Question about Shark Rotator Professional Lift-Away Vacuum, NV502 - lift-away vacuum
The brush roller has stopped spinning and all the hair has been removed, how do I fix it?
    Master:
  • Shark Master
  • 755 Answers
Hey this is Jim with Crucial Vacuum,
If there's no noticeable debris on the brush roll try manually rotating it to help unearth any hidden clogs behind it. Take note of the condition of the bristles while you're doing this. If they look worn down, or loose then its time to replace your brush roll.
Check your vacuums belt as well. Overtime your belt will stretch and loose resistance. This could lead to the brush roll no longer turning. Be sure your belt is on nice and tight to ensure optimal performance. Your belt should be changed every 3 to 6 months depending on usage.
You can purchase a wide variety of replacement belts for your Shark vacuum directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on May 04, 2015
2 Suggested Answers
fred_license
  • 350 Answers
SOURCE: How do I remove roller brush from Shark cordless handheld vacuum?
You have to remove All the screws, and you are correct they are almost impossible, after that most of the part's also snap together, so you almost have to break it to take apart, a vacuum repair shop knows all the tricks to opening these up....
Posted on Feb 20, 2015
My beater bar is not spinning on my Dyson DC39. Ive taken the head apart and see no reason why it wont spin. Any ideas
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 03, 2017 | Dyson Vacuums
The roller brush on my Bissell Proheat Pet won't spin at all. The belts are fine, i already removed hair and debris, and it dispenses water, as well as sucks it back up.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?page=3&q=bissell&type=product
Ava B.
May 11, 2016 | Bissell Vacuums
Dyson brush roller spins intermittently. it starts out good but then stops
Do you have a burning rubber smell at the same time? Turn the machine over and remove the bottom cover. Hook a loop of cord under the belt, pull it up wards and pull the brush out. Remove one end cap and pull the spindle out from the other end. Remove the fluff and hair that is tied around each end.
This shows quite well.
https://www.youtube.com/watch?feature=player_embedded&v=cYqOEpZgocg
Put the brush back and see if that fixes it. If not, then you need to change the two belts, and possibly the clutch. The same guy at Vacuum spot shows clutch servicing, but you may wish to get a professional to do it. How to check the Dyson DC04 Roller Brush Bearings
Mar 21, 2016 | Dyson Vacuums
Why doesn't brush roller rotate?
The ends may be clogged with debris. You will have to remove the brush roller and remove one end cap to disassemble the roller for cleaning.
Jan 09, 2016 | Panasonic Mc-Ul594 Eco Max - Bagless...
Dyson dc44 brushbar
https://www.thinkcrucial.com/search?type=product&q=dc44
Ava B.
Jun 17, 2014 | Dyson DC44 Animal Cordless Vacuum
Brush bar is not spinning
Common causes of brush roller failure are belt breakage and clogging. If this is a Dyson animal vacuum, you may find the brush roller is so clogged with hair that it cannot rotate. The solution is to remove the brush roller and clean it thoroughly, particularly inside the end caps where hair accumulates. It is unlikely that an entire animal was ingested.
Nov 20, 2013 | Dyson DC28 Animal Vacuum
Hoover mach 5 turns off after 10 minutes of use
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
Another item to check is if your dust filter is not plugged up which is located behind the removable dirt cup. This is the cup that you remove that collects the dust/dirt/hair from your floor. Take the removable dirt cup out by depressing the gold button and then look behind where the dirt cup sits for filter. This can be cleaned out by washing it with soap and water in the sink but make sure you let it dry overnight before placing it back in the machine. This probably causes some of the overheating when not enough clean air is passing through the machine.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Oct 01, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
I have a self propelled Power Supreme vacuum. It
Most common cause is fibre / hair in the roller and brushes. remove base cover and remove fibres . Remove screws and use small scissors to cut along roller / brush then pull gently.
Sep 20, 2009 | Vacuums
Replaced belts and brush roller will not rotate.
check to see if the spindle (small pencil-thin metal rod) is spinning where it projects from the motor. the belt wraps around this rod. if the rod is spinning when the vac is turned on your brush roller could be jammed. the bearing in the far sides of the brush roller frequently pick of long threads and hair and will stop the brush roller or the bearings sometimes overheat when worn and plastic will melt in this area causing stoppage.
Jul 10, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My brush will not turn, and the brush control is stuck on "off"
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Shark Rotator Professional Lift-Away Vacuum, NV502 - lift-away vacuum Logo
394 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
