Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Microwave works for a minute or two, then stops heating.
My microwave works fine for a couple minutes, but then stops heating. Everything else seems to be operating fine (e.g. lights, timer, rotating plate). However, the microwave's normal buzz/hum stops after a minute or two and it stops heating. If I cancel the job and wait at least 5 minutes or so, it will do the same thing. It's almost like the microwave thinks it's overheating and shuts off the heating element until it cools back down. I have already replaced the magnetron and the diode, and the same problem continues. Could it be some sort of thermostat or something else?
    Problem Solver:
  • 11 Answers
Check the air filter and cooling fan.
Posted on Feb 24, 2016
MicrowaveSvc
  • 9047 Answers
SOURCE: KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Mar 11, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Stopped heating food
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here onFixYa:.
You can find helpful exploded view diagrams and order parts for many brands by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you may be able to download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jan 01, 2009
  • 1214 Answers
SOURCE: Microwave hums
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Posted on Jan 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Hi, my microwave is not heating and i cannot hear
I would have started with the diode and capacitor (i.e the least expense) but you can check the diode by removing the input wire and doing a continuity check in BOTH directions. In other words check it then reverse the leads and check it again. It should only read in ONE direction. If it reads continuity in both directions or is open in both directions it is bad and must be replaced. If the diode check out fine then by all means check the capacitor. Just respect the fact it is a large capacitor and can really ruin your day if it is good and has a full charge. (Been there done that!) Take a screwdriver and ground across the terminals several times then note the position of the wires on the capacitor and remove the wires from ONE terminal set. Take your meter still on Ohms ( old simpson type dial meter for this test) and place it on the capacitors 2 terminals. Then rapidly reverse the leads and you should see a momentary jump on the meter then fall off. No jump when you repeatedly reverse the leads then the capacitor is bad. This should solve your problem unless there is a relay on the control board that controls the magnetron power.
Posted on Jan 16, 2010
  • 6771 Answers
SOURCE: kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Posted on Mar 12, 2012
Frigidaire Microwave heats everything except for food
Your fianc? employed a surefire method of killing a microwave oven. A simple perusal of the manual would have revealed the recommended cleaning method.
Feb 26, 2017 | Microwave Ovens
The microwave heats up fine but the blower motor does not come on right away. After a couple of minutes you can hear the motor start - stop and at the end finally works fine.
rheire could be a number of reasons for this problem i would start by checking the connections to the blower motor may just be loose connectors that dont make a good conection until heated up then check for power to the motor when unit is opperating if none it will be in the control panel if power is present replace motor.
Mar 08, 2011 | Maytag Appliances Over-the-Range Microwave...
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
It quits heating after a couple minutes and sounds
replace the fan otherwise your microwave cell wil burn out, the safety comes on because the cell become to hot. no colling of microwave cell.
Feb 15, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Microwave won't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
mv.,
Feb 28, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave cuts off after heating for about 3-4 minutes
There is a overtemperature device inside that is shuting you down until things cool off. Take the cover off and clean up everything as much as possible. Grease from the cooking can get all over everything inside and collect dust buildup enough to obstruct the airflow and cause overheting.
Dec 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
Dec 17, 2007 | Sanyo EM-S9515W Microwave Oven
Panasonic Model nn-s252bf.....not heating probably
check magnetron related circuit, any loose contact is there the above problems comes to oven, thats why check all wiring at high voltage section...
Oct 28, 2007 | Panasonic NN-S254BF Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
101 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
