especially if you've disconnected them. Don't rely on push fit only - use hose clips.
Posted on May 04, 2015
SOURCE: I have a YTH1542 husqvarna riding mower. Will not stay running
make sure the small vent hole on top of the gas cap is not clogged. Mine did the same thing and then I found mine was packed with dirt.
Posted on Jul 20, 2009
  • 77 Answers
SOURCE: I have a John Deere/Scotts/Home Depot 20 hp
The easiest way is to not remove the tank. Buy a can of chem tool the liquid,not spray.Drain gas out of tank,pour can in tank,let sit for 15minutes,then drain,should clean it out good.
Posted on Aug 10, 2009
spekgt
  • 60 Answers
SOURCE: Husqvarna GTH2250B riding mower leaking gas tank
Hi there
The tank on that machine is a Husqvarna tank . The part # is 532 15 13-46 and you can get it @ your local Husqvarna dealer. To find a dealer near you just check the link below
http://www.husqvarna.com/us/homeowner/support/dealer-locator/ . About any recall on the tank you probably have to contact Husqvarna direct . Use "contact" on the Husqvarna site .
Hope this help
Posted on Sep 03, 2009
mickey813
  • 472 Answers
SOURCE: Husqvarna gth 2448t 48'' 24 hp riding mower 2007
YA IT SOUNDS LIKE YOUR SEAT SWICH IS BAD THATS THE MOST COMON THING I SEE A LOT OF LET ME KNOW IF THIS HELPS YOU
Posted on Oct 08, 2009
  • 3074 Answers
SOURCE: Crack in the Kohler engine block for a 2006 LT1042
if you find a good machinist and he/she maybe able to braze it
Posted on Apr 17, 2011
How do i drain wrong gas from my tank.
There is a gas line hose which is attached on one end to the bottom of the gas tank, and which then will run to a gas flow shut-off valve (if your mower has one) or to the gas filter or fuel pump. Take the hose loose at the nearest point to the tank, remove the gas cap, and simply drain the gas into a suitable pan or other receptacle large enough to hold the volume of gas that's in there. Try to make sure the mower is level front to back and side to side when you do this. Hook everything back up and you should be good to go.
Aug 02, 2016 | John Deere Riding Lawn Mower. D140 48 in....
What are the steps to removing gas tank from Husqvarna 48" riding mower
If it is a rear tank unit, drain the fuel and disconnect the fuel lines. The transmission will need to be removed for clearance. Then locate the 3 or 4 mounting blots. The tank will then drop out from the bottom.
Apr 30, 2015 | Husqvarna Garden
How to remove fuel tank on 48 inch husqvarna riding mower
pull the rear seat/fender assy... the floor boards ( where your feet sit ) have a couple of bolts, then the seat springs have a couple of bolts... a couple of handles might have to be removed...
Aug 26, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Why is the gas tank not venting ?
Did you check the top of the gas cap for tape over it top of gas cap should have a small hole all the way through it.take a small piece of wire see if you can push it through . you might have other issues. If it does not.take cap off and drill tiny hole through it .or send cap back where you bought mower explain you want a new cap.
May 18, 2014 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
Riding Mowers
You may need a 'heli' coil or a larger Spark Plug, it seems that the vehicle at operating temperatures is building up too much pressure and pushing out your current sized plug! Same thing happened to a me! And if its too much pressure, there is a 'filter' that becomes restricted, easy check!
Hopes this helps!
Dr. Gene n Landrum, PhQ. Quantum
May 19, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My Husqvarna will only stay running with the choke in and even then it will only run for a short time?
Gas flow through the carburetor is clogged. Easy fix is the following----- remove all gas from tank (siphon or drain). Put that gas aside or dispose of it. Use a little bit of fresh gas and a little bit of carburetor cleaner in the tank. Run that through (by running the motor with the choke.). Do it several time if needed. When it seems to be running better, then try just a little gas only to be sure you have cleared it. When you fill-er-up, be sure to add a gas additive like Sea Foam or similar.
Apr 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Gas will not flow. All hoses and filter have been
that unit has a fule pump on it thay rarley go out but last week i had one that the pump was frozen it was cold here and i took it off and put in the truck and warmed it up i asllso found a lot off water in the gas tank so try that if that dosent fix it than you may need to get a new one let me know and tell me what moter it has and ill tell ya the part number ok i may have one in stock ok
Jan 30, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
268 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
