Question about Radio Communications
How do I extend the radio frequency from 80 MHz to 105 MHZ?
  • 21 Answers
No possible due to the frequency band of the radio. Governed by component values.
Posted on May 10, 2015
Benimur
  • 6966 Answers
SOURCE: Yeasu FT 897D
I suspect that the extended transmit will really allow you TX on 2 Meter from 136-174 or thereabouts even with modifications.
At any rate, Air Bands are amplitude modulated, have you tried switching mode to "AM" when operating 116-136MHz??
Would you post back please on how the modification (extended transmit) was done; software programming of the EEPROM or jumpers (JP1001-1009).
Good luck and kind regards.
Posted on Nov 23, 2007
  • 6 Answers
SOURCE: Need Frequency List
CHANNEL FREQUENCY 01 462.5625 02 462.5875 03 462.6125 04 462.6375 05 462.6625 06 462.6875 07 462.7125 08 467.5625 09 467.5875 10 467.6125 11 467.6375 12 467.6625 13 467.6875 14 467.7125
Posted on Dec 17, 2007
Agent Ken
  • 250 Answers
SOURCE: choosing the right frequencies for Uniden GMR1058-2CKB
Hello huko,
I see from your profile that you are in Bulgaria. Assuming that you are using the European PMR446 version of the Uniden radio in question, the channels / frequencies should be;
1 - 446.00625 MHz
2 - 446.01875 MHz
3 - 446.03125 MHz
4 - 446.04375 MHz
5 - 446.05625 MHz
6 - 446.06875 MHz
7 - 446.08125 MHz
8 - 446.09375 MHz
So, to operate on 446.09375 MHz you would chose channel 8.
If your radio has more then 8 channels, then you may have the U.S. version of the radio which operates on a different set of frequencies and does not have a channel that corresponds to 446.09375 MHz.
Best Regards,
Ken
Go Ahead. Use Us.
Posted on Apr 23, 2008
  • 14 Answers
SOURCE: yaesu
Here is a good website with radio mods for most radios, here's the mod for the vx2, also note the other files, I guess that radio has had a few problems in the past....
http://www.ham.dmz.ro/yaesu/vx-2r-freeband-mod.php
Posted on Oct 29, 2008
ALLEN CLARKE
  • 47 Answers
SOURCE: maxon SL25
if the band assigned to the radio doesn't cover the frequencies you want then it will not happen. you need to get the software and the right programming lead. make sure the mic socket is good and clean
Posted on Nov 27, 2008
How do you get the cobra walkie talkie to say the weather
Provided that your 2-way radio has the feature, there should be either a dedicated weather button or somewhere in the menus. Not sure what model you have. If it is a more advanced radio where you can set the frequency, the list of weather broadcast frequencies taken from NOAA are listed below. Two way radios are normally automatically programmed to one of these frequencies and usually require a push of a button.
Nationwide Station Listing Using Broadcast Frequencies
162.400
MHz 162.425
MHz 162.450
MHz 162.475
MHz 162.500
MHz 162.525
MHz 162.550
MHz
Jul 02, 2014 | Radio Communications
Sanyo car radio F-7512A
FM frequency range in North America is 87 MHz to 108 MHz. In Japan it is from 76 MHz to 108 MHz.
Jun 25, 2014 | Audio Players & Recorders
Tabla de frecuencias
CB Radio Channels (FCC)[32] Channel Frequency Channel Frequency Channel Frequency Channel Frequency 1 26.965 MHz 11 27.085 MHz 21 27.215 MHz 31 27.315 MHz 2 26.975 MHz 12 27.105 MHz 22 27.225 MHz 32 27.325 MHz 3 26.985 MHz 13 27.115 MHz 23 27.255 MHz 33 27.335 MHz 4 27.005 MHz 14 27.125 MHz 24 27.235 MHz 34 27.345 MHz 5 27.015 MHz 15 27.135 MHz 25 27.245 MHz 35 27.355 MHz 6 27.025 MHz 16 27.155 MHz 26 27.265 MHz 36 27.365 MHz 7 27.035 MHz 17 27.165 MHz 27 27.275 MHz 37 27.375 MHz 8 27.055 MHz 18 27.175 MHz 28 27.285 MHz 38 27.385 MHz 9 27.065 MHz 19 27.185 MHz 29 27.295 MHz 39 27.395 MHz 10 27.075 MHz 20 27.205 MHz 30 27.305 MHz 40 27.405 MHz
Oct 18, 2013 | Connex 3300 240-Channels Base CB Radio
What is the frequency
FRS frequency range: 462.5625 MHz to 467.7125 MHz
GMRS frequency range: 462.5750 MHz to 462.7250 MHz
Oct 13, 2013 | BellSouth 2250BK (22 Channels) 2-Way Radio
Can the GRECOM PSR255. be used to scan for aircraft /airband frequencies
Your radio is not capable of recieving air band frequencies. It will only receive 4 bands consisting of: 26 - 54 MHz; 68 - 88 MHz; 137 - 174 MHz and 380 - 512 Mhz.
The VHF airband uses the frequencies between 108 (just above commercial FM radio) and 137 MHZ (just below 2 meter Ham radio). Amplitude Modulation ("AM") is the mode that transmissions are made. The lowest 10 MHz of the band, from 108-117.95 MHz, is split into 200 narrow-band channels of 50 kHz. These are reserved for navigational aids such as VOR beacons, and precision approach systems such as ILS localizers
Jan 26, 2013 | Grecom Gre Psr-255 50 Channel Handheld...
Looking to find the frequenecies of the upper and lower channels
  • Hi I can help.
  • For the Grant 40 channel CB there are 40 frequencies I will list below.
  • When you refer to the upper and lower channels for this raidio you must mean USB (Upper Side Band) and LSB (lower side band).
  • This is called single side band modulation which is to say the the carrier is removed from the upper or lower sideband depending on which your pick and the signal goes farther on less power.
  • So the upper and lower side bands are the same frequency just upper side band or lower sideband.
  1. 26.965 MHz 21. 27.215 MHz
  2. 26.975 MHz 22. 27.225 MHz
  3. 26.985 MHz 23. 27.255 MHz
  4. 27.005 MHz 24. 27.235 MHz
  5. 27.015 MHz 25. 27.245 MHz
  6. 27.025 MHz 26. 27.265 MHz
  7. 27.035 MHz 27. 27.275 MHz
  8. 27.055 MHz 28. 27.285 MHz
  9. 27.065 MHz 29. 27.295 MHz
  10. 27.075 MHz 30. 27.305 MHz
  11. 27.085 MHz 31. 27.315 MHz
  12. 27.105 MHz 32. 27.325 MHz
  13. 27.115 MHz 33. 27.335 MHz
  14. 27.125 MHz 34. 27.345 MHz
  15. 27.135 MHz 35. 27.355 MHz
  16. 27.155 MHz 36. 27.365 MHz
  17. 27.165 MHz 37. 27.375 MHz
  18. 27.175 MHz 38. 27.385 MHz
  19. 27.185 MHz 39. 27.395 MHz
  20. 27.205 MHz 40. 27.405 MHz.
  • If you have any comment please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
I need to know what the number for the weather frequeancey for my radio.
Nationwide Station Listing Using Broadcast Frequencies 162.400
MHz 162.425
MHz 162.450
MHz 162.475
MHz 162.500
MHz 162.525
MHz 162.550
MHz
For active frequencies in your county, visit the National Weather Service web site:
http://www.weather.gov/nwr/indexnw.htm
Bill B.
Listening in since the 60's
May 23, 2011 | Uniden BC92XLT Handheld Scanner
In Thailand Cb radio users must use freq range 245.000 - 249.999 freqs. Do usa Cb's use this freq?
Thailand actually has three "CB" bands, the first is the same as the U.S. / CEPT (EU "European Community) band 26.965 - 27.405 MHz, the second is a 78MHz VHF mid CB band (I think its either 40 or 80 channels with FM mode) and then the 245.0000 - 245.9875 MHz VHF 80 channel band - apparently the law also stipulates that the 78MHz CBs must be yellow colored and the 245MHz CBs must be red colored.
But yeah, 245MHz Thailand VHF CBs are very illegal in the United States.
Jun 24, 2010 | Cobra 19 DX III 40-Channels Base CB Radio
I can't retune the channels on my motorola xtn
Sorry, but the XTN446 has only the 8 channels pre-programmed by the manufacturer.
Channels 8
Codes 121
Frequencies 446.00625 MHz
446.01875 MHz
446.03125 MHz
446.04375 MHz
446.05625 MHz
446.06875 MHz
446.08125 MHz
446.09375 MHz
Here is a copy of the spec sheet: http://www.comm-spec.com/pdfs/radios/Motorola-XTN446-UHF-License-Free-100225.pdf
Best regards.
Mar 27, 2010 | Motorola XTN 2-Way Radio
Choosing the right frequencies for Uniden GMR1058-2CKB
Hello huko,
1 - 446.00625 MHz
2 - 446.01875 MHz
3 - 446.03125 MHz
4 - 446.04375 MHz
5 - 446.05625 MHz
6 - 446.06875 MHz
7 - 446.08125 MHz
8 - 446.09375 MHz
Best Regards,
Ken
Go Ahead. Use Us.
Mar 14, 2008 | Uniden GMR1058-2CK (7 Channels) 2-Way...
Radio Communications Logo
160 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
