Question about Hotpoint Washing Machines
New Door Lock - Machine does nothing
Hi, I have and Hotpoint Aqualtis AQGD169s. I used the machine in the evening and the next morning, I went to put a load in and the door would not lock. My husband called espares and ordered a new lock and followed inline video instructions which looked easy enough. The new lock was diffrerent to the old lock. The old lock has two connectors and the new lock has 1. We called espares again, who had no clue that this machine had this issue and did not have a solution. We returned the part and then thought it best to contact hotpoint. Explaining the issue to them, speaking to three different people with three completely different answers, we ordered a part and wiring kit. All fitted, the mchine switches on, and does nothing. No error code. Not sure what to do. Please can you help?
    Genius:
  • Hotpoint Master
  • 1,585 Answers
Make sure the wireings in right order
Posted on May 04, 2015
SOURCE: Hotpoint washing machine WMA66
Thank you gittos73.
It's as gittos says. When you open the door and look inside, at the very top of the door is a white square. This holds the metal clip. If you push the little white dot in the middle of this clamp gently, it gives way and you will see the round metal clip that goes all the way round the door rubber (gasket). Remove this and you can put your fingers round the gasket and pull it toward you.
Then take the lid off the machine and you will see a 6mm nut with a spring behind it and a wire clip similar to the front one, going round the gasket where it attaches to the drum. This has a crosspoint (phillips type) head on it and you can get a small screwdriver into it and undo it all the way. Then slide the gasket off and it will come away.
Fitting it is the reverse but it is a little bit tricky as you have to get the gasket behind the lip to make the seal. Take your time and they will both go round properly.
Posted on May 28, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WMA13 door lock fault
If the door locked light is flashing , then the main board probably has a fault on it, due to a problem with the motor, or the board itself being faulty.
Recommend calling an engineer.
Posted on Jan 04, 2009
SOURCE: i have just fitted a
How do i replace the door handle on my hotpoint washing machine (wt960)?
Posted on Jun 13, 2009
  • 157 Answers
SOURCE: I have fitted a new door lock on my hotpoint
wiring must be wrong or could be pcb fault not lock
Posted on Oct 12, 2009
Testimonial: "THANK YOU, WILL CHECK WIRING. IF ITS PCB BOARD MAY AS WELL GET ANOTHER MACHINE, ITS 6 YEARS OLD"
SOURCE: I have a Hotpoint Aqualtis washing machine. It is not working
Check if the waste pipe isnt blocked.
Posted on Jun 28, 2010
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
Hotpoint aqualtis aqgd169s no power wont turn on not even had an error code come up
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
May 26, 2014 | Hotpoint Ariston AW125 Front Load Washer
It seems most likely shorted somewhere in the wiring system and you have to check for every defective part ,use step by step method
Dec 10, 2013 | AEG Washing Machines
I have a electrolux ewx 14440w washer/dryer. its had a new door lock but the machine works sometimes and other times it double clicks and then stops........I put it on a 30 degree wash and it went through...
Hi shirleyb16 - I recommend to get a professional to diagnose the unit for repairs. From what you have described if the unit has a new door lock assembly, then you are going to either have a faulty timer or control board.
Sep 16, 2012 | Washing Machines
I have hotpoint wma62 and door lock light flashes, machine will not start as door will not lock any clues ???
Hiya,
yes, i can help..
Firstly, lets start simple. Have you noticed the door lever/handle has got "floppy"? or loose? or easy to squeeze?
This is the most common reason, what happens is there are 2 bits of spring steel behind the handle, these either break or become weak, to test this theory, close the door, put your finger between the handle and the door and push the handle towards the glass, if this works then you need a new spring/handle.
Please let me know,
Please rate my help.
Regards
Sussex engineer.
Oct 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aqualtis Stacking Kit
I Have the same machines and the only option is the Hotpoint stacking kit. Available from Hotpoint - 08448225225. They are selling it half price at the moment for around £70 delivered. I have been assured by Hotpoint this is the only option.
Mar 01, 2009 | Silver King Stacking Kit For SKR27 and...
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Aqualtis AQGD 169 S F12 problem Please help :-(
ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
Jul 01, 2008 | Hotpoint Aquarius WD640 Front Load...
WMA46 stopped woking power off mid cycle
hi there the problem you have sounds like the motor has shorted out causing the pcb to blow, sadly this is a costly repair and is usualy not worth repairing as you will need a new motor and pcb
murdozzz
Dec 09, 2007 | Hotpoint WMA46 Front Load Washer
No power to washing machine but fuse is ok...
could be 2 things 1)try closing the door and banging the machine on the front next to where your door catch goes into the washer if it starts could have a lose wire or be faulty 2)if no1 doesnt work than it will be your mains filter which if blown power doesnt get to your machine if the machine is brand new and has manufacturers warranty then these are covered through the warranty and any tampering will void your warranty though should be covered for no less than a year
Nov 26, 2006 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
77 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
