Question about Grilling
How to replace burners on Jenn Air Model 730-0337 grill
  • 11 Answers
SOURCE: The gas flow is very low to the 3 burners on my grill
Hi - assuming there is no severe kink in your gas hose and there isn't any other obstruction in your gas line, a likely cause is that your regulator is faulty and may need to be replaced. I don't think they are very expensive.
You may want to post your problem on the Jenn-Air section of this forum: http://www.bbqsource-forums.com
I've had good luck getting help there with my grills.
Pat
Posted on Nov 28, 2008
SOURCE: jenn air 32 in. 4 burner gas grill
Sounds like a problem with the regulator. Try turning on the burners 1st before opening up the propane valve. If that doesn't work unscrew the gas line from the propane tank with the tank valve open a little (burners off) then screw it back on.
Posted on Apr 09, 2009
SOURCE: Jenn Air lp grill won't light with the ignitor button
I just finished cleaning our starter on our jenn air. Over time, corrosion, rust and battery acid builds up on both the coils on the lid (positive side) as well as in the battery chamber and negative tip inside the chamber. I used sand paper and sanded the coils in the cap and the chamber. The coils need direct connection to the battery to create the charge. There are no instructions on this that I was able to find. I figured it out after about 3 hours of fussing with it. It worked immediately once I placed the battery back in. You may also need to clean the electrode tips near the burner. I used a q-tip. Hope this helps.
Posted on Apr 20, 2009
SOURCE: Jenn Air gas grill with cast iron burners...only
It sounds like your cross-over **** located underneath on the back of the burner is needs cleaning. Take your burner out, turn them over and your will see a slot on the rear of the burner. wire brush the slot until it has a clean ****. This cross-over **** is what brings the flame to the right side.
Posted on Apr 27, 2009
SOURCE: jenn air propane grill conversion
It is inconceivable to me that large manufacturers like Jenn-Air and Nexgrill can jointly make and sell an expensive grill and then completely abandon the consumer. I purchased an Jenn-Air 740-0142 LPG and like so many wanted to convert to nautural gas which requires a larger gas orifice. I spent a month on the internet and phone calling Jenn-Air and finally Nexgrill who actually manufactured the unit in China. The Jenn-Air and Nexgrill serial numbers are the same. the 740 prefix is LPG and the 750 prefix is natural gas. After three calls to Nexgrill I found a manager who actually acknowledged making Jenn-Air but declined selling me parts for it as I believe they have product liability concerns. I call back as a Nexgrill owner and finally ordered natural gas orifices at $10.00 each. The shipment never showed up. Calling back again I was told that they really didnt really have any orifices in stock but could sell me the entire replacement gas valve for $28.00 which I purchased. The valves actually arrived on the shipping receipt was from The Grill Services in City of Industry 909-718-6128 www.grillservices.com . Part number 750-0141/142/593/594.
Forget about pirates in Somalia... we have them right here. Shame on you Jenn-Air and Nextgrill.
Posted on May 31, 2009
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Do Jenn-Air have recommended suppliers? I have a Jenn-Air Gas Grill Model 720-0163 and need burners.
Appliance Factory Parts http://www.appliancefactoryparts.com/ is a good place to start. They carry parts for just about all makes and model grills. If you can't find what you need under Jenn Air, try looking under NEX Grill. Actually, they are the manufacturer of the Jenn Air Gas Grill.
Hope this helps you. Please let me know. Happy Grilling.
Jun 26, 2011 | Grilling
I am in the process of replacing my burners on a Jenn Air model #7200063LP. The burners appear to slide into the gas feed tube on the front part of the grill and attached to the back part of the grill with...
Yes, there really is enough space. Remove the cotter pin(s) and while lifting up the end of the burner farthest from you, pull the burner up and out.
To replace the burners, do the above in reverse. Just be sure the burner tube slides over the burner orifice, properly.
Hope this helped you change the burners and Happy Grilling!!
Jun 06, 2011 | Jenn-Air Grilling
Jenn Air Built in Four Burner Grill
Replace the regulator that should do it
Aug 01, 2010 | Jenn-Air JLG7130A
Flare behind temperature knobs on jenn-air gas grill
This seems to be a problem for most Jenn-Air users. The burners are defective, rusted or clogged and allowing the flame to "back up." You most likely have a melted electronic ignitor as well as gas valve damage. The new burners that I received this week for my model 720-0061-LP are 1/2 inch shorter than previous versions. Time will tell if this fixed the problem. I would call Nexgrill and get all new burners and inspect the gas valve area for damage. Since 2004, I am on my 5th set of burners, glad they were free since I have a lifetime warranty on my model.
Apr 17, 2010 | Grilling
Jenn Air gas grill model 720-0163 will not get above 180 degrees?
Try turning on just one burner to start, once it is on, turn on the next burner, if the flame gets lower on the first burner, you need to replace your regulator.
Dec 20, 2009 | Jenn-Air Grilling
What are the btu ratings for a jenn air model 720-0100 ng grill. i am converting this to lp gas...
does not matter just change out the orfices on all burners and back burner even if you have a IR buners, the orfices let enough gas in for your grill call jenn air they will sell you the kit to convert it over
Jul 29, 2009 | Jenn-Air Grilling
I have a Jenn-Air model #720-0061-LT gas grill. All three burners cracked and I have received replacements but can not get their Tech. Support people on the phone to get installation instructions. Greg
How did you get your replacement burners, they are covered under the lifetime warranty.
They are east to replace, simply lift out of guide hole in back of grill slide off of the gas source. Then slide new burner on gas source and position back into guide hole.
Jun 11, 2009 | Jenn-Air Grilling
Jenn air grill
You should test the wiring to see if there is any short that is causing the overheating.
If one knob only is getting hot, then the knob is probably faulty and need to be replaced.
I the all knobs are overheating because of heat coming from the grill, then is a bad heat insulation problem, better to call the service number listed on the owner manual and discuss the problem with Jenn Air in this case.
Here you find replacement parts for your model, in case you need to replace a knob.
Sep 16, 2008 | Grilling
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Grilling Logo
112 people viewed this question
Top Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
