Question about Kenwood Juicers
I have a kenwood multipro FDP60 and trying to figure out how to put it together to do juicing. Any help would be great. Thanks
Hi I was just using my Kenwood vita pro active JE810 juicer and putting through a small apple and it stopped working. I have changed the 13a fuse but it has made no difference. Any suggestions?
It is easier to solve the problem than it sounds. The solution is underneath of the machine located reset button called 'power overload'. Press it and here we have Vita working again. Have a nice glass of juice!
Alvydas
May 11, 2011 | Kenwood Juicers
I cannot remove the broken latch arm on my Omega 1000 Juice Extractor to replace it with a new latch arm. I have tried to follow vague instructions on the web, but I cannot remove it. Thanks.
It's a real pain and even bigger pain to snap the new one in place. Best way to do it is remove
the 4 screws, not the center one, and separate the base. You will then have access to the
latch arm from within, but remember how everything goes back together again.
Jan 27, 2011 | Omega 1000 Juice Extractor
How do i put parts together
check out for the service manual.... for it...
thanks for rating Good luck
Jan 05, 2011 | Champion 2000+ Household Juice Extractor
WONT RUN
is it all put together? if if is not all put together properly it will not power up. if the whole thing is put back like the picture and it doesn't work perhaps it is your motor?
Jan 03, 2011 | Champion G5NG853S Household Juice...
Wet pulp
There are two almost identical cone-shaped parts, one with metal screening and one solid dark plastic (I'm going by the parts color appearance of my 8003 model). Be sure you're using the one with the screen, otherwise the juice has nowhere to go but out with the pulp.
Jan 05, 2008 | Omega 8005 Juicer
Pomegranate
Well ya can juice 'em but it's a bit labour intensive .. lol 'cause ya gotta skin 'em, and get ALL the "Seeds" out, they taste bad... then put the pulp in.. and juice away... yield is low also .. but tastes real nice in the end.. I usually do it in a plastic bag,and tip the pulp into the juicer. Ya can make great "leathers" too..
Aug 04, 2007 | Jack Lalanne Power Juicer 250 Watts
OPENING the JC-250 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Jan 22, 2007 | Brentwood JC-250 Juice Extractor 350 Watts
Champion Juicer stopped working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Nov 09, 2006 | Champion G5-PG-710 650 Watts Juicer
Juicers Logo
303 people viewed this question
Top Kenwood Juicers Experts
eyecam
David Payne
David Payne
Tom Chichester
Are you a Kenwood Juicer Expert? Answer questions, earn points and help others
