Question about Samsung SDE-120n 4 Channel DVR System
Boots up and runs perfect for about 5-10 minutes. Then it beeps twice and shuts down and does a reboot.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Could be a hard drive, power supply or DVR board issue. Try testing each by replacing except the DVR board which you cannot change without a new board. At which point, a new DVR is recommended.
Posted on May 17, 2016
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
My SDE - 120N Loads up and runs perfect for about 5 minutes and then it beeps twice and shuts down and restarts. Why?
listen to hear if the cooling fan turns on, you can probably turn it over and look through the grid, if it is loaded with lint then blow it out.. possible your CPU cooling fan is shot
Apr 30, 2015 | Computers & Internet
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
Shuts off and reboots then shut off in the middle of reboot.
these posts are endless here, truely
had to google it ah a DESKTOP
old Pentium 4 processor
circa 2003 , tiny HDD, and memory. old, Goodwill has 1000s parked.
well it can be many things,
did you remove all the cards first, (yes all)
does that hold up power? now?
it will beep, like that, if video car is pulled
and then pull memory, and it will give the ram missing beep codes
all this is covered in the great HP service books.,
beep codes and all
the power switch can be bad or the line cord. to wall. bad.
the power switch unplugs and you can short its 2 pins
to turn on PC< hold up now>?
hold up, means stay running,
you can strip it down, to just mobo and PSU
sure can,.
the CPU can overheat, sure can. and can be checked.
cpu fan works so is not that. im sure. and new thermal grease.
data sheet shows. (pull it,?)
nVidia GeForce4
GeForce4 MX
MX
440 440 AGP
AGP 8x
8x graphics
graphics card
card
Mar 12, 2017 | HP Pavilion A250n (DF253A#ABA) PC Desktop
I have a fujitsu seimens scaleo p computer with a asus pg5d1-fms motherboard. Everytime i start the computer up it runs for maybe five minutes and boots up and everything but it just shuts down. During the...
these are the meanings of those two beeps u're getting:
1 short beep : Normal POST - system is ok
1 long, 2 short beeps : Display adapter problem (MDA, CGA)
if u're still hearing 1 long and 2 short beeps then try to swap the MDA, CGA adapter around, if it is ok then that is the problem...MDA and CGA is just like the VGA card they supplements each other. replace MDA/CGA card with another then see.
Jun 17, 2010 | Computers & Internet
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Motherboard only boots every other time.
Change the CMOS battery.
It may be dead after sitting.
Thanks for using FixYa -a 4THUMBS rating is appreciated for answering your FREE question.
Oct 19, 2009 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Gateway 5056 Media center doesn't boot everytime.
did you look on gateways website for a bios update. the firmware on your motherboard maybe corrupt. go here and check since I dont have your serial number... gateway has a java based scanner that might be able to repair it for you
http://support.gateway.com/support/drivers/dlcenter.asp
please rank me if you can
Jun 22, 2009 | Gateway GT5220 PC Desktop
Laptop caught up in reboot sequence
Do you have the case speaker connected? If so listen for the bios beep codes. You will have to know which bios you have.
Dec 27, 2008 | Microsoft Windows XP Professional
Samsung SDE-120n 4 Channel DVR System Logo
753 people viewed this question
Top Samsung Home Security Experts
Mike
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
