Question about Copystar CS-4500i Copier, Printer"
Can I print up completed cover sheets?
I want to see the cover sheets that went through the machine for the past 4 days
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Copystar Expert
  • 194 Answers
Not possible
Posted on Jul 12, 2017
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    Mfc 5860 red printing green - already checked print levels. all are fine.
    1. Confirm that the colors are incorrect by printing a Print Quality Check Sheet
    a. Press INK.
    b. Press the UP OR DOWN ARROW key to select Test Print.
    c. Press OK.
    d. Use the UP OR DOWN ARROW key to select Print Quality.
    e. Press OK.
    f. Press COLOR START
    The machine will generate the Print Quality Check Sheet.
    2. The LCD will ask "IS QUALITY OK? 1. YES 2. NO"
    a. Press STOP/EXIT to return to the "Date and Time" display.
    3. Evaluate the Print Quality Check Sheet.
    On the Print Quality Check Sheet each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    NOTE: Cyan is the light blue color and magenta is the pinkish color.
    a. If the colors on the Print Quality Check Sheet do not match the sequence listed above then the ink cartridges are most likely installed in the wrong order. Continue to STEP 4 to resolve this.
    4. Open the Ink Refill cover.
    5. Open the cartridge covers of the colors that do not appear in the correct order.
    6. Remove the cartridges and reinstall them in the correct slots. On Brother Genuine Cartridges the color of the label will match the color of the cartridge cover.
    7. Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink supply tubes with the correct color. One or more of the ink cartridges may run empty during this process. If they do, replace the empty cartridge with a Brother Genuine Ink Cartridge before continuing the process.
    a. Press MENU - BLACK START - MENU. The LCD will display Maintenance.
    b. Press 7-6, The LCD will display CLEANING ALL
    c. Press 6, the LCD will display eINIT__P ALL
    d. Press the RIGHT ARROW key until one of the colors that was installed incorrectly is displayed. i.e. eINIT__P CYAN.
    e. Press the BLACK START Key.
    • After the machine completes the Setup Purge it will return to the Standby Display.
    8. Print another Print Quality Check Sheet
    a. Press INK.
    c. Press OK.
    e. Press OK.
    9. The machine will generate another Print Quality Check Sheet.
    a. If all four colors printed correctly the issue is resolved.
    b. If one or more of the colors are still not printing in the correct order repeat STEPS 4 - 8.
    Feb 17, 2011 | Brother MFC-5860CN InkJet Printer
    WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
    This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
    NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
    To resolve this issue you will need to clean the print head.
    NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
    1. First verify the position of the ink cartridges:
    a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
    b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
    - If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
    - If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
    Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
    When all the cartridges are installed, close the ink cartridge cover.
    2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
    1. Press the INK key.
    2. Press OK to select Test Print.
    3. Press OK to select Print Quality.
    4. Press the COLOR START key.
    5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
    a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
    b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
    6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
    a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
    b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
    c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
    d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
    NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
    e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
    If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
    NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
    7. Test by printing the document that had the reported problem (wrong color printing).
    Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
    While printing, red turned to pink on printed sheets. All cartridges have ink.
    Try
    Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
    Be sure to turn off the power and disconnect the power cord before cleaning the machine.
    i_important.gif Important
    bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
    bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
    With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
    sikaku.gif Cleaning the ADF i_expl.gif Caution
    1. Open the Document Tray.
    2. Open the Feeder Cover.
    3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
    4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
    5. Close the Document Tray.
    6. Reconnect the power cord then turn on the machine.
    Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
    How to configure printhead alignment
    Hi there, Aligning the Print Head
    If ruled lines are misaligned or a printout is unsatisfactory,Print Head Alignment is required.
    Steps for Aligning the Print Head.
    1) Press [Menu] repeatedly until [Maintenance] appears.
    2) Press [Maintenance] repeatedly until <P> appears.
    3) Press [Black] or [Color].
    The machine print the head alignment sheet.
    4) Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    5) Load the checked sheet on the Platen Glass.
    When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
    6) Press [Maintenance] repeatedly until <U> appears,
    7) Press [Black] or [Color].
    The machine scans the pattern and aligns the Print Head automatically.
    Note : If you select <L>in step 2, the machine prints the current Print Head Alignment setting.
    Hope this help.
    Have a good day.
    Dec 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Dell 962
    Have you tried to get it to print anything else? Like one of the internal reports, or just a document from your computer. That will determine if it can print at all.
    Once you can establish that it can (or can't) print, then you can troubleshoot other items.
    You did mention that you only use it a few times a week, it could be that the cartridge has dried up, or the print nozzle has become blocked.
    Try the tests, and please inform.
    Jul 31, 2008 | Dell 962 Photo All-In-One InkJet Printer
    How can I avoid printing a cover sheet every time we print on a 265 st xerox document center
    You have to enter the customer settings, access button then 11111. Scroll around until you find the location to turn OFF the cover sheets.
    You also MUST have cover sheets disables on ALL conputers connected to the machine. Somehow if someone on the network has the cover sheet turned on, it will sometimes enable it on the machine also.
    It is called BANNER sheet in the memory.
    Jul 15, 2008 | Xerox Document Centre 265ST Printer
    'paper jam' error on canon pixma ip4300
    Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
    Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
    Lexmark X7170 not ejecting printed sheets
    Time to get a new printer, because you cannot get the parts.
    Mar 01, 2007 | Lexmark X7170 All-In-One InkJet Printer
    Copystar CS-4500i Copier, Printer" Logo
    65 people viewed this question
    Top Copystar Office Equipment & Supplies Experts
    Kyocera HP Expert
    Tammie Duggan
    Tammie Duggan
    Timothy Van Der...
    Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
