Question about Husqvarna Garden
What are the steps to removing gas tank from Husqvarna 48" riding mower
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
If it is a rear tank unit, drain the fuel and disconnect the fuel lines. The transmission will need to be removed for clearance. Then locate the 3 or 4 mounting blots. The tank will then drop out from the bottom.
Posted on Feb 22, 2017
trippssmengi
  • 76 Answers
SOURCE: diagram of belt replacing on 21h 48 in cut husqvarna riding mower
You can try http://www.usa.husqvarna.com click on support and then product manuals. There you can find a diagram for your machine that could possibly help.
Posted on Mar 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: My 48
You will have to find another way to highten the deck, different bolts, shorter springs, Or if possible, adjusting the lever
Posted on Sep 03, 2009
spekgt
  • 60 Answers
SOURCE: Husqvarna GTH2250B riding mower leaking gas tank
Hi there
The tank on that machine is a Husqvarna tank . The part # is 532 15 13-46 and you can get it @ your local Husqvarna dealer. To find a dealer near you just check the link below
http://www.husqvarna.com/us/homeowner/support/dealer-locator/ . About any recall on the tank you probably have to contact Husqvarna direct . Use "contact" on the Husqvarna site .
Hope this help
mickey813
  • 472 Answers
SOURCE: Husqvarna gth 2448t 48'' 24 hp riding mower 2007
YA IT SOUNDS LIKE YOUR SEAT SWICH IS BAD THATS THE MOST COMON THING I SEE A LOT OF LET ME KNOW IF THIS HELPS YOU
Posted on Oct 08, 2009
  • 202 Answers
SOURCE: I have a Husqvarna Pro Rider 15 ride on mower,cuutting deck broke
You may find this helpful. A complete manual you can download and use for this and other repairs.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqom88hoen2003_1140142-26rideen.pdf
Posted on Dec 23, 2009
What are the steps to removing gas tank from Husqvarna 48 riding lawn mower?
Before you do that check the breather hole in the gas tank cap - that's the most common problem. Leaking is probably a faulty pipe, especially if you've disconnected them. Don't rely on push fit only - use hose clips.
Apr 30, 2015 | Husqvarna Garden
How could gas be entering the crankcase of my Husqvarna 48" riding lawn mower?
Sounds like you have a hole 'burnt' in the piston top allowing fuel combustion mixture (normally compressed above the piston) getting down into the crankase or that the piston rings are shot allowing the same thing.
As the piston is continuously moving, the reverse happens giving oil at the intake or carb.
. Looks like a strip down, good inspection and rebuild of engine required .
Sep 20, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How to remove fuel tank on 48 inch husqvarna riding mower
pull the rear seat/fender assy... the floor boards ( where your feet sit ) have a couple of bolts, then the seat springs have a couple of bolts... a couple of handles might have to be removed...
Aug 26, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
White smoke is coming out of exhaust of husqvarna yth2454
smell the oil and if it smells like gas you have a bad seal on the needle valve in the carb and gas overflows into the crankcase change the needle and seat change the oil and if possible add a fuel shut of valve and close it when not in use
Jun 24, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My Husqvarna will only stay running with the choke in and even then it will only run for a short time?
Gas flow through the carburetor is clogged. Easy fix is the following----- remove all gas from tank (siphon or drain). Put that gas aside or dispose of it. Use a little bit of fresh gas and a little bit of carburetor cleaner in the tank. Run that through (by running the motor with the choke.). Do it several time if needed. When it seems to be running better, then try just a little gas only to be sure you have cleared it. When you fill-er-up, be sure to add a gas additive like Sea Foam or similar.
Apr 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
When the mower is started it spits out gas fron
i have a honda riding lawn mower but it will runn for a bit then quites
Mar 26, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Oct 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Hi there
Hope this help
Sep 03, 2009 | Garden
Garden Logo
240 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
