How do I fix Fuser Error, when prompted
When I power on the Printer, after checking all components, the printer will prompt me with amber led light, signifying 50.4 Fuser Error
  • Office Equip... Master
  • 6,696 Answers
Replace the fuser unit. What make and model would help???? try this site for a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jun 02, 2015
SOURCE: printer alignment
hold down the enter button for 5 sec. then simultaneously press the menu button
Posted on May 08, 2007
SOURCE: fuser malfuncion
try this:   "turn off the power ,turn on the power holding the button, wait, then when the "drum" light is burning wait a sec then press the button again.  The printer will "dump" whats in its tiny 0.5mb memory and start a self diagnosis and will begin to print the results of the test."
Posted on Dec 18, 2007
Soulvisitor
  • 1113 Answers
SOURCE: HP clj 2550n error 50.2 fuser
Replace fuser assembly is the fix
Normal consumable, the lamp electrics (lamp, thermistor) will have blown.
9337832.jpg Part info
Posted on Jan 13, 2008
SOURCE: Unable to print Zebta TLP 2844.
When you get a red light it means that there is some type of error, either with the lable or the ribbon.
Take a look at the ribbon and make sure that it is properly placed in the grove otherwise it will 'slip' an wont move.
That is the most common problem that we get.
Posted on Mar 14, 2008
  • 13433 Answers
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Posted on Jun 26, 2008
What will I do to solve Fuser Error?
Hello Samaila,Would you please tell me the printer model,So i can help you,Regarding your fuser error...
Apr 30, 2015 | Office Equipment & Supplies
It is showing a triangle with excalamtion mark blinking
That would be the attention light.... Indicates that the input tray is empty, the print- cartridge door is open, or bad toner. Is there any lights that are on solid or flashing? (could also have a bad fuser ... need to trouble shoot this a little more)
If you hit the green button does it do anything?
- www.trusttechnology.biz
Mar 13, 2014 | HP LaserJet 1320 Printer
Fuser unit failure
Remedy:
1.Replace fuser unit
2.Check the harness connection between fuser unit connector and eject sensor PCB ASSY
3. Replace the PS PCB unit
4.Replace the toner LED PCB ASSY
5.Replace the main PCB assy.
You can try to leave the machine power on for 10 minutes maybe this can clear the error. Or power on the machine while pressing the SW supporter,when the front cover is open and check that toner, DRUM and error LEDs light up, and then release the SW supporter. Check that all LEDs go off and press the SW supporter once,and then this problem maybe cleared by that press the SW supporter once again after all LEDs light up.
Apr 14, 2013 | Brother HL-2170W Laser Printer
Amber "Paper" light constantly flashing. It has
This light sequence means that the printer prompts you to load a single sheet of print media in the manual feeder. What you can do is load paper into the manual feeder and press Continue to resume printing. Press and hold Cancel to reset the printer.
For further assistance, please call Lexmark Technical Support.
Apr 26, 2011 | Lexmark E250dn Laser Printer
Ours's a hp color laserjet 4700dn ; the message is 59.30 error ; we bought the machine in the year 2007 what do you suggest?
59.30 states it's the:Fuser motor startup error
Based on the service manual here are the steps to follow:
Fuser motor error
1. Reconnect the connectors J4605 for
the fuser motor and J1024 on the DC
controller PCB.
2. Run the component test to verify that
the fuser motor is working correctly.
3. Replace the fuser motor.
How to preform the component test below
1. Press Menu to enter the MENUS.
2. Press to highlight DIAGNOSTICS.
3. Press to select DIAGNOSTICS.
4. Press to highlight COMPONENT TEST.
5. Press to select COMPONENT TEST.
6. Select the component test Fuser motor. Use this test to rotate the fuser motor and drive gears.
Menus cannot be opened during component tests, so serves the same function as the Stop button.
More information on a Fuser motor failure detection
  • The DC controller determines the fuser motor failure and notifies the formatter of an error status when it encounters the following conditions.
  • Fuser motor start-up abnormality. The interval of the fuser motor speed detection signal does not reach the specified interval after 1.5 seconds of the fuser motor drive start.
  • Fuser motor rotation abnormality. The interval of the fuser motor speed detection signal stays at an irregular interval for two seconds and longer after it reaches the specified interval.
I've attached a screen shot of where the fuser motor is located It is # 8. tballone.png
Feb 25, 2011 | HP LaserJet 4700 Printer
Printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Lexmark X5150 All-in-One Error: 50
"When the printer fuser fails it prompts many HP laser printers to display an ERROR CODE 50 service code" same could be said about the lexmark fuser malfunction
replacining a fuser can be expensive might be better to get another printer unless you have a special bond like me i find it hard to just throw away things that have gone bad
Feb 01, 2010 | Lexmark X5150 All-In-One InkJet Printer
CR motor error prompts
CR Motor Errors are bad. Check to see if there are any bent or misaligned componenets on the carrier.
Mar 21, 2009 | Alps MD 5000 Thermal Printer
There is a red light flashing
From the OKI site, I found this information. My problem is a Flash 2 Blink, which is a problem with the cover or minor error, whatever that means. I can't figure out how to fix it. Any suggestions greatly appreciated!
Flash type Ready LED (Green) Manual feed LED (Amber) Error LED (Amber) Meaning Flash 1 -- slow blink X ecblank.gif ecblank.gif The printer is processing data when printing has been suspended. ecblank.gif ecblank.gif ecblank.gif X The image drum required changing or toner is low. Flash 2 -- blink X ecblank.gif ecblank.gif The printer is receiving and processing data during printing or the printer is resetting itself. ecblank.gif ecblank.gif X ecblank.gif The printer is requesting manual paper feed. ecblank.gif ecblank.gif ecblank.gif X There is a printing error, problem with paper or a cover open. ecblank.gif X X X There is a minor error with the printer. Flash 3 -- rapid blink X X X There is a major error with the printer.
Oct 27, 2007 | OKI B4250 Led Printer
All leds' are amber and solid... no flashing.
Have you unplugged the printer and retried? Also check for a paper jam.
Jun 19, 2007 | Xerox DocuPrint P12 Laser Printer
27 people viewed this question
k24674
jasbo
jasbo
