What will I do to solve Fuser Error?
When I power on the Printer, after checking the scanner, it prompt me with amber led light, signifying fuser error.
  • Aqib Saghir
    Aqib Saghir Apr 30, 2015
    ok first turn off your printer and leave it for 10 minutes.Next follow the video and remove your fuser,clean the golden connection of fuser and reinstall it again.Try to change power chord and socket.IF problem is not solved take it to service center they will diagnose and decide to change fuser or dc controller PCA.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Hello Samaila,Would you please tell me the printer model,So i can help you,Regarding your fuser error...
Posted on Apr 30, 2015
Testimonial: "HP LaserJet M5035mfp"
How do I fix Fuser Error, when prompted
Replace the fuser unit. What make and model would help???? try this site for a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 30, 2015 | Office Equipment & Supplies
Fuser unit failure
Remedy:
1.Replace fuser unit
2.Check the harness connection between fuser unit connector and eject sensor PCB ASSY
3. Replace the PS PCB unit
4.Replace the toner LED PCB ASSY
5.Replace the main PCB assy.
You can try to leave the machine power on for 10 minutes maybe this can clear the error. Or power on the machine while pressing the SW supporter,when the front cover is open and check that toner, DRUM and error LEDs light up, and then release the SW supporter. Check that all LEDs go off and press the SW supporter once,and then this problem maybe cleared by that press the SW supporter once again after all LEDs light up.
Apr 14, 2013 | Brother HL-2170W Laser Printer
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
925 service fuser error
A 925 Fuser Error indicates that the wrong fuser lamp or the incorrect fuser assembly is installed.
  1. If this error appears shortly after the fuser unit in the printer is replaced, put the old fuser unit back in.
    If the error message goes away with the old fuser unit, please check that the new fuser unit is the correct one for this printer model.
  2. If the printer has not recently had its fuser replaced, plug the printer directly into a wall outlet. Surge protectors and power strips can sometimes regulate the voltage to a fault for the printer. If the printer is already on a wall outlet, plugging the printer into a different outlet may solve the problem. Keep in mind that there is no need to have the printer connected to a computer during testing for a fuser error as any pages to test the functionality of the printer can be processed internally.
  3. If you have tried the printer on other wall outlets and the 925 Fuser Error still appears, the printer will require service to clear the message.
Jan 12, 2010 | IBM Infoprint 1352 Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
50.4 fuser error
Some suggestions:
  • Turn the printer off for 20 minutes and allow the fuser to cool (this may resolve high temperature fuser errors).
  • Re-seat the cooled fuser assembly (this may resolve other non-temperature related fuser errors).
  • If the printer is plugged into a power strip or surge protector, plug it directly into a wall socket or different circuit (this may resolve errors caused by an inadequate supply of electricity).
  • Try a different power cord (the current power cord may be damaged).
If still a problem, your fuser is faulty and needs to be replaced (typically not a user-serviceable item) by service. Hope this helps.
Jul 21, 2009 | HP LaserJet 5000 Printer
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
Fuser error 50.2
1) First thing is check power source. If you have the printer plugged into a UPS (uninterruptilbe power source) unplug it and plug it directly into the wall. If it is plugged into the wall you might want to try a different outlet to see if it solves the problem.
2) Remove and reinstall the fuser. It may not have seated properly.
#) Make sure you installed the correct fuser. Should be RM1-1082. There should be a sticker on the fuser with this number. See the following article for more info. http://www.partsnow.com/service_today/0705.asp
If you still have the old fuser check also that it is a RM1-1082. If not you may have a euro version machine which would require a different fuser.
If the fusers match up you should check the voltage coming to the fuser if possible. If there is 100- 127 volts where the fuser plugs in you probably got a bad fuser or it was damaged in transit. If there is low voltage or no voltage you may have a board problem. Probably DC controller or Power Supply.
Mar 30, 2008 | HP 4250 Monochrome LaserJet Printer
Fuser temp error
To test fuser out of circuit make sure lamp and thermal fuse are not open circuit, and thermister is neither open or shorted
Fuser repair procedure from tec manual.
Fuser Failure (U4-1, U4-2, & U4-3)
Switch off printer main power. Remove the Fuser Full Cover so you can observe the Heat Rods. Switch on printer main power and observe the ends of the Fuser Assembly. The Heat Rods glow.?
Y N
Go to step 5.
2 Replace the Printer Engine Controller PWB (REP 4.10.6). The error message reappears.
Y N
Problem solved.
3 Replace the Fuser Assembly The error message reappears.
Y N
Problem solved.
4 Check for a broken wire or a loose connection
between components
5 Measure the AC voltage between J23-2 and J23-6 on the AC Driver PWB. There is 110VAC (or 220VAC if the printer is the 220VAC model) between J23-2 and J23-6.
Y N
Go to step 7.
6 Replace the Fuser Assembly (REP 4.7.1). If the problem persists, replace the Printer Engine
7 The Fuser cycles up and down.
Y N
8 Measure the voltage between P401-1 and P 401-4 when the Fuser Fan cycles up and down. There is 24VDC between P401-1 and P401-4 when the fan is rotating and 0VDC when the fan is off.?
Y N
9 Replace the AC Driver PWB
Please rate solution to your question "How can I check that new Fuser unit is ok?"
Jan 10, 2008 | Xerox DocuPrint N32 Laser Printer
Laserjet 6L
The way-off ohms reading would suggest the fuser element is bad. If the fuser is not heating, a sensor will tell the logic circuitry so, and thus your error, and no-print condition. I'm reasonably certain the self check at power on checks for fuser heating. Guessing here, but a heating check is likely done prior to a printjob being completed too. If you can check the voltage at the fuser during the self check or as it readys to print, this would tell you if full voltage is applied. The 12 volts you are seeing probably is a standby voltage. The HP laserjets I've worked with all have higher heating voltages than this. You might be able to find some more accurate info elsewhere on the 'net.
Apr 23, 2007 | HP LaserJet 6L Printer
jasbo
jasbo
