Question about Canon imageCLASS MF216n Black-and-White All-In-One Printer
How do I change the number of rings on my canon mf216n. It is set for 5rings and I need it changed to 2 rings
    Sergeant:
  • Canon Expert
  • 316 Answers
Under Menu - fax settings - you can set the number of rings to pick up.
Posted on May 07, 2015
Send & reseive fax
Set Fax system and adjust your Fax address .
Set Local fax code with fax number.
Apr 27, 2016 | Canon imageCLASS MF216n Black-and-White...
Change number of rings before answering
Change the ring count on the fax when the receive mode is set to Fax/Tel or FaxOnly modes. Change the ring count on your answering machine when it is connected to the fax and the receive mode is set [Ans mc connect] (Answering Machine Mode).
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button.
  3. Press the left or right arrow button to select [Maintenance/settings], then press <OK>.
  4. Press the left or right arrow to select [Device settings], then press <OK>.
  5. Press the up or down arrow to select [FAX settings] (item <1>), then press <OK>.
6. Press the up or down arrow to select [RX settings] (item <3>),
then press <OK>.
7. Press the up or down arrow to select [Incoming ring], then press
<OK>.
8. Press the up or down arrow to select [ON], then press <OK>.
Note: The default setting is [OFF]
    1. A window will appear displaying the number of rings before the machine will answer. Press the up or down arrow to select the number of rings (from 1 to 30 rings).
    2. Press <OK> to set the number of rings.
9. Press the <Stop/Reset> repeatedly to return to Fax standby
mode.
I hope this helps.
Apr 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How can you delay the number of rings from 2 to 6 before fax answers on a canon 5570 imagerunner?
enter the function setting by pressing the * key
fax setting
tone ring
and change the setting
Apr 07, 2010 | Canon imageRUNNER 5570 Copier
Need to change the pickup from one ring to picking up on the 5th
This should do it:
Press the {Function} {6} then enter
the access code {2} {2} {2} {2}.
Then press {6} {1} and the {Yes} key
press the 'next' (right arrow) key until it displays "set number of rings" . Press "yes" (the current setting is displayed). Press "no" to change. Enter the desired number, then press "yes" to set. Press "function" to exit.
Please rate me :)
Mar 14, 2009 | Ricoh 2050L Laser Fax
Change number of rings to answer on iRC3170 fax
I believe, you just have to open the doors on the control pannel. It will show you more funcation of the fax. There should be a botton that say's "Data Entery" press it once and the display changes. Next you use the arrow bottons on the control pannel to move in that mode. Scroll down to Fax Setting and press the OK botton and scroll some more till you see number of rings and change it from 5 to 2 rings. Then press OK or Set, the press Stop/Rest twice and you should be done. It's alot hard to explain then doing it. It's called panich botton pushing..... Good luck
Jan 01, 2009 | Office Equipment & Supplies
Ihave a conon mx700 and the fax tone rings when I get a phone call
Go through the menu on your Canon, and change the setting from auto answer to off. You might also want to change the number of rings before answering (to like to 7 or 10)
Aug 05, 2008 | Canon Office Equipment & Supplies
Fax\phone line
Here's how to change the ring count...and I'm also providing the link for support and troubleshooting your specific machine on Canon's website...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
To Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [INCOMING RING] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select [ON] then press <OK>.
5. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
Hope this worked for you!
MaggieB
Feb 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Ring Cont on Canon LC 8500
lift up the 2 keyboard panels and press data registration and press set. scroll down using down arrow to RX settings and press set scroll down to turn ringer on and set the ring count to 3 and set and press stop a few times.
Feb 19, 2008 | Canon LaserClass LC 8500 Plain Paper Fax
Changing the amount of rings
Pick the phone up earlier it will stop ringing......:-)
To set the number of rings-to-answer
To set or change the number of rings-to-answer, use the following steps:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Fax setup, and then press tick
3. Use the < or the > button to select Fax Recv. setup, and then press tick
4. Use the < or the > button to select Rings to answer, and then press tick
5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press tick
But I still think picking up the phone earlier would be easier
Your Manual, please rate as fixya or post back
Dec 28, 2007 | Office Equipment & Supplies
Canon imageCLASS MF216n Black-and-White All-In-One Printer Logo
498 people viewed this question
old marine
old marine
